Old 01-11-2008, 05:44 PM
Brian jones Brian jones is offline
Default Best after market stock type exhasut system
I need to buy all new exhaust for my 64 gto convertible. I see A-body systems are available from Flow-Master and Pypes. Can anyone make a recomendasion as to what is the best set up to go with.
Thanks,
Brian
Old 01-11-2008, 10:17 PM
Flatfish Flatfish is offline
We are finishing up the off-frame resto on my 64 GTO Tripower Convertible, and after a lot of research we came up with the following exhaust system components, many of which were purchased from the forums host Performance Years. It is not a stock system, but it should last forever and should sound good: 2.5" stainless downpipes, Pypes SGA30 kit (2.5" stainless downpipe extensions and 2.5" tail pipes), stainless 2.5" exhaust splitters, and of course all associated flanges, clamps and hangers. We picked the Dynomax 2.5" Ultraflow long case mufflers in stainless. You can save a couple of hundred by getting the Ultraflows in welded steel. I like the deep tone of the straight thru mufflers as opposed to the chambered mufflers. The CD Silent Power, available through PY, can help you choose a muffler sound that you like. The whole package was espensive, but after going thru the off frame restoration, you kind of get numb to it. We ordered the mufflers from JEGS. It has not been bolted on yet, but we are looking forward to firing it up. Hope this helps. Walt.
64 GTO Tri-Power Convertible, 4-spd
2nd owner, since December 1965
Old 01-11-2008, 11:59 PM
jarhead's Avatar
jarhead jarhead is offline
If your looking for a system that's close to original including the correct hangers, I went with the system offered by Gardner - http://www.gardnerexhaust.com/homepage.html
If you go to my web site you can hear what it sounds like - http://www.geocities.com/mm5581/index.htm
More pictures of my former Goat:
http://www.barrett-jackson.com/appli.../w_search.aspx
My old car is listed in the 2007 Scottsdale Auction, Lot #1016 - $60K
And in the 2008 Scottsdale auction, Lot #960 - $80K
Eventually sold by Brighton Motor Sports in Scottsdale, AZ -$89,900
Old 01-12-2008, 12:28 AM
lil64gto lil64gto is offline
Brian,
If you are looking for a stock system, Jarhead is correct the only choice is to go with a Gardner Exhaust.
If you looking for something with a little more performance then look into a pypes or flowmaster set up. I went with the flowmaster 2.5 with Super Turbo mufflers.
You just need to make the choice as to what you want.
Good luck
Jim
Old 01-12-2008, 12:47 AM
aceaceca's Avatar
aceaceca aceaceca is offline
I got mine from Ames. All stock, bolted right on. About $300 for 2 head pipes, 2 mufflers, and 2 tail pipes. All the others were ridiculously priced in my opinion. This was for a 1965 but I think 64 is same. Check it out.
Old 01-13-2008, 05:03 PM
Dick Boneske's Avatar
If you don't need to be absolutely "correct", the '67 GTO D port manifolds bolt on and fit the chassis perfectly. They look like factory manifolds and add nicely to HP. with whatever engine you have. As a bonus, headpipes, mufflers, and tailpipes from the '67 will fit if your exhaust guy has the program for his bender. Midas and others around here do have the info for this. I like that better than ordering from a vendor far away.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 01-17-2008, 04:46 PM
som2002's Avatar
som2002 som2002 is offline
Send a message via AIM to som2002
The local Midas just did my a system for my Dad's 64. They ordered him a 2 -1/2" kit from Dynomax, which they are a dealer of, and installed it there for him in just a few hours. Plus if there are any issues with it they stand behind it and do all the re-work for free. Sounded like alot better deal than the Flowmaster kit I bought a month earlier for my 62 SS for more money, that I still had to do myself, with NO warranty. Just a option maybe you hadn't thought of.
www.fquick.com/som2002
