Old 07-25-2009, 05:42 PM
Scott M's Avatar
Scott M Scott M is offline
Question Floor jack recommendations?
I've been using the same 1 1/2 ton Craftsman floor jack that my parents bought for me 27 years ago. The teeth on the up/down control have finally worn out.
I've heard good things about a company called "Lincoln" and I forget whose jacks the local tire store uses.
Any suggestions either in steel or in aluminum?
Thanks.
Old 07-25-2009, 06:12 PM
The Boss's Avatar
The Boss The Boss is offline
A long handled screw driver or a tire iron will spin those teeth for you Scott - not sure how I know that.
And go racin' in the street.
Old 07-25-2009, 07:15 PM
limejudge69's Avatar
Spend the money on a good one. Cheap jacks aren't worth your life. Stay away from the Harbor Freight garbage, especially the aluminum 'racing' jacks. OTC also makes great jacks, but are pricey. You get what you pay for. just my .02
Old 07-25-2009, 09:23 PM
Carquest or NAPA and buy one with a universal joint in the pivot. No matter who the vendor is they u-joint jacks are good quality.
Carquest has a 3.5ton jack for 329.00 until Sept 30th of this yr.
Mike
former." --Albert Einstein
- Winston Churchill
Old 07-26-2009, 12:08 AM
fiedlerh's Avatar
fiedlerh fiedlerh is offline
The newer Craftsman jacks seem to hold up better. I had the same problem on my old Crapsman jack after a few years. Ended up scapping it after I got tired of using channel-locks to work it.
http://www.pontiacpower.org/
Old 07-26-2009, 12:19 AM
rcrahn's Avatar
rcrahn rcrahn is offline
I have an AC Hydraulic jack and love it.
http://www.asedeals.com/hydraulicjacks2.html
Old 07-26-2009, 01:42 PM
Scott M's Avatar
Question
Anybody have any idea who currently makes the floor jacks for Sears?
I say "currently", as the low bidder on their contracted stuff often changes from year to year.
Old 07-29-2009, 02:37 PM
YVEYANT's Avatar
YVEYANT YVEYANT is offline
Send a message via AIM to YVEYANT
I believe Hein-Werner is the only floor jack still being made in the USA. Quality is second to none and can be fully serviced:
http://www.jackxchange.com/categories/24.cfm
Ant
1967 Pontiac Tempest, GTO-Inspired
"What's so special about having Italian food cooked by a bunch of friggin Mexicans"
Paulie-
Rocky Balboa
"Your heart is free, have the courage to follow it"
Braveheart
http://i106.photobucket.com/albums/m...Wm0SlqN030.jpg
Old 07-29-2009, 03:44 PM
TA455HO's Avatar
TA455HO TA455HO is online now
If I were going to buy a new one today I'd take a serious look at this one.
http://www.griotsgarage.com/product/...+floor+jack.do
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant
http://www.ford-trucks.com/forums/12...al-ranger.html
1966 Ford F250 4x4 Red/White 4-speed - San Jose plant
1966 Ford F250 4x4 White 4-speed - San Jose plant
http://www.ford-trucks.com/forums/11...-f250-4x4.html
1971 Trans Am White/Blue 4-speed limited options - Norwood plant
http://forums.maxperformanceinc.com/...d.php?t=757496
Old 07-29-2009, 04:04 PM
jww jww is offline
I recommend a Lincoln/Walker, OTC, Hein Werner if they're still made. Get a name brand made in the US and get one larger than what you think you really need. Even the US jacks aren't as good as they were 20-30 yr ago.
I have two, 30 year old Blackhawk (no longer made) floor- jacks that I wouldn't trade for anything made today. Actually my oldest Blackhawk, I bought at Sears about 1972-3, and has "Sears" nameplates on it, but it's a Blackhawk. You may want to consider fixing your old one if it's a quality piece.
My $.02
JWW
Old 07-30-2009, 07:39 PM
Simple Man's Avatar
I have one purchased at Granger about 7-8 years ago, Dayton brand. It's been trouble free.
be a simple...kinda man.
Old 07-30-2009, 11:23 PM
mechanic17 mechanic17 is offline
Hate to say it, but I had a Harbor Freight 2 1/4T cast iron jack for many years when it got stolen. Replacement 3T is working great. They're not junk.
BTW, "Earthquake" 12" impact gun is pretty good too.
On the other hand, I had 2 compressors die on me; #3 works great and reliably.
My point is, yeah, the place is a crap shoot and not good for our economy, but condemning their stuff just because it's inexpensive isn't solid thinking. You do sometimes get more than you pay for.
Old 07-31-2009, 12:17 AM
tajohn tajohn is offline
It is probably overkill but you might want to check Weaver floor jacks. They are still manufactured in Michigan. If I remember, NAPA sells them, among others.
If new isn't where you want to be money wise, check the auctions of ....unfortunately. car dealerships...as they frequently purchase them.
I have a 4 ton as well as a couple of their 10 ton units(don't ask why...) I also have one of their 9000 pound lifts. Quality items that can be rebuilt(seals available) and I don't think you would ever twist the frames on these jacks.
A good jack and stands are something you really don't want to go budget on. They will be what keeps the car off your head.....
Best of luck with your search.
Old 07-31-2009, 07:34 AM
straycat's Avatar
straycat straycat is offline
don't forget craigslist or local auctions listed in the newspaper. some good buys there from guys closing shop.
Old 07-31-2009, 08:14 AM
Overkillphil's Avatar
Overkillphil Overkillphil is offline
I'm on my 4th Sears aluminum "racing" jack. First one didn't work right out of the box. Second one stopped lifting after a little bit of use and would only lift at the last inch of stroke on the handle! The third one broke the U-joint when I was lowering the GTO onto the caster wheels!
Now on 4th one and ended up buying a heavier duty one at Pep "Bros." which is a "Torin". Big heavy red thing. Should be able to handle my Excursion, hopefully.
Bottom line: The Sears Alum. jacks are certainly pretty, but my confidence is nil in them at this point. (I thought they were ideal at first because they are so nicely put together and light for throwing in the trunk of the car in a pinch.)
Scott, proceed with caution if you decide to go with an Alum. jack.
___________________________________
"Objects in mirror are closer than they appear"
Old 07-31-2009, 11:04 AM
Agreed. I have a 5 year old one that works great. Not sure what the capacity is but it lifts the Pontiac with no problem. I think its 2 1/2 tons?
I have an aluminum one that I don't trust but keep it in the back of the Volvo in case of a tire change. You wouldn't believe what kind of jack came with that that car.
Old 07-31-2009, 11:32 AM
Region Warrior's Avatar
My 30 yr old 2.25 Matco still works like new.
Probly regret say'n it.
It gets used almost nightly.
Old 07-31-2009, 06:16 PM
lighthouseman's Avatar
lighthouseman lighthouseman is offline
I vote for the Sears aluminum (called a racing Jack) unit . . . not too expensive and mine is going on 6 years, and works like the day I bought it.
Steve
Old 08-01-2009, 10:58 PM
rkm1003's Avatar
rkm1003 rkm1003 is offline
I don't trust my life with ANY jack. Would NEVER crawl under any car being held up with only a jack. Jacks are for lifting, jack stands are for keeping you safe. BTW, have been using the same Harbor Freight jacks, engine puller, engine stand for 8 years with no problems. Granted, I don't do it for a living, but have pulled motor outta mine and a couple buddys cars 8 times with no problem.
'69 Pontiac 400 YA, .060 over, stock crank, 10.2:1 comp, CAT H-beam rods, HS 1.65 rockers, Crane cam 248/252 660 lift, Edelbrock 72cc heads ported 300 cfm, Performer RPM Intake, Ruggles 800 cfm Q-jet, Summit 140 gph electric fuel pump, 12 bolt 4.10 posi, 200-4R, Transgo HD shift kit, 2800 stall, aluminum radiator, 2" MadDog Headers, DMH 3" cutouts.
12.51 et @ 111 mph
Old 08-05-2009, 12:08 AM
Colin Frolick's Avatar
Colin Frolick Colin Frolick is offline
this one's been real good for me
