Old 06-04-2008, 07:42 PM
Brian Baker's Avatar
Originally Posted by Drunk'nInjun
Brian, you know the Hemi's .....like a 526ci KB runs a 4.310 bore, 4.50 stroke and spin to 9600rpm. I'll grant you, they have a better oiling system but its still a proven bore/stroke combo.
You're talking alcohol, not nitromethane. NHRA rules dictate a 500-CI max and nobody in the nostalgia fuel ranks is running anything that big due to rules constraints as well.
  #182
Old 06-04-2008, 07:43 PM
Quote by Lynn:
"An engine with Tiger/KRE heads, IA/KRE block, bryant/crower/Asian crank, dominator carbs, BOP/Tiger/KRE manifolds, 4.40 bore, some crazy kind of stroke, and you guys call it a Pontiac motor? Billet heads?
Maybe we should call it a newly improved facsimile of a Pontiac motor on Steroids?"
Well Lynn there was a guy who set a few records at Bonneville and other places. He cast up his own blocks, made his own heads, put in 4.5" cranks, made his own injection and blower manifolds, made his own pistons and rods, valvetrain, camshafts, etc. Everyone considers his stuff to be PONTIAC PARTS. I think his name was Thompson.
Quote by Eric:
"IAII block
4.500 stroke
4.250 bore
billet heads...our own design based on Ram Air V
approx. 6:1 compression
14-71
80-90% nitro
MSD Pro Mag 44
Crowerglide
2-speed Lenco"
Should be a great combo Eric!!
  #183
Old 06-04-2008, 07:57 PM
440GP69's Avatar
440GP69 440GP69 is offline
Actually top fuel HEMIS are using long arms! most are in between 4.185-4.205 bore and use 4.50 Stroke very similer to a stroker pontiac, the small bore is used because of the extreme heat and stresses, also allows more meat in between cyl walls.
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
  #184
Old 06-04-2008, 08:01 PM
Typical topfuel bore/stroke is 4.187/4.50= 500ci
  #185
Old 06-04-2008, 08:36 PM
Hmmmm, I thought the 4-3/8" crank was still used.
  #186
Old 06-04-2008, 08:38 PM
Elarson's Avatar
Elarson Elarson is offline
The primary motivation for the 4.500 stroke is that we own (3) good 4.500 cranks and we have been assured by our experienced nitro advisors that a blown nitro engine will not care much about B/S and R/S ratios. The 4.500 stroke will spin happily to 8000 rpm in our nitrous engine and we may not need to wind the nitro combnation that tight.
Our claim to the Pontiac heritage is retention of stock bore spacing, head bolt pattern and valve cover pattern.
Should be an incredible ride...........it can't be done soon enough.
Eric
  #187
Old 06-04-2008, 10:15 PM
Elarson's Avatar
This thread has gotten completly off the original topic. Maybe that's a good thing?
Eric
  #188
Old 06-04-2008, 10:33 PM
Eric
I've seen worse hijackings.
  #189
Old 06-05-2008, 12:23 AM
chief455's Avatar
chief455 chief455 is offline
I take every opportunity to voice my same opinion on this.
While this thread is about something else, I agree - we might as well call it a Chevy - they have Donovan blocks, Dart heads, China iinternals, etc and still are "Chevy"?
This is just Pontiac brand loyalty with a big aftermarket budget.
Carry on......
  #190
Old 06-05-2008, 12:37 AM
NHRASuperStock455SD's Avatar
NHRASuperStock455SD NHRASuperStock455SD is offline
Send a message via AIM to NHRASuperStock455SD
Not everyone Particularly guys who run all mostly OEM castings
Lynn
  #191
Old 06-05-2008, 07:31 AM
Oh, come on, Lynn...the aftermarket blocks out there will take any factory part, why wouldn't they be a Pontiac? You talk of stroke, well...NHRA Super Stock rules allow for increases in stroke, albeit they are minute...longer stroke no longer make it a Pontiac? We respect you SS guys for running hard with factory parts...why the disrespect for guys that run even harder with aftermarket parts?
  #192
Old 06-05-2008, 08:23 AM
Elarson's Avatar
Super Stock engines have non-factory parts in them. Everybody choses their own point to draw the line. I can't really see that there is a black & white answer to this debate.
Let me propose this test for the Pontiac fans: When we get the Boss Bird done, I'll lift the body for you. If you feel happier that it is a Pontiac facsimile engine instead of a Chrysler hemi facsimile, then it qualifies as a Pontiac. Agreed?
Eric
  #193
Old 06-05-2008, 12:36 PM
Oh, come on, Lynn...the after market blocks out there will take any factory part, why wouldn't they be a Pontiac? You talk of stroke, well...NHRA Super Stock rules allow for increases in stroke, albeit they are minute...longer stroke no longer make it a Pontiac? We respect you SS guys for running hard with factory parts...why the disrespect for guys that run even harder with after market parts?
No disrespect intended. You must acknowledge the difference between aftermarket stuff and real Pontiac stuff. I love the aftermarket stuff. But, let us call it what it really is.
John Langer is doing a great job with a terrific engine builder. I support him 100%.
Lynn
  #194
Old 06-05-2008, 01:44 PM
Eric
I support you guys 100%. However, I think you guys get the point between an OEM casting and a Billet alum head motor.
Lynn
  #195
Old 06-05-2008, 01:57 PM
Elarson's Avatar
Lynn
Understood.........and I really feel good about the fact that so many people are trying so many different things with Pontiacs.
Eric
  #196
Old 06-07-2008, 03:22 PM
Dragncar Dragncar is offline
If someone reproduced the entire 1970 SOHC 427 Pontiac Hemi engine would you call it a Pontiac or some sort of a custom race engine.
I would call it a Pontiac,its based on a Pontiac.Hell that thing was a factory Pontiac and it was more advanced than some full custom race engines.
We have devolved.
What could have been.The big dogs are still playing around with pushrod engines and that thing was around in 1970.
Make it again and the tables are turned.
