Old 07-09-2008, 10:43 PM
goldbird*12.82 goldbird*12.82 is offline
Send a message via AIM to goldbird*12.82
Default what is the N on the crank mean?
frist of all i am 16 and this is my first pontiac motor with no car.
its a 350 got it for free here some pic
on my intake where is the date code?
ID:	135832   Click image for larger version
ID:	135833   Click image for larger version
Old 07-09-2008, 10:58 PM
gregneun gregneun is offline
Default N is for North
Always install the crank with the N pointing to the Magnetic North Pole.
OK, I'm done "bustin' your chops".
I think it stands for Nodular, but I would wait for the more knowledgeable on this.
Good luck with it,
Greg
Old 07-09-2008, 11:02 PM
Tiberius Tiberius is offline
Yes "N" is the designation for Nodular Iron Crank..
Pontiac made their cranks ready for severe duty.
It's a good one
Old 07-09-2008, 11:11 PM
thanks , for that that helps alot
Old 07-10-2008, 07:39 AM
cnc's Avatar
cnc cnc is offline
R u sure its a 350 .....?? it should be stamped in the lifter bore area and or the side of the block too I believe ....
I'm not sure but I thought only 389 and up came with N cranks and or windage tray ...someone else chime in here and let us know....
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 07-10-2008, 07:52 AM
cnc it said 350 on the side of the block were else do i look for the # on the crank
Old 07-10-2008, 08:22 AM
cressy cressy is offline
I have a crank out of a 1970 350 2 barrel engine and it has the N on it.
Old 07-10-2008, 08:25 AM
SWEETJUDGE's Avatar
SWEETJUDGE SWEETJUDGE is offline
389 cranks & ram air IV cranks are ARMA STEEL (much better) than NODULAR.
all pontiac cranks are nodular except noted above.
all or MOST pontiac blocks will have the last 2 digits cast in the valley of the motor
00 = 400 55= 455 28= 428 and so on... some are also cast into the sides of the blocks aswell.....
Heres a good tip MOST all of large journel blocks have a pyramid near the dist. THIS IS A STREET RACING TRICK... if you cant tell what the block is look for the pyramid. NOW the street racers know this & is very common for people to hack that off to appear to be a smaller motor
1969 Early 01D JUDGE #s MATCH RA III 4 Spd (Concours Restored)
1969 PRO STREET GTO 2500 lbs. ALL ALUMINUM 505
1969 RARE All Glass GTO (FOR SALE) YOU NEED THIS
AC Cobra Kit Car 521 670 HP/715 Trq
LOOKING FOR V PARTS !!!!!!!!!!!!
Old 07-10-2008, 08:26 AM
SWEETJUDGE's Avatar
date code is usually near the water outlet but that intake looks late to me but i dont look at many 350s.....
Old 07-10-2008, 09:15 AM
67drake's Avatar
67drake 67drake is online now
Is there a way to I.D. the arma steel cranks?
I have a local guy who wants to swap me some Pontiac parts for some of my old Chevy parts. One of the items he claims to have is an arma steel crank.
‘55 Catalina
Old 07-10-2008, 10:55 AM
440GP69's Avatar
440GP69 440GP69 is offline
ive seen N cranks take a LOT of punishment i don't think there is that much different between the PM,AL,and N cranks they all are pretty tuff and can take any kind of normal abuse as well as some ab normal abuse LOL
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
Old 07-10-2008, 05:30 PM
x-bird2 x-bird2 is offline
actually, the 67-later Nodular iron cranks are better/stronger than the armasteel. arma steel was only a "brand" name so to speak and they are cast iron, not steel as many people think. arma steel name and iron type was dropped due to fear of misrepresentation claims and pearlitic nodular replaced it. i'll find all the arma steelcranks u want and trade you straight up for any 67-later nodulars you have.
Old 07-10-2008, 06:56 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Sweet Judge,
The valley 2 digit castings didnt begin until 1969 and the pyramid is on all 421-455 blocks as well as the 326's and 350's. Only the 389-400 's had no pyramid.
And yes as mentioned above "Arma Steel" is cast and no better than an "N" crank.
What this young man has is a 70-74 350 (dual - early/late motor mount holes "5" holes on all 70-76 engines) , windage trays ended after 74 (mostly 73) , 75-78 blocks are not drilled for a windage tray at all.
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
Old 07-10-2008, 10:02 PM
thanks for all the info
