Old 03-30-2007, 09:01 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
HIS, not to argue with a rocket scientist, but....100lbs or sprung weight is a tenth(.1). not .01. But then again I am not a believer in the sprung vs unsprung formula posted either, I beleive it makes some difference, but not that much. JMO,FWIW. -Jim
  #42
Old 03-30-2007, 09:21 PM
Diamond Jim....I was "quoting" the M/T site for their "highly technical guidance". DiamondJim how come it took ME to spell-out the obvious and YOU to point-out the obvious. I seems to be in agreement on the tenth-sec for 100Lbs.. 12Lbs unsprung *8 to equal ~100Lbs load ("sprung") for +0.1 ET. Like a tithe huh. M/T guidance spells-out .01
Also: seems the tubless folks here are totally NOT-tubular about slicks.
I did an experiment with 2 balloons: put a hole in a balloon then stuff it into another balloon that hasa had the blow-ring removed...and blow the INNER balloon up against the outer balloon.
Good luck: I found it impossible to get the inner balloon to seal against the outer balloon. Since I'm a dumb-arse moron, can someone else try this at home and see if then can get an inner balloon (the tube) with a small hole to seal its air to an outer balloon that has it's blow-ring cut off?
I might go tubeless
Sooooo, uhm what is all this talk about hand-soap , like we own the little green bottle of Palmolive dishpan hand soap. Is that the trick stuff?
  #43
Old 03-30-2007, 09:23 PM
WDCreech's Avatar
WDCreech WDCreech is offline
I put my tubeless 15X33 Mickeys at 5 lbs. before loading the car into the trailer last September 4. Just checked them and they're at just over 4 lbs. Also, a tubeless tire is safer than a tire with a tube because the tube will cause the tire to build more heat. Hot tires and speed don't mix.
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
[email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
  #44
Old 03-30-2007, 09:33 PM
WDCreech's Avatar
"I might go tubeless
Sooooo, uhm what is all this talk about hand-soap , like we own the little green bottle of Palmolive dishpan hand soap. Is that the trick stuff?"
I don't know about "hand soap", but I always use Dawn dishwashing liquid. I keep a bottle in the garage, just for mounting tires. I coat the inside of the tire completely with a clean shop rag soaked with Dawn, and then the bead. It has always worked good for me.
Bill
  #45
Old 03-30-2007, 09:34 PM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
HIS, I prefer the green Palmolive dish soap! I keep some at work in a Plastic container for mounting my tires.
I also use Hunter wheel lube on the bead. Acts as a lube when wet, and an adhesive when dry.
Anyone in my area, let me know if you need your tires mounted.
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
  #46
Old 03-30-2007, 09:49 PM
Uhm,
I have a pair of M/T's N A T U R A L Rubber tubes in nice shape, with the fancy valve-stem jobby. Fits the rage that includes the 28 x 9 x 15 Slicks. They are in nice, unscrewed condition.
Sooooo, I gotta drill-press the Rims full of rim-screw holes first huh.
  #47
Old 03-30-2007, 10:08 PM
Personally, if I run any kind of slick on a car with any kind of power, I would put screws in the wheels/beads whether they would be tube or tubeless.
Just make sure the screws are aimed at the bead when installing them.
They can start to go toward the tire just above the bead.
Then they may go through the tire and possibly leak air there.
  #48
Old 03-30-2007, 10:36 PM
DiamondJim's Avatar
HIS, I apologize, I didn't catch the MT .01 and your being facetious, my bad. I do know that running tubes and not screwing rims can be a bad thing(with enough power applied). I have run both ways, my QT Pros have tubes and screws, I ran Goodyear slicks without tubes or screws, now I have MT Drag Radials(no screws). Not only are drilling all the holes a PITA, but the MT tubes I have required drilling the valve stem hole out. Goodluck-Jim
  #49
Old 03-30-2007, 10:47 PM
mikeb mikeb is offline
Originally Posted by Half-Inch Stud
Uhm,
If you have a steady hand you can do it with a hand drill after marking off the screw locations. I did mine with the slicks already mounted (without tubes). Practice on the back side first
If you've already drilled out the valve stem hole and want to go tubeless you can get the larger metal valve stems from bob drake reproductions on the net.
  #50
Old 03-31-2007, 09:47 AM
BAD455TA's Avatar
BAD455TA BAD455TA is offline
Sorry if someone already said this I didn't read this whole thing but I had the same problem and I put a sh!t load of green seal in it for flat tires and it sealed. Didn't feel like tearing the tire down again. I don't think this would hut performance just a pissed off tire guy when he changes it.
  #51
Old 03-31-2007, 11:08 AM
DiamondJim's Avatar
MikeB, I went to the Bob Drake site but could not find the oversize valve stems(very interesting but 144 page catalog!). Any idea where they show up? This oversize stem might allow me to run MTDR's on this set of(drilled out) wheels. Thanks -Jim
  #52
Old 03-31-2007, 11:21 AM
mchell's Avatar
mchell mchell is offline
you can get .425 and .625 vavle stems at napa..............I may have the exact sizes wrong, but there are generally two sizes available.......
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
  #53
Old 03-31-2007, 02:13 PM
http://store.bobdrake.com/chromvalstem.html
or it sounds like napa might be the hot ticket.
  #54
Old 03-31-2007, 09:45 PM
Probably drill the rims tomorrow.
May be buying a pair of metal valvestems from Drake ($2.50x2) or NAPA...will check ADV Auto for their Made in Canada I mean China offering.
Probably go tubeless.
Has anyone tried the balloon in a balloon experiment?....
  #55
Old 03-31-2007, 11:13 PM
mchell's Avatar
the exact valve stem sizes usually on the shelf at NAPA are .453 and .625.......
