Old 12-08-2006, 12:27 AM
formulabird428's Avatar
formulabird428 formulabird428 is offline
Default low dyno result???
I know this is probably a "rookie" question, but does this dyno not seem low for this combo? I was expecting an honest 575hp+ out of this, but the engine only pulled 540@5900rpm.
maybe with a carb/intake change, 575 can be achieved...
428 + .060 = 440cid
74cc KRE 326/525 heads
11.0 : 1 compression, 210psi (hot)
255/263 @ .050", 108LSA, installed @ 104, 594/610 lift@valve
solid flat tappet camshaft, .016" valve lash
torker II, matched to fel-1233, HP 830cfm Holley
Hooker SC 1.75" primary, 3" X-pipe exhaust
MSD Pro-billet distributor, 6AL, Blaster2, 31deg timing
I guess my question is...is the TorkerII and 830HP hurting me that much?
Btw, if anyone knows, is KRE's "house HP950" just a stock HP, or is it modified in any way?
Old 12-08-2006, 12:39 AM
tom s tom s is offline
somethings just not right with your combo.Good HP for RPM but engine should make peak HP at higher RPM IMO.Tom
Old 12-08-2006, 01:35 AM
GOAT490's Avatar
GOAT490 GOAT490 is offline
Did you play with jetting and timing? Is that all the timing KRE's need? Did you try any spacers? Can you post the dyno sheet?
PHILLYGOAT
PHILLYGOAT
1965 GTO/ OEM Block, Crank & D-ports(all slightly modified of course)/
3550lbs/ Full Exhaust/ Foot Braking
1.41 60ft [email protected] [email protected](Pontiac Heaven)
More Details on GOAT http://www.pontiaczone.com/forum/vbpicgallery.php?do=view&g=379
GTO Burnout http://www.youtube.com/watch?v=nZqdcH0Ltc4
Old 12-08-2006, 01:46 AM
timing was checked at 34, 32, 30, 29, and finally 31 where max power was made.
jetting was checked, coming out to 78/84
lash was checked, initial was .024", made +12hp @ .016"
engine was dynoed w/1" open spacer <--still on the engine now
Old 12-08-2006, 01:48 AM
**btw, the reason I asked about KRE's 950HP, is because they put it on my engine, and the engine picked up 18hp @ max.
Old 12-08-2006, 03:10 AM
screamingchief's Avatar
The fact it picked up by tightening the lash is telling me it may be a bit undercammed,as reducing the lash makes the cam seem "bigger" to the engine.
What ratio rockers are on this?
Might also try installing that cam straight up and pulling it again,this also makes the cam seem "bigger" to the engine.
If it keeps "picking up" as you tighten up the lash,and retard the cams ICL,and add more rocker ratio,likely it's time for more cam.
If that's the case,I'd go up about 4-6 degrees on duration for the next cam and start with it advanced 4 degrees like this one is.
I dont think it's costing you 35hp myself,I'd be inclined to believe 18hp could be lost to a better carb like the KRE unit you mention,but I dont use those HP carbs that much myself,so I dunno for sure,on a combo like that I'd be using at least a well built 850 (4781 based) unit myself.
JMO/HTH,Bret.
Old 12-08-2006, 04:54 AM
Engo's Avatar
Engo Engo is offline
What has already been said. And I would like to add, based on my experience with these heads.
Add about five degrees of duration and put them on a MUCH wider lobe separation, like 114-115. Put the cam in straight up. Add a Victor intake and a 1050 Dominator or the biggest 4150-style carb you can find.
The peak hp should be around 6300-6500rpm with those heads.
I think you could see 650hp with the right combo.
Street/strip 1969 TA clone. Back halfed. 3300lbs. Twin turbo LSX 387cu. JW glide. Holley Dominator EFI. E85. Street driven.
https://www.facebook.com/photo.php?f...type=1&theater
Old 12-08-2006, 05:07 AM
John Bailey (GTOKID)'s Avatar
John Bailey (GTOKID) John Bailey (GTOKID) is offline
Am I wrong... I thought NUNZI made 760 with a 440 a 4bbl on gas with RA4 heads...in the 90's?????
Old 12-08-2006, 06:13 AM
RAIV55 RAIV55 is offline
With your heads and cam, I would've expected peak HP at a higher RPM. As the RPM climbs, even though the torque is falling, the engine will continue to show more power.
SC is correct concerning lash, not iron clad but a good indicator.
Old 12-08-2006, 10:18 AM
gearbanger's Avatar
gearbanger gearbanger is offline
I doubt it on pump gas.
Old 12-08-2006, 10:47 AM
Skip Fix Skip Fix is online now
You can't completely compared dynoes to diferent dynos. My current 455 E head pump gas motor on a Stuska dyno put out 525hp @6200, less than the Moroso slide says it has from the mph. It even had less TQ than HP. How many dynoes do that, usually they are way above on TQ and way above the Moroso slide once in the car. It's pushing a 3750 lb car to 10.99@ 124.5. Torker II and 850 DP with a Shaker.
Using dyno numbers as absolute is like using flow bench numbers as absolute. great tuning tool against itself but not exactly against the one across the street.
Old 12-08-2006, 11:28 AM
Billy177's Avatar
Billy177 Billy177 is offline
if you ran it with that air cleaner on you may have left a lot on the table
70 GTO
462 E-Heads TKO-600 9-Inch/3.60's
Old 12-08-2006, 11:30 AM
Cliff R's Avatar
Cliff R Cliff R is offline
KRE's HP950 is pretty much right on the money. I used it about this time last year as part of our testing when I had my engine out for a cam change and "freshening up". It made 2 less HP than my Q-jet, which is dialed in exactly for my engine. We just tried it because we weren't getting the power we thought the engine should have been making, so we installed an MSD billet distributor (lost slightly less than 1hp) and KRE's HP950 (lost 2hp), over my HEI and Q-jet.
I also tested a flat solid cam last year, and found that even at 240/248/112, with Comp's "very best lobes", it made 22 ft lbs and 10 hp LESS than my Crower 60919 (231/240//113) flat hydraulic cam. It would have taken almost another 10 degrees @ .050" to make about the same power. It was my first experience with flat solid grinds. We immediately went to a hydraulic roller, but, if I were to test any more of them, I'd pick them about 20 degrees @ .050" bigger than I thought I needed.
We ran the T-II set-up on my engine, and although it made the highest peak hp, the RPM made a LOT more average power. It's really all about the combination of parts. My guess is that the solid cam on a 108 shut the power down a tad early in the rpm range?......Cliff
Old 12-08-2006, 11:41 AM
Flamin65's Avatar
Flamin65 Flamin65 is offline
Sorry I'm not trying to highjack this thread but I have a question for Cliff R. What do you have done to an HEI that it makes 1 more horsepower than a billet MSD. The reason I'm asking is I'm getting ready to buy a distribtor and if I can get an HEI instead of a billet MSD I will.
Thanks Greg
Old 12-08-2006, 12:59 PM
GoatRider's Avatar
GoatRider GoatRider is offline
Your cam sounds (exactly) like the one Bullet recommended for my 433 engine.
However I have only 9.8:1 compression, and 255cfm heads, and asked them to recommend a cam with max HP at 6,500rpm.
Based on them being correct (I have not tried it yet) I would say your camshaft is too "small" for your better flowing heads and higher C.R.
I agree with ScreamingChief, try a camshaft with more duration.
Good luck and have fun!
"Nothing Beats an Ol' Goat."
Old 12-08-2006, 01:28 PM
My DUI HEI and a MSD billet with a 7AL box on the dyno were identical.
I heve picked up without an air cleaner. I forgot my longer carb stud for my setup to do that at the track. After clicking 10.99 and 11.00s I figured that was fast enough.
Old 12-08-2006, 01:41 PM
jm455ho's Avatar
jm455ho jm455ho is offline
We got 584 HP @ 5700 rpm with 464 cid, KRE 290 heads and a slightly smaller cam than yours. I think the 108 LSA with the 104 ICl is whats costing you a few ponies. Check out the dyno results on our website for more info.
www.hobracing.com
Old 12-08-2006, 02:32 PM
71 Ventura II's Avatar
71 Ventura II 71 Ventura II is offline
IMHO those 1 11/16 butterflies in the 830 carb are not helping. Even though your combo calculates between an 800-830 cfm because of the high efficiency of the engine you are going to pick up considerably with between an 850-1050 carb. At the minimum I'd try to borrow an 850 or 950 to see how it reacts.
I agree with the camshaft being to small, so to speak. rather than change cams just test the larger carb first and then try installing "straight" up. You may gain a few HP with a Victor but the TQ2 is a decent intake as well. JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
Old 12-08-2006, 04:11 PM
scott70's Avatar
scott70 scott70 is offline
I use that same cam but mines a 455.My combo will next summer will be 455,Ud 255/263 with 1.65 rockers,victor with a dom. carb and 315 butler eheads,,,,,,,,,,,,,,,,,not that far off from your combo.Hopefully soon it will hit the dyno for a comparo.That cam is supposed to be installed at 102 icl.Mine came in at 103 so i left it.The middle of this year i tried it at 101 icl at the track,it seemed to pull better at 103 and run its best times so put it back at 103 ICL..Mine also ran its best at 30- 31 total degrees.Your running the exact combo i used to run except for the heads.Ive been using #62 heads that flowed 251.Im with you,with that combo i would of been looking for at least another 25 hp and more trq than 537 lbs.
Old 12-08-2006, 04:17 PM
Mines a 112 LS, 107 IC
