Old 02-07-2008, 07:05 PM
steve's Avatar
steve steve is offline
Default what is that thing called in the rear of my crank ?
sure, it is some sort of bearing for the input shaft of my muncie. i have an auto motor that i need to mate with a manual trans.....what is the "insert" in the crank called ? my new clutch kit did not come with one and i need to tell the local parts guy what i need......
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-3:55 Moser rear-Dougs Headers....
Old 02-07-2008, 07:07 PM
limejudge69's Avatar
pilot bearing
Old 02-07-2008, 07:10 PM
mike hayes mike hayes is offline
Hopefully you have a crank that a pilot bearing will fit in, I had to get a brass pilot bearing and turn it down to fit in the crank of a 1967 400.
Mike
Old 02-07-2008, 07:14 PM
steve's Avatar
thanks guys...it looks as if it will fit fine. i thought about trying to remove my old one and swap it over to the new motor....guess that is a bad idea ? is the bearing different than the "housing" it rides in ? are they two different part numbers ??
Old 02-07-2008, 07:43 PM
Kyflier Kyflier is offline
Pack grease in the old one, stick a pilot snout in it and hit firmly with a light hammer, it'll hydraulic itself out to be installed in the new motor. Better yet, buy new one, tap it in place and you'll have one in both cranks
Kenny
Cincinnati, Oh
1971 Ventura II
400 .060 Eagle Rods
Old 02-07-2008, 08:59 PM
BB1968's Avatar
BB1968 BB1968 is offline
I agree with KYflier buy a new one. They aren't that expensive. The do make a bushing and a bearing for this purpose I believe. Either one will work...BB
Old 02-07-2008, 09:47 PM
Keep in mind if you use the bearing instead of the bushing that the bellhousing alignment needs to be closer/tighter. This has an effect on shift quality and trans life. In my experience the bushing works fine, and no real advantage over using the bearing.
Old 02-07-2008, 11:36 PM
steve's Avatar
am i in trouble ? i need the rusty/silver one to be like the oily/dirty one.....
ID:	121738   Click image for larger version
Old 02-07-2008, 11:52 PM
i82much's Avatar
i82much i82much is offline
Sometimes the titles of these threads are absolutely priceless.
Old 02-08-2008, 12:05 AM
steve's Avatar
Old 02-08-2008, 01:27 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Its called the base
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 02-08-2008, 07:49 AM
No, your fine, the one on the left just doesn't have a pilot bearing/bushing in it. The one on the right has a pilot bearing in it.
Old 02-08-2008, 11:07 AM
boater bill's Avatar
boater bill boater bill is offline
Since the pic on the right shows a bearing instead of a bushing, I wouldn't try to remove it. Just get a new one and install in your "new" crank.
Every time I've tried to remove a pilot bearing it has come apart and was useless.You can remove a bushing with the method KYflier recommended.
Good luck!
Old 02-08-2008, 11:44 AM
steve's Avatar
thanks guys the new one was $30.00 ! but it looks like a much better unit than the brass "bushing"....fed mogul part #7109
