Old 11-08-2009, 06:31 PM
antique69lemans antique69lemans is offline
Originally Posted by gearbanger View Post
Were the upper rod bearings cupped to the point they wouldn't stay in the rod. If so, I would say definitely detonation. I went through several engines back before I knew about detonation. Engines all ran good and you could not hear any pinging or rattling. But after a few thousand miles the oil pressure would go away and eventually would start knocking.
Pull it apart and all the bearing would be down to the copper. That was back when I was trying to run 670s on a 406 with pump gas. Not gonna work.
Bearing inserts being loose AFTER meltdown is common. They are deformed under the extreme heat and lose their shape. The rod big end is suspect from the heat. Even if they were perfect before, the rods will probably be "egged" and cause improper clearances with new inserts. I have seen oil starvation cause rods and blocks to blacken from the heat and burnt oil. I would personally consider another set of rods in the next build.
Old 11-08-2009, 09:54 PM
68grandprix 68grandprix is offline
A couple of the lowers were cupped. I heard the engine rattling/knocking as I slowed from the interstate and the oil pressure was considerably lower than it had been. Most of the bearings look the same. Oil pressure was 75-80 psi at startup, around 60psi when warmed up and running down the road at 2000-3000rpm. Oil filter is an AC Pf24. The rods are the PPR 4140(cheaper forged). The engine ran 190degrees all the time(except went to 210 one time during extended idling). Tangs on rods are facing in. The short block was delivered complete, I assembled the top end. The rods shouldn't have been resized, they were new.
I do plan on completely tearing down the engine and getting it cleaned out. The heads are 6X-4, with the combustion chambers opened up by me as suggested in HTBHP Pontiac V8s. Also a valve job. 455+.040", I knew I'd be close on 91, but the motor ran the same on 91 as it did on 110(as far as I could tell). The piston tops were also polished with all sharp edges smoothed. Jim
Sometimes I think about how much more money I'd have if my car got better mileage, but when I hammer the gas and I smell that tire smoke........I remember that I also spend a lot of money on tires.
Old 11-08-2009, 10:13 PM
Ken K Ken K is offline
If the crank was standard and you just had it polished then there should not be any problems with clearence. I had a machine shop check a set of those rods, I was told the big end was right where they liked it.
Old 11-08-2009, 10:34 PM
Riffle brush the oil passages. 1500 miles should not be enough time to get them dirty. If they were cleaned then you should not pull any gunk out of them. Dirty ones can be just like tar.
Old 11-08-2009, 10:52 PM
old66tiger's Avatar
old66tiger old66tiger is offline
I would have all of the big ends checked by the machine shop to make sure that they are all the same size. Then, have the crank checked to make sure that there is consistency. My guess is that it was too tight - borderline. The bearings did not look rough and the picture of the crank looks nice and clean. Should clean up well with some new bearings.
Skinned knuckles and empty wallet! Could I be any happier?
66 GTO Convertible. LS3-525 HP. Legend LGT700 5-speed, Wilwood 4-wheel disc brakes, Ridetech coil over front susp, PMT rear susp, Hotchkis bars, Billet Specialties 18" Dagger's (18X9 rear, 18X8 front).
2002 Ram Air WS.6 convertible Trans Am. Wife's car.
Old 11-08-2009, 11:06 PM
chevymad chevymad is offline
Are all the bearing halves marked standard? On a recent build I had half of my main bearings std the other half 0.010. Came out of the same box, in sealed shrink wrap. I looked saw 0.010 and installed. Then wondered why I had no oil pressure. First time I ever put one together without at least plastigauging too! I was sure of the machine work because it was a running motor.. never thought the bearing shells themselves would be a problem.
Old 11-09-2009, 03:12 AM
72blackbird 72blackbird is offline
Jim,
6x-4's on a .040 455 make about 9.3-9.4:1, a bit close for 91 octane, even if you opened up the chambers a little- a chamber volume check will tell you for sure. I've used the PPR 5140 rods on other builds an they're usually dead on, but it's not a bad idea to have them rechecked for roundness after what happened.
Have your machinist mic the rod and main caps torqued to spec and crank journals after everything is cleaned up. I'd shoot for a .0018-.002 oil clearance on both the rods and mains- that should give you both good oil pressure and bearing protection.
Geno
Old 11-09-2009, 12:09 PM
Z Code 400 Z Code 400 is offline
I've had a few sets of brand new rods lately that were too tight and had to be honed. Check everything twice, even the obvious stuff...Robert
Old 11-09-2009, 01:29 PM
2manyponchos's Avatar
2manyponchos 2manyponchos is offline
Were the mains and cam bearings ok? If not, might have been a good idea to do an oil sample analysis. Have seen this on an engine that had coolant in the oil, but all bearings were affected.
P.O.S.I - It's not just a club...it's an addiction!
Old 11-09-2009, 07:12 PM
Here are a few more pics. Pistons, bores, chambers looked good(may have been running a little rich) but one rod journal and rod are discolored. Does this mean I need a new crank and rod(s)? I haven't checked the mains yet. I can't get the damn damper off and I'm waiting for a puller(mine was borrowed and never returned). The pistons are also about .030" down in the hole according to my cheap machinist's dial gauge. If I remember right the online calcs said I would be at about 9.6:1 compression. Jim
Old 11-09-2009, 07:14 PM
pics
Name:	464 teardown 001.JPG
ID:	187018   Click image for larger version
Name:	464 teardown 002.JPG
ID:	187019   Click image for larger version
Name:	464 teardown 006.JPG
ID:	187020   Click image for larger version
Name:	464 teardown 007.JPG
Old 11-09-2009, 07:55 PM
Is the discolored rod and journal toward the front of the engine?
Old 11-09-2009, 08:26 PM
AG's Avatar
AG AG is offline
By the looks of the chambers, you have an oil blow-by issue also.
Old 11-10-2009, 01:34 PM
It was the #4 rod. Jim
Old 11-10-2009, 02:30 PM
webfoot's Avatar
webfoot webfoot is offline
FWIW I have those cheaper forged rods and had to get the big ends resized. The machinist said they were hourglass shaped.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 11-10-2009, 02:50 PM
Now you are starting to scare me. I have a set of those rods and they checked out and the engine is still running. The reason I am scared, that is the second engine I have seen pictures of using those rods that had bearing problems. The other was a 400.
Old 11-10-2009, 10:23 PM
The mains look like they would have been ok, but some are now grooved(I assume because of rod bearing material). The outer sides of the thrust bearing are copper-colored, is this normal? Jim
  #38
Old 11-10-2009, 10:30 PM
The copper color on the thrust bearing is normal, that is how brand new ones look. What brand of bearings did you use?
  #39
Old 11-10-2009, 10:45 PM
This is the bottom end on a 400.
  #40
Old 11-11-2009, 01:32 AM
rod cole rod cole is offline
The discolored one indicates it was to tight[most likely cause] or starved for oil. Poor clearance checking as a fyi I receive a new set of FM bearings and they were half .010 and .020 right out of the box.
