Old 04-15-2009, 10:22 AM
h0trod389's Avatar
h0trod389 h0trod389 is offline
Default 1969 354 into a 78 t/a
wassap poncho freaks!
i was wondering what engine mounts are used to install a 1969 354 into a 78 t/a.
as of now, i have a set of 68-72 GTO, Tempest,Lemans rubber mounts bolted on the engine.
the engine is sitting in the engine compartment, but the lower mount hangs half way off the crossmember.
is there a bolt on solid mount i can use?
thanks for your help!
i had a chevy engine once, then i got a pontiac
Old 04-15-2009, 12:01 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
You need the motor mounts from a 1970-1979 Pontiac v8. But those are 3-bolt mounts and 1969 blocks aren't drilled and tapped for those extra 3 bolts, so you need adapters. Most of the local parts vendors (PY, Ames, etc) sell them. The fit isn't stellar and perfect, but it works.
Old 04-15-2009, 01:55 PM
h0trod389's Avatar
excellent!
105 a pair??!!!!??
jesus! there chargin alot now a days to drill 4 holes and tap 2!
off to the garage!
