Old 03-30-2009, 06:25 PM
gkinch's Avatar
gkinch gkinch is offline
Default Aftermarket shifter for Trans Am ?
I have broken the factory shifter in my 79 TA .Which of the 3 aftermarket shifters works the best? The Quicksilver ,mega shifter or the hurst V-matic.I want to keep the factory console !
thanks gene
Old 03-30-2009, 06:36 PM
GREATGTO's Avatar
GREATGTO GREATGTO is offline
I prefer the quicksilver, a lot of my frinds have it in their t/a's ,they sell one that fits the factory console really nice
Old 03-31-2009, 09:59 AM
OrigOwner77's Avatar
OrigOwner77 OrigOwner77 is offline
+1 for the QuickSilver...have it in the '77 and love it.
I have no experience w/the Hurst V-Matic II, but have heard that the B&M Megashifter is real sensitive to cable routing, else it gets stiff and feels like it binds or doesn't shift smoothly. Never heard that in regards to the QuickSilver though.
As far as installs go, the MegaShifter is the ONLY drop-in-and-go shifter. The QuickSilver needs the hole where the shift cable runs through the floor elongated, and the V-Matic II needs a new hole entirely drilled. This is to get the correct shift cable geometry and such for proper operation (probably so you don't snap the shift cable).
I don't know about the V-Matic II, but the MegaShifter *I believe* comes with microswitches for reverse lights and neutral safety switch hookups, whereas the QuickSilver does NOT. This is only relevant if your stock backdrive linkage is disonnected, however.
Like Father, Like Son.
Dad's car: 1977 Trans Am: Original Owner, T/A 6.6 400, modified TH350, Hooker Headers, Flowmasters, Edelbrock Performer Intake, Holley 750 cfm carb, 3.91 rear end
My car: 1980 Trans Am: 1968 400, 1969 #62 heads, TH400, Hedman Headers, Flowmasters, Edelbrock Performer Intake, Holley 750 cfm carb, 3.42 rear end
Old 03-31-2009, 04:55 PM
gkinch's Avatar
Thanks for the input,I ordered a quicksilver today!
gene
Old 03-31-2009, 11:24 PM
gene
Sweet! Now send a couple hundred extra bucks my way so I can throw one in my 80 T/A!
Hope ya like the shifter!
Old 04-03-2009, 12:03 AM
Don 79 TA Don 79 TA is offline
ditto on the quick silver shifter
bolts in nicely
looks classy
works nice
yes.... even I at one time had an automatic in my TA
Old 04-04-2009, 02:45 AM
Colin's Avatar
Colin Colin is offline
Location: The ObamaNation we once called the United States of America
Guess I am the one guy that got a bad one. The Quicksilver I had was junk. Worked good for about a year. After that it was a PITA. Still worked when I sold the car but not well.
I liked it when it was new though.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."- General George Patton
"Perpetual peace is a futile dream."-General George Patton
"I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them."-Thomas Jefferson
"Any society that would give up a little liberty to gain a little security deserves neither and will loose both."-Benjamin Franklin
Old 04-10-2009, 12:39 AM
TransAm525 TransAm525 is offline
I've run the Hurst V-Matic II for two years now and wouldn't trade it for any other automatic shifter. One of the best features about the V-Matic II, other than the look, is the option of running it as a straight automatic shifter (pulling it into gear just like the stock shifter) for daily driving, or when in neutral, pushing it down into the ratchet mode for racing. To my knowledge, the V-Matic is the only shifter with both straight and full ratchet modes. The Hurst Dual Gate also offers two modes, but the [semi] ratchet function is only available for up-shifting, and works much like the stock shifter's ratchet mode. The V-Matic allows full ratchet up and down shifts, returning to a "neutral" position after each shift movement. Not only is the V-Matic a quality unit, it has a lighted gear selection indicator which can be wired into the stock shifter's original light socket wire--turning on with the other interior lights via the headlight switch.
OrigOwner77 made a good point about the neutral safety switch. The Firebird console V-Matic II does not have the switch. However, you can order the switch used on the universal V-Matic II through Summit Racing, part number HUU-2480021 and it bolts right on (requires some wiring). The Summit website doesn't say the switch fits the V-Matic, but the Hurst service parts page does. You can also retain your original neutral safety/back-up switch linkage assembly, but this may not be an option with some headers.
Old 04-13-2009, 03:33 PM
transamfan1981's Avatar
transamfan1981 transamfan1981 is offline
I had started a post like this. A guy told me he lost a trans due to a mega shifter. I was thinkin about that and thought that may have happened because the cable was longer than it should be and the cable lost the tension it should of had and it didn't pull the linkage into the next cog and blew the gear.
1981 trans am: 74 pont 350
1989 bronco: 302: R.I.P.
