Old 11-19-2007, 06:53 PM
CMill421 CMill421 is offline
Default Rear suspension parts
Looking for a good rear control arm bushing retailer, any recomendations?
Also just noticed ram air retorations has new upper control arms, has anyone used these?
CMill
Old 11-19-2007, 07:29 PM
60man's Avatar
60man 60man is offline
Our host PY probably has stock replacement bushings...
You can also try Kanter Auto or get some Poly/graphite ones from PST.
At leats I got front lower control poly bushings for my 60 from PST ...
Going to try for rears next....
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 11-20-2007, 08:35 PM
64catdroptop's Avatar
64catdroptop 64catdroptop is offline
CMill,
You have a PM
Never trust anything that bleeds for five days and won't die.
Old 11-20-2007, 08:46 PM
PITTSBURGH 64 PITTSBURGH 64 is offline
Ram Air Resto sells all four rear control arms. I have there uppers with one of the last sets of Indian Adventures lowers made.
Buy the Ram Air Resto units and be done with it. I went all through boxing, replacing bushings, then trying to tack in the loose (junk) bushings Kanter sold me for my stock control arms. Then having my car torque steer because of weak rear control arms!
Buy the Ram Airs...........................
http://www.ramairrestoration.com/catalog/
Old 11-20-2007, 11:08 PM
66bonne's Avatar
66bonne 66bonne is offline
I'm with 60man - Performance Suspension Technology urethane bushings are the way to go.
Old 11-21-2007, 12:06 AM
summit racing and pst bushings in my 65 g/p. so far i love them, it's been about 7k since the install.
mike
former." --Albert Einstein
- Winston Churchill
Old 11-21-2007, 12:53 PM
63pontiacgp's Avatar
63pontiacgp 63pontiacgp is offline
I put the upper and lowers from RamAir on mine and it made a world of difference in the ride.
Mike
Old 11-21-2007, 05:10 PM
Fat Cat's Avatar
Fat Cat Fat Cat is offline
Got my polyurethane rear bushings from Ames. Not sure if PY sells them or not. I also had BOP Engineering make me a set of custom upper adjustable and lower tubular control arms. I didn't know that RamAir had them available...
"A bend in the road isn't the end of the road unless you fail to make the turn."
Old 11-21-2007, 08:25 PM
warriors revenge warriors revenge is offline
Send a message via Yahoo to warriors revenge
take a look at the ones i make on my website, www.xtremefabrication.com they are made from 4130 Chrome Moly, have H.D. CrMo rod ends, and AL bushings W/CrMo sleeves
kal
262-968-2514
Old 11-27-2007, 11:17 PM
Kal,
Are those lowers for a 66? If so how much?
