Old 11-13-2007, 08:30 PM
LawnJockey's Avatar
LawnJockey LawnJockey is offline
Default 68 Rag top need to Raise Rear
Springs and shocks all new but rear seems lower than front end. Also new headers bottom out a little
I didnt want to use air shocks. Are there any other rear shocks to raise rear? I found some Monroe 58574 Sensa-Trac Load Adjustable Shocks. Are they any good?
LJ
Old 11-13-2007, 09:50 PM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
I would put air bags in the springs before I used air shocks.
Old 11-13-2007, 11:24 PM
Bill Eveland's Avatar
No non-air shock will raise the suspension other than a coil-over shock, replacing the rear springs would be the best repair.
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 11-14-2007, 07:10 AM
amcmike's Avatar
amcmike amcmike is offline
Or you could lower the front.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
Old 11-14-2007, 10:30 AM
rotdog rotdog is offline
Got the same thing on my 65. Would it matter what the height was when u tighten control arm's?? I waz backed up on ramps.
Old 11-14-2007, 10:33 AM
David Jones's Avatar
The cars sat down slightly in the butt end when they were new. How bad is yours?
Old 11-14-2007, 05:50 PM
LawnJockey's Avatar
It looks abnormally low, I just ordered air bags that inflate inside the rear coil springs. The odd thing is I have replaced all suspension parts
Thanks for the responses
LJ
Old 11-14-2007, 07:14 PM
Murf Murf is offline
How bout some coil spring spacers? The ones that go under the spring, not the twist in type.
Murf
Old 11-14-2007, 08:24 PM
LawnJockey's Avatar
I used the 2.25 or 2.5" spacers they dont supply enough height
LJ
Old 11-14-2007, 09:00 PM
surfnuke9's Avatar
surfnuke9 surfnuke9 is offline
If you used 2.25" spacers and the rear wasnt higher than the front, something is very wrong with your new springs.
I am fairly certain that on the 68, there was only about 1/2" diference between the rocker to ground measurement front to rear with the rear being lower.
Old 11-15-2007, 01:28 PM
Is the frame to ground measurement the same f & r , or are you just looking at the body measurments?
6.27@107
9.97@131
Old 11-15-2007, 05:57 PM
6704gto's Avatar
6704gto 6704gto is offline
try heavy duty springs if you what to raise the car
Old 11-15-2007, 06:13 PM
LawnJockey's Avatar
I'll look into it
LJ
Old 11-16-2007, 09:50 AM
figure out where you want the car to sit in regards to the oem ride hieght and then call coil spring specialties and have them wind up a set of springs to suit your needs. the cost is slightly higher than stock units and i've never had a failure with their products. they'll also change rates if you want to stiffen it up a bit.
mike
former." --Albert Einstein
- Winston Churchill
