The power windows no longer work on my 1977 Trans Am. I suspect I need to replace the power window motors. If anyone has replaced them, can you tell me where I can get replacement motors and if there are any tricks I should know before replacing them. Thanks.
78 Trans Am
The power window motors of this era are pretty durable units & I'd suggest you do some troubleshooting/circuit testing BEFORE condeming them.
It's really unlikely that both are dead. I'd suspect a burnt/unplugged wire or bad switch/relay first. If you pull your door panels you can put power & ground directly to the motors to test them. |
The switch is the most likely place. I would check there first -> use a multimeter to determine power and then jump the wires at the switch to see if they go up and down. I've never seen a relay go bad, but it's not unheard of either and it's a bit more work to get to and test. |
My 78's passenger side burned out 1 month after it's warranty.
I do doubt both went out. Look at the switch too they are pretty bad design and routinely go out.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Especially if you've dumped your soda or coffee in it!
Or if some knuckleheaded previous owner only liked to push the switch button halfway down. Causes arcs since it is a high current connection (never did understand that design decision) and leads to carbon buildup over time which causes the motors to go up and down slower and eventually stop working. Contact cleaner is your friend.
The contact design does look bad to me also.
Sometimes a good cleanup and new grease of the mechanism will work wonders, also backing up the felt blocks in the door will get it going again. Ofcourse if you dont hear anything, the suspect is mostly the console switch.
IF you decide to remove the motors - remove the glass and mechanism completely and BEFORE you unbolt the motor put vise grips on the mechanism or mark the positions thorougly. This has to do with the pre-tension of the spring in the mechanism. The vise-grip-trick makes replacement of the motor easy.
Greetings Frans |
Thanks to everyone that responded with your trouble shooting suggestions. It was the center console switch after all...
78 Trans Am
Agreed, Those switches are pretty crapy. Had a couple bad ones over the years.
I often wonder how much they would improve by taking the motors apart, cleaning & re-greasing the gears, & the window tracks. Seems the grease gets much thicker over time.
![]() 68 GTO 4-spd Convertible 78 S/E Trans am L78, WS6 Auto 78 S/E Trans am W72, WS6 Auto 79 10th aniv W72 Trans am 80 Indy pace car Trans am 89 Trans am GTA Last edited by 68ragtop; 05-15-2009 at 06:36 AM. |
