Old 09-14-2009, 08:12 PM
Blue '66's Avatar
Blue '66 Blue '66 is offline
Originally Posted by fyrffytr1 View Post
And no, I have not added in the initial cost of the car. I will probably reveal the purchase price when I do the final total.
Can we guess the price of the car?$19.95?
  #382
Old 09-14-2009, 09:54 PM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is offline
I got it at Sam's Club, not Wally World!! But, you are the closest so far.
  #383
Old 09-20-2009, 06:02 PM
fyrffytr1's Avatar
Well, I didn't do too much to the car this week. Work is kicking my old butt. I did get the ribbon harness installed(Thanks, Bigpop) and got the pigtails fixed on my back-up lamps as well as good lenses and lens gaskets(Thanks, Tim John).I also bought a bumper jack at the Pigeon Forge show.
I worked two hours and spent $179.41 on parts so here are the latest totals:
Labor @ 375 1/2 hours..............$7,510.00
Parts ....................................$7,089.57
Outside Labor .........................$6,156.00
Gifts ........................................$716.52
total....................................$21,472.0 9
  #384
Old 09-21-2009, 06:12 AM
You keep paying yourself those kind of wages, you'll be rich by the time you finish that car!
Old 09-21-2009, 06:43 AM
bigpop bigpop is offline
Hey Phil, when you go for BOS or Gold Concours,be sure to pull up the carpet and show the judges the Ribbon Harness,that should insure a win!!!! (wink) Larry B.
Mr. President, you can't say Dallas doesn't love you "
  #386
Old 09-21-2009, 08:23 PM
fyrffytr1's Avatar
You mean I have to cover up my beautiful ribbon harness with a carpet?! I thought I would run it on top of the carpet. In fact, I may just leave the carpet out so as not to spoil the view. Heck, I may just leave the convertible top off.
  #387
Old 09-21-2009, 08:25 PM
fyrffytr1's Avatar
I would ask myself for a raise but considering the small amount of work I have been doing lately, I might fire me instead!
  #388
Old 09-27-2009, 07:29 PM
fyrffytr1's Avatar
I didn't even get out to the shop last week. I have been working but, the money has gone to tires for my truck and my wife's SUV. I also have to fork over about $350.00 for car tags in the next week or two.
The builder I work for has two houses to start. However, I won't get to do my part until around February or March of next year!
So, unless I win the lottery, the car will not see much headway for awhile. Man, this economy SUCKS!!!
  #389
Old 09-27-2009, 09:10 PM
Blue '66's Avatar
It will give me some time to catch up!$350 for car tags???Mo tags are based on the Horsepower of the car.My wifes '00 Prizm and '03 Impala are well under $100 my GTO is $35
It would be tough as close as you are Phil and having to put it off....
  #390
Old 09-27-2009, 09:48 PM
fyrffytr1's Avatar
I hope to get all the small stuff done and, maybe, by then I'll be in one of the new jobs. I have faith that the car will get finished. But, you know He can't be rushed.
  #391
Old 10-04-2009, 11:31 AM
fyrffytr1's Avatar
I did a little to the car this week. I trailered it to my friend's alignment shop and had the front end lined up and checked out. Everything is OK. I also worked on the turn signal switch. The screw that holds the turn signal lever was broken off in the switch, so, I took the switch out to work on it. It takes an 8-32 X 5/8" screw so I figured I'd run out to Lowe's and pick up a pack. They had 1/2" and 3/4". I bought the 3/4" and ground it down to 5/8".
I posted a thread on here about it. That's when a fellow PYer reminded me of the springs in the housing! So, I eneded up pulling the whole steering column out of the car to work on it. I needed to do that anyway because I forgot to install the lower column seal when I first put the steering column back in.
I also ordered some bumper bracket washers from AMK but they have not arrived yet. I bought the bolts from a local shop and spent $14.30 on them The front end work ran me $65.00
I worked on the car for 3 1/2 hours. Here are the latest totals.
Labor @ 379 hrs...............$7,580.00
Parts .............................$7,103.87
Outside Labor...................$6,221.00
Gifts .................................$716.52
Total.............................$21,621.39
  #392
Old 10-07-2009, 07:33 PM
fyrffytr1's Avatar
I drove her around the block 3 times today!! Man, it felt good!
  #393
Old 10-08-2009, 12:48 PM
vamman1's Avatar
vamman1 vamman1 is offline
Awesome.
Hoping to in a couple of weeks... if it doesn't snow.
  #394
Old 10-08-2009, 08:29 PM
Blue '66's Avatar
Pics of the rubber burned off the tires?
  #395
Old 10-11-2009, 08:54 PM
fyrffytr1's Avatar
Man, I splurged this week! I spent $41.00 on parts!! I got the grip washers and clipped washers for the bumper brackets. Bought them from AMK Products. Oh well, I have a birthday coming up soon and I hope to increase the gift column amount.
I took the oil pressure/water temp gauges out of my instrument cluster and hooked them up to the wiring harness. I ran a seperate ground from the gauges to the dash and the oil pressure gauge worked the first time. I had to remove and reinstall the temp sending unit wireand then the temp gauge worked.
I drove the car around the block two times and the temp needle rose almost to the first line on the gauge. I let the car idle but it never did get hot enough to open the thermostat.
Anyway, I worked one hour and spent $41.00 so here are the new totals.
My Labor @ 380 hrs..........$7,600.00
Parts.............................$7,144.87
Outside Labor..................$6,221.00
Gifts ................................$716.52
Total ...........................$21,682.39
  #396
Old 10-11-2009, 08:58 PM
fyrffytr1's Avatar
Let's just say I'm coating my driveway one run at a time!
  #397
Old 10-11-2009, 09:26 PM
Blue '66's Avatar
That really awsome Phil that you are getting to drive your car,that will keep you motivated
  #398
Old 10-11-2009, 10:05 PM
fyrffytr1's Avatar
I'm motivated. My wallet won't support me in the manner I am accustomed to!
  #399
Old 10-11-2009, 10:07 PM
GT182's Avatar
GT182 GT182 is offline
Great to hear it's now diveway driveable Phil.
Got ya beat on parts for the week. I just spent 302.00 on parts I've needed for awhile but put off getting. And that's not counting the steering wheel I'm getting from you.
BTW... how in hell do you get the anyone to give you "gift" parts? I throw out all kinds of hints but they fall on deaf ears. Not even a thing for my Goat at Christmas for the past 2 years. And no, I'm not about to buy any of them hearing aides either. They can stay just as deaf as they are dumb. LOL Hmmmmm, maybe it's because I won't let them touch it unless the women are Totally Nude. Yeah, I've got a sign for the dash that really says that.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
  #400
Old 10-11-2009, 11:39 PM
fyrffytr1's Avatar
When they ask me what I want I tell them I want the green stuff. And I take an extra large!!
