Old 11-20-2008, 11:34 AM
MarkJ MarkJ is offline
Default 1970 Lemans daily driver for sale
1970 PONTIAC LEMANS, 350/auto, 2bbl, ps/pb, air conditioning (complete system, but bad compressor), Original Numbers matching motor 107k miles (no hot rod parts installed, stock). Limited slip rear, dual exhaust, rally II wheel, rear tires good, front tires ok. Car has nice original black bench seat interior. Dash radio area was cut by previous owner for aftermarket radio. Original AM radio was reinstalled. Original color 55 Baja Gold Metallic with Black vinyl top. Paint is original, so it looks rough after 38 years! Car was recently hit/bumped on diver side door and fender. Rust in usual spots, lower fenders, lower quarters, rear window corners, area where trunk meets inner fender wells. Car is driven daily and PA inspected until 6/09. Asking $6,000 obo. These cars are getting harder, even a daily driver like this one! No phone calls please, email only & I can take pictures for serious inquires. I’ll try to post pictures here.
Old 09-20-2009, 09:04 AM
Exclamation
Update:
This car is again up for sale.
I had to move at the beginning of summer, so the car was placed in outside storage at the end of June 09.
PLEASE BE AWARE: Although the car was covered, moisture leaked in and was trapped inside the car. The interior is now inundated with MOLD! I tried to clean some of it out, but it is “everywhere” (dash, headliner, carpet, seats, and seat belts). Expect to complete gut the interior if you are planning on buying this car for a daily driver.
The car did NOT pass PA state inspection in June 09 for the following reasons:
Needs 4 tires (dry rotted, and front are worn).
Needs exhaust (pin holes in tailpipe, but whole system will need to be replace because of rust).
Leaking left wheel cylinder (FIXED, both cylinders replaced along with new rear brake hardware, shoes, flexible brake line and master cylinder.)
The car is drivable, complete and original.
Have some extra small parts (including all A/C parts) that will go with the car, but no sheet metal
Yes, I can take pictures and will try to post them here.
Please do not email me unless you are seriously interested!
Old 11-26-2010, 11:31 AM
Update:
Best offer!
Started work on it, but do not have the time or money. Car has clean title and can be started, but is not drivable (front brakes lines and calipers are off and need to be replaced). Car is safe to trailer or tow.
Photos are up in my album “70 Lemans Gold w/Black top”.
email @ [email protected] or send pm.
