Old 01-23-2007, 01:03 PM
cgeise's Avatar
cgeise cgeise is offline
Pinion angle is generally around 2 degrees -- depending on how hard you want to hit the tire -- and engine/trans centerline should be "pointed" aor angled at the pinion -
Old 10-31-2022, 03:41 PM
Nacs Fab's Avatar
Nacs Fab Nacs Fab is offline
Default Tube Chassis Engine Placement
What kind of pan clearance are you guys experiencing with such low crank centerlines of 12” and below? I’ve got my 68 Firebird sub frame mocked up so that I should have about 6” from flat part of my rocker to the ground.
This allows me to modify my crossmembers to allow a low crank centerline but I’m only going to have about 1-1/2” off the ground to my 20490 9-3/4” deep Moroso oil pan.
69 Firebird - Angry Bird
455 with 84mm Torqstorm
Old 10-31-2022, 04:39 PM
cgeise's Avatar
crank center at 12 -- pan depth of 8 ish gives you 4 in of ground clearance .-- time for a new pan. and depending on the cars use -- 12 to 13 crank heights work ok.
Old 11-02-2022, 02:03 PM
Probird's Avatar
Probird Probird is offline
You’ll have to have a different pan. That’s too low. You will bang it on everything. I think we ended up with about 6” or so. It uses the 7 quart pan. My other car sits way lower and the only pan that will fit is a dry sump pan.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
2024 Chief of the Pontiacs
Old 11-03-2022, 07:11 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
The Raven is crank CL ~ 12 3/8 at ride height, engine set back as far as possible with stock firewall.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
