Old 07-10-2009, 10:11 AM
dean7276's Avatar
dean7276 dean7276 is offline
Default 78 TA newly rebuilt 400/TH350
1978 Pontiac Firebird Trans Am.400 cubic inch engine TH350 auto trans.both professionally rebuilt with 1500 miles since the rebuild.Posi rear with 3:42 gears.True dual exhaust with headers and crossover pipe.BF Goodrich tires on 15x8 (WS-6) snowflake rims.Brewster Green with Tan interior.Very solid car,passed Texas inspection.Runs and drives like new.I spent over $12,000 so far to get it to where it is now asking $7000. A paint job will complete this very reliable driver.
Following is a list of what was done to this car by me
1.Milodon water pump
2.High flow 160 degree T'stat
3.Temp. sending unit
4.rebuilt Q-jet carb
5.Brake proportioning valve
6.Stainless braided brake lines
7.Stage 8 locking header bolts
8.speedometer cable
9.motor mounts
10.trans mount
11.Hotchkis front coil springs
12.PST super poly front end rebuilt kit
13.Timing cover
14.Aluminum valley pan
15.Engine wiring harness
16.Polygraphite subframe/body bushings
17.full size spare
18.Bilstein shocks(front only)
19.Rebuilt TH350
20.brake vacuum booster
21.Jet hot coated headers
22.Powder coated frame/control arms/spindles
23. front end alignment
24.rebuilt 72 400 new pistons,rings,gaskets,cam bearings,rod and main bearings,oil pump,lifters,timing set,cam,3 angle valve job,valve guides.
25.stainless full brake line set
26.stainless trans cooler lines
27.aluminum radiator
28.brake calipers
29.Stainless steel fastener kit.complete kit for 78 TA (Totally Stainless)
30.Grant removable steering wheel (I have stock wheel in excellent shape)
31.subframe connectors (bolt on)
ID:	174353   Click image for larger version
ID:	174354   Click image for larger version
ID:	174355   Click image for larger version
ID:	174356   Click image for larger version
Name:	Trans am 2.jpeg
Brakes? Who needs brakes,they'll just slow you down!!
Old 07-10-2009, 04:27 PM
Paul Brezinski Paul Brezinski is offline
Nice Car !!! Any interior pics ???
Old 07-10-2009, 04:41 PM
dean7276's Avatar
Here's a few.Can take more if you like.Interior is in good shape.As you can see there is no heater control,prev.owner took all heating components out.
Grant removable steering wheel is installed but I have the stock wheel which is in very good shape.
ID:	174386   Click image for larger version
ID:	174387   Click image for larger version
Old 07-10-2009, 10:36 PM
thefirebirdm@n's Avatar
thefirebirdm@n thefirebirdm@n is offline
Send a message via MSN to thefirebirdm@n
Is the car a Firebird made into a TA or a real TA per the VIN? I ask because of the interior color set.
Jimmy
www.firebirdgallery.com
2002 WS6 M6 Trans Am - original owner
1973 Trans Am 455/4-speed
1971 Formula 400/400
1969 GTO 400/400 - 3rd owner
1968 Firebird Convertible 350/200R4
POCI - AAC
Old 07-11-2009, 10:08 AM
dean7276's Avatar
2W87Z8L148250
Old 07-12-2009, 05:42 PM
Thanks. Does the data plate list an interior trim code? I'm very surprised Green would have been available on a TA. I am interested in the car, just working out the particulars.
Jimmy
POCI - AAC
Old 07-19-2009, 09:08 PM
dean7276's Avatar
Bump!
Old 07-20-2009, 12:07 PM
turbo's Avatar
turbo turbo is offline
Brewster Green is a one year only color that was put on 1973 Trans ams.
In the birdcage:
1972 T/A, White with blue Deluxe interior
1973 T/A Brewster Green with Saddle Deluxe interior
1977 SE T/A, Black with Black Deluxe interior
1981 SE Turbo T/A, Black with Deluxe Tan velour interior. 19,000 original miles. Owned since 1984.
Old 07-20-2009, 09:28 PM
dean7276's Avatar
Re-painted somewhere in it's 31 year history.
Old 07-20-2009, 09:58 PM
turbo's Avatar
What is the color code on the trim tag. It will tell what the original color of the car is.
In the birdcage:
Old 07-20-2009, 10:07 PM
dean7276's Avatar
Solar Gold w/Dark Camel Deluxe interior.
Old 07-21-2009, 07:39 AM
Hitman's Avatar
Hitman Hitman is offline
The car is sharp. Never seen one in green like that. Kind of cool. The gold was a great color too. Is it reliable? Need anything to cruise it around? Is it one of those "I'd drive it anywhere" type cars.
Should you ever find yourself the victim of others peoples bitterness, smallness or insecurities, just remember, things could be worse. You could be them.
Check out my sons blog, www.driftundertheradar.com
Old 07-21-2009, 08:15 PM
dean7276's Avatar
It runs like a champ.engine and trans are brand new.as is mostly everything else under the hood. Yea, I'd drive it anywhere.Only thing it lacks is A/C and heat.
Old 07-27-2009, 09:37 PM
dean7276's Avatar
End of summer sale! $6250 drives it away!
Old 08-16-2009, 02:02 PM
dean7276's Avatar
