Old 07-23-2007, 11:58 PM
BradZZ BradZZ is offline
Question Frt Drive mtr & trans swap
This maybe an odd question for this forum
I have a wrecked 90 Chevy Cavilier with a good 4 cyl and 5 spd trans
(Runs Great Still)
what Pontiacs will this combo fit into. Sunbird ?
Can I make it fit a 88-94 Grand Prix?
Old 07-24-2007, 08:08 PM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
Sunbird Yes.
GP probably not.
Old 07-29-2007, 09:05 AM
Default which years interchange
Which Sunbird years interchange with the 1990 cavilier
Does the Grand Am use the same drivetrain
or
the Chevy Corsica/Barretta
Old 07-31-2007, 09:47 AM
Mr_GTO's Avatar
or
Same years Sunbird. Not sure about the other cars.
Old 08-01-2007, 07:18 AM
fellro fellro is offline
Sunbirds swap quite well with Cavvies, but be aware of trans differences. If you have a 1.8 or 2.0, the trans is different than the 2.2. As long as they are the same, as in auto to auto, then everything else hooks up. Unplug the harness from the Cavvie, and switch the computer too, and you are set. Grand Am is similar as well, but I would avoid the Quad 4's due to reliability issues. You can even go V6 if you want, from a Z24, or Skylark with the Buick V6. I had wanted to take a 3.8 and put in my old Sunbird, but never got around to it. The 3.3 is a little brother to the 3.8, all the mounts would work.
71 Lemans T37- waiting to be worked on...
83 T/A, 305 auto, rear disc
Old 08-05-2007, 09:58 AM
Default powerplant swap
Thanks for the info
Ive got a 2.0 and 5 spd it looks like another cav or a sunbird are really my best options.
and I really want to keep the 5 spd (makes a little car a lot quicker and fun)
If I understand the wiring harness is the same between 2.0 and 2.2
I just need to switch the eng and computer?
Old 08-05-2007, 11:20 PM
It depends which 2.0 you have, there is one that looks list like the 2.2, then there is the overhead cammer, different beast altogether. If you have the overhead cam 2.0, you can't use it on the 2.2, the starter mounts on the firewall side vs. on the front side on the 2.2. Personally, I won't mess with the 2.0 any more. Too much of a pain to work on.
