Old 03-26-2008, 12:07 PM
TxGoat TxGoat is offline
Default Which Rhoads lifter to use?
To those out there using Rhoads lifters - Which one should I use, the original or V-Max?
I am using a Crower 60919 cam with 1.65 ratio PRW aluminum roller rockers in a 455.
Thanks.
Old 03-27-2008, 09:25 AM
Murf'sDad's Avatar
Murf'sDad Murf'sDad is offline
Thanks.
I don't run either one but I've read that the V-Max are not as good as the originals. Appears that the V-Max are very similar to "other" brands which aren't as noisy and don't work, jsut like the other brands. Stick with the originals.
JMO, Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi.
“Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill
Old 03-27-2008, 11:09 AM
wheelspin's Avatar
Thumbs up V-max is my choice..............
I have extensive use/mileage w/ both conventional & V-Max style Rhoads lifters in my three Pontiacs, and I recommend the V-Max for their additional adjustability and their "cool face" type oiling groove. The newer V-Max lifters offer the same top quality construction as the originals PLUS the ability to adjust the lash for more/less vacuum/noise. I suggest cast v-covers for those that don't favor the solid cam tone.
Les
Les Iden
Old 03-27-2008, 11:22 AM
70lemansport's Avatar
70lemansport 70lemansport is offline
Not to pirate this thread but on a "way more than stock cam" motor do the rhoads lifters really give back your low end?
Old 03-27-2008, 11:47 AM
71 Ventura II's Avatar
71 Ventura II 71 Ventura II is offline
Thanks.
The original version have a long track history of success. With that said, the person who promted the Rhoads lifter movement switched to the V-Max lifters before they were even advertised. The best person to ask about the benefits of each would be to send a PM to Jim Hand himself.
Personally, I like the "Idea" of the V-Max lifter bacause you gain more control over your adjustments and lifter pump up. In laymans terms, the V-Max is like having a middle to choose from giving you some of the benefits of the solid lifter with the low maintenance of a hydraulic. Off topic, Pontiac used a "Limited" travel lifter on the Ram Air 4 engines a long time ago. Good luck! JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
Old 03-28-2008, 12:28 AM
440GP69's Avatar
440GP69 440GP69 is offline
Yes the rhoads work!!! WAY better low end and vaccume but i still don't like the sound, to me it's lowder than any sollid cam i've heard, but i never used cast v-covers, also if you really want to tame the ra4 cam then use the v-max's, but personally i'd go with the originals
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
Old 03-28-2008, 11:02 PM
old66tiger's Avatar
old66tiger old66tiger is offline
I used them on my 389 and it was nice to have some adjustability/.
Skinned knuckles and empty wallet! Could I be any happier?
66 GTO Convertible. LS3-525 HP. Legend LGT700 5-speed, Wilwood 4-wheel disc brakes, Ridetech coil over front susp, PMT rear susp, Hotchkis bars, Billet Specialties 18" Dagger's (18X9 rear, 18X8 front).
2002 Ram Air WS.6 convertible Trans Am. Wife's car.
Old 03-28-2008, 11:30 PM
lust4speed's Avatar
Les talked us into running them in our 2+2 and I have nothing but good to say about the V-Max. We are also running the Crower 60919 cam, 1.65 rockers and V-Max lifters with the Super Lube option. 15 Inches of vacuum and much more torque than we had before in the 421. Unless the hood is up, they are difficult to hear (we also are running heavy aluminum valve covers). The little bit of clatter that is present is very consistent and even - which actually sounds good to me.
Mick Batson
Old 03-29-2008, 09:25 AM
PITTSBURGH 64 PITTSBURGH 64 is offline
Mick do you have them lashed at the loose end or the tight end?
I have the 60919/original Rhoads in my 462 and I'd like a little more cam to come on at low rpm.
With the hydro my first gear is 3.97 and very deep even with the 2.56 posi.
The ticking grew on my too.
http://www.youtube.com/watch?v=wTaoSj7taKs
Old 03-29-2008, 11:53 PM
lust4speed's Avatar
Rhoads lists the range from .010" to .030" and we picked the middle of the road and set them at .020" and we have over 15" of vacuum. I was thinking of dropping down to .010" and dropping the torque off a bit since we are now blowing the stock tires away on the 2+2. If the power came on just a tad later I think it would just hook and go. I just haven't had the time to play with it to see what we like better.
Mick Batson
Old 03-30-2008, 08:55 AM
Thanks for the info Mick.
Old 03-31-2008, 07:27 PM
Thanks for all the good information.
Old 04-01-2008, 04:19 PM
greyno3's Avatar
greyno3 greyno3 is offline
So which V-Max lifters are the better choice, 9518x or the 9518XL with the patented groove down the entire length of the lifter body?
10C 1972 Formula 461 non A/C
08B 1969 GP J/428 non A/C
Old 04-01-2008, 10:16 PM
wheelspin's Avatar
Thumbs up Rhoads version of "cool face" lifters..........
Use the XL type Rhoads as the side groove provides extra oiling @ the lifter/lobe interface.
Les
Les Iden
