Old 01-04-2007, 04:36 AM
pjdutton pjdutton is offline
Default BLOCKING OFF HEAT RISER
Do the flow advantages in blocking off the heat risers in the head justify the work involved?
Old 01-04-2007, 12:06 PM
RAIV55 RAIV55 is offline
yes
Old 01-04-2007, 12:59 PM
engineer engineer is offline
not a flow advantage, but a heat issue with the fuel in the carb.
Old 01-04-2007, 06:50 PM
Yes, a flow advantage on the 4 EXH bowls.
Yes, a reversion-contamination isolation-advantage on 4 & 3 vs 6 & 5.
Yes, a cooler head temperature...in the middle-zone where the fastner shank show surface rust.
Yes, a cooler head temperature...in the middle-zone where the head-gasket shown plastic deformation reflow...and likes to blow.
I think it'sa good idea to Fill our crossovers, rather than blocking plates or leave open.
Old 01-04-2007, 07:01 PM
Region Warrior's Avatar
Region Warrior Region Warrior is online now
Consider it a std op for headers.
Old 01-05-2007, 01:45 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Not just with headers- as HIS pointed out, 'sharing' of exhaust ports by cylinders 1/3 & 2/4 ain't good- reversion, etc.
Old 01-05-2007, 02:29 AM
BVR421's Avatar
BVR421 BVR421 is offline
Not worth half the effort on a street car unless already doing a major overhaul on the heads.
If race only then yes.
Old 01-05-2007, 02:31 AM
Will Will is offline
I'd have to go along with BVR421 with a big "it depends."
What exactly are you trying to accomplish with the engine? If it's simply a strong street engine in a cruiser, then I don't see it as being worth the effort.
If you're setting the car up for maximum performance, whether street or strip, then yes, it's definitely worth the effort.
Old 01-05-2007, 03:53 AM
explain flow advantage? a reversion-contamination isolation-advantage on 4 & 3 vs 6 & 5.
if order is 1 8 4 3 6 5 7 2, and 4 6 are common with 3 5 common, how can the exhaust from opposite cylinders interfere? There is no back pressure from one on the other?
