Old 12-07-2009, 03:47 PM
Trump Trump is offline
Default 1960 389 timing cover?
I'd like to locate a 1960 389 Pontiac timing cover. Looking for the one without the snouts for the heads and without the water cross-over that goes to the intake. Hoping to use it to allow me to use a 1955-1960 intake on a '61-64 longblock.
If you have one you'd be willing to part with, please let me know. Thanks.
Old 12-07-2009, 08:39 PM
Poncho60 Poncho60 is offline
There's one on e-bay right now with a BIN price of $35....Just type in Pontiac 1960 timing cover!
Old 12-08-2009, 09:01 PM
poison heart's Avatar
poison heart poison heart is offline
Send a message via AIM to poison heart
You'll have to use 55-60 heads to make the intake work. The water cross over in the intake is what makes a difference, not the timing cover. Changing to a 1960 cover won't help
Robert Lewis
1959 Star Chief 4 Dr HT dual quad 389 4 speed
1962 Pontiac Plain Jane Catalina
http://pontiac-59.com/
Old 12-08-2009, 09:17 PM
you are absolutely right. Luckily, the edelbrock intake that I'll be using was drilled for both water passage locations, I just have to put freeze plugs in the passages that won't be used.
Old 12-08-2009, 09:43 PM
Then why do you want to swap timing covers? Can't you just plug the water hole in the timing cover that goes to the intake?
Robert Lewis
Old 12-08-2009, 10:06 PM
I could plug the hole in the timing cover, but the whole passage interfers with the intake. I might be able to grind it down on a corner, but that would be kinda clunky looking. I'd rather have it look proper.
These pictures might help you see what I'm talking about. See how the water cross-over portion of the intake hits the water passage of the timing cover? It's just easier all around to use a 1960 cover. Look cleaner, function properly, fit right, etc....
Old 12-08-2009, 10:49 PM
Ah I see what you mean. What year is that timing cover in the photos?
Out of curiosity, what is the motor going in and who makes that intake?
Robert Lewis
Old 12-08-2009, 11:15 PM
1962 timing cover currently on it.
Motor is going into a gasser project I've been messing with. The intake is an old Edelbrock unit. This isn't the actual motor, but this is one I keep around to test fit stuff and maybe down the road might build if nobody else buys it. I've got a '60 389 core as well. But saving it for when I get the opportunity to buy "the one that got away".
I know where two others are, one is $500 and has some buggered carb base holes, the other is loaded with 6 stromberg 97s and I'm afraid to even ask how much.
Old 12-08-2009, 11:23 PM
Thats pretty cool.
What kind of gasser?
Robert Lewis
Old 12-10-2009, 11:56 PM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
I have a 60 cast iron one. Let me dig it out & see what condition it is in.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 12-13-2009, 01:22 PM
thepontiacman's Avatar
thepontiacman thepontiacman is online now
what is the part # for the 60 timing cover?
Old 12-13-2009, 02:02 PM
Thanks fellas, I just bought the one that was on ebay. So I should be good for now.
