Old 11-01-2007, 10:46 PM
yak's Avatar
yak yak is offline
Default engine painting advice
i'm painting up my 1970 400 short block with some factory match plastikote paint at this point while waiting for my edelbrock heads and valvetrain and intake to come from sd performance..... i just need advice on if i should paint the e-heads and intake blue as well or leave them natural.... is there clear coat i can put on them to keep them nice or?
i like the look of just leaving the top end natural aluminum looking but i'm thinking if i paint them it might look a little more like a factory raiv motor ..... what do the experts recommend?
Old 11-02-2007, 12:07 AM
azbirds's Avatar
azbirds azbirds is offline
I removed the name and painted mine, looks stock to the non-Pontiac crowd. I wish they would have fixed the oil drain back problem.
Old 11-02-2007, 06:43 AM
smagnotti smagnotti is offline
If you use tall spring cups on the rear intake and exh valve in each head, the oil contamination problem is solved.
Your spring seats my need to be cut to use them with your springs.
SJM
Old 11-02-2007, 11:44 AM
yak's Avatar
yak yak is offline
what oil drain back problem? do you just sand the edelbrock name off?
Old 11-02-2007, 09:25 PM
Dan Linebarger's Avatar
Dan Linebarger Dan Linebarger is offline
Default painted heads
I've recently done exactly what you are thinking. Complete with Ram Air IV intake.
The engine is back in the car and I'm pleased with how it looks. The body shop shot clear coat on everything.
The Heads made a huge difference. My stock "13" heads flowed 190 cfm, compared to 290 with the new heads. Butler designed the hyd. roller cam, heads etc.
Men feel younger by driving old muscle cars.
Women feel younger by doing a little "nip and tuck".
Both are expensive and darn well worth it!
Old 11-02-2007, 11:29 PM
Redta's Avatar
Redta Redta is offline
Dan--Did you have any issues with the roller lifters hitting that valley pan?
Old 11-03-2007, 02:13 PM
Default pan
No problem with the pan, but the lifters did tap the valve cover oil speaders.
We just bent the small spreaders closer to the inside of the cover and all is good.
With a roller motor, it will red line real fast. I highly recommend a rev limiter.
Old 11-04-2007, 07:42 PM
yak's Avatar
yak yak is offline
geez you know that does look pretty nice too with it all painted up, i'm still undecided what to do yet.... i'm thinkin if i was goin to run original looking raiv exhaust manifolds i'd paint the whole engine but since i'm goin to be running ceramic coated headers i might leave the heads and intake not painted cause it might look better....
Old 11-04-2007, 11:09 PM
Default looks
Here is a picture of stock heads painted and clear coated, with RA II ceramic silver coated exhaust.
Edelbrock heads run cooler and the paint lasts longer.
Old 11-17-2007, 04:39 PM
yak's Avatar
yak yak is offline
this is what i ended up doin....
Old 11-17-2007, 05:22 PM
Default nice
The motor looks good! My paint is still on the heads, but is starting to turn a bit yellow.
Old 11-18-2007, 10:47 AM
mysticmissle's Avatar
Steve Mag> how are you, ron says you still are porting heads on the side, thats gr8. which spring cups do you recomend, i am pretty sure thats a problem i need to rectify on my eheads. thanks JeffR>
Old 11-22-2007, 07:45 AM
Default steve magnotti look here :)
hey steve, do you happen to have a part number for the taller spring cups? how much taller are they .250? i have been battling a highrpm detonation problem that i think is oil contamination but havent been able to verify, so i d like to try this. thanks Jeff
