Old 12-13-2009, 02:00 AM
EPC_Motorsports EPC_Motorsports is offline
Originally Posted by bad69bird View Post
How much HP did you make N/A? According to Wallace's calculator you making:
Your HP computed from your vehicle MPH is 1,271.59 flywheel HP
Your HP computed from your vehicle ET is 1,130.41 flywheel HP
Based off your 5.38 @ 133 pass.
What fiberglass do you have on the car? Hood and inner fenderwells?
Just the hood,It has a dry sump system and 0.65 wall stainless headers on the front etc. The car is all thare pluss some. Those numbers up thare should show you someting. We ran that same tune up testing that converter that broke two weeks before and ran a string of mid 8.30s at 165.8 , On motor we went 147mph Converter and gearing will throw you for a loop
  #162
Old 12-13-2009, 02:11 AM
Motor made 787 at 6800 rpm. We took two points of static out of it since But still seems to run about the same on nos But now runs more mph and runs cooler. Who knows! you cant measure a pontiac to anything. Best n/a run on motor to date since all the changes, 9.89 at 147 mph on c-16 fuel.
  #163
Old 12-13-2009, 02:22 AM
1963gp's Avatar
1963gp 1963gp is offline
Default 1963 Grand Prix
Thanks Wreckmastr for posting pic of my car. Ran it best that week end 11.28 at 120.88 mph at 4280 lbs. Allen
1966 Grand Prix loaded 421 tripower
1963 Grand Prix 4180lbs street driven 10.96 1/4 120.98 mph 1/4 1.51 60' 6.92 1/8 with 8 lugs, factory A/C and reverb
and tons of Corvairs
  #164
Old 12-13-2009, 09:11 AM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
I did think the car had any interior and has a lexan rear window?
[email protected]. 3460#s
  #165
Old 12-13-2009, 03:15 PM
Jack made a point, car does have alexan rear window but does have a full interior. head liner full factory carpet , stock front and rear side panels stock dash less heater assy. Kick panels and 1/2 inch plywood between the mini tubs to replace rear factory seats and foctory package shelf. With all thhat weight savings lets add programable 7 box, race pak and wireing three nos controllers a switch box and about 18 lbs of wireing nos gauges and lines etc. By the post I can kind of see whare this is headed. All the hoopla last year before norwalk and look what hapened. Were 3478 and on one system we could consistantly go 8.30s on 10.5s through the pipes and were happy with that. As like for some others 2010 will be alittle differnt story for us.
  #166
Old 12-13-2009, 03:53 PM
LiL Jack's Avatar
Jack when you were down MIR running 30's they car didn't have any interior in it. I could see the hole saw holes in the doors.
When did you get the interior put in the car?
Good luck in 2010, hopefully I will be able to see what a race track looks like next year.
  #167
Old 12-13-2009, 04:41 PM
bad69bird's Avatar
bad69bird bad69bird is offline
Dude when you run the numbers the MPH is way off from the HP numbers you had on the dyno. So either the dyno you were on was stingy, you're throwing more than one plate at it, or the car is lighter than you say.
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs)
  #168
Old 12-13-2009, 05:56 PM
wreckmastr's Avatar
Hey EPC I know it was our fault we didnt get the race off last summer ( we brought junk ) But is same race offer still stand for this year? Not starting chit. Just seeing where we stand.
Not to turn this into a pissing match, Just a good race. We are almost at your weight and smaller inches.Also on 10.5s. But I dont come begging like some. So with that said . Lets make this worth our while. I have no problem running you at your weight. We will run for no less than 2500$$ And no clocks. You name the place and how much. only one request, A treated track.
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
  #169
Old 12-13-2009, 10:39 PM
spartazoo's Avatar
spartazoo spartazoo is offline
Born Too Late at Good Guys Indy.
ID:	190785   Click image for larger version
ID:	190786   Click image for larger version
ID:	190787   Click image for larger version
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
1966 GTO Hardtop - PS 14.84 @ 97mph
  #170
Old 12-13-2009, 11:11 PM
Brian, we dont have a plate on our motor any longer and we ran our car all summer on one system. If obviously your trying to measure up how much power were making mayby you caremore than us. Ill be the first to tell you what you prob already know. you all make more power than us but I could care less. You got to put it down. I dont know about all these calculations. Are you measureing by the mph, **** man all I care about is et We have been enough mph to show almost 1300. To me that dosent seem realistic. That tells me I am missing something. We found it If you think its lighter than it is I guess you know more than me. Next year it will be some other sh t I have new angle for this year, were going forward . I dont want to wait for some to play catch up. Ill save that for the fries at 75-80. You and jack should come this summer, Its agood time
  #171
Old 12-13-2009, 11:39 PM
jdw_poncho's Avatar
jdw_poncho jdw_poncho is offline
Originally Posted by wreckmastr View Post
Here is a little better picture for ya.
Man, I knew I should have bought that car when it for sale AND I had the money. Great looking car....
  #172
Old 12-13-2009, 11:52 PM
Buddy, I like you guys but this is racing. First of all that offer was with your e headed motor. We both know that so lets not start playing dumb. I said I would consider running a big tire car with your new bigger motor because I was suspect to what would happen and sure enough we towed all the way to ohio and what happened. We still went faster with much less in worse conditions. Sunday lil jack only went 8.70s, So you tell me. Still we were on one little kit. So here we sit in late december. You guys build yet another new motor still wanting the same race. Yeah right. Not being mean but you guys were in trouble in august Because We knew what was going to happen, Oh then one better, Remember to the comment Just run what you brung and I said that offer was with your current motor. You guys want a gimmie race. So here is the deal. We have a new package too. Same old low budget junk. You all go down south with Steve Johnson and test all that new latest and greatest and we well test our new package in late feb and we can do that run what you brung **** all you guys want for the same money or whatever Thats whare I stand.
Happy new year to you and your brother better luck in 2010 You guys should have much better luck with George , Hes a good guy.
  #173
Old 12-14-2009, 12:25 AM
David Holmberg's Avatar
Billy, if you guys come down here to test with Steve, you BETTER call me.
The weather is great, BTW.
Sounds like a race, I can't wait for spring.
  #174
Old 12-14-2009, 11:16 AM
PONTIAC DUDE's Avatar
Post
Few pics from 2005 Orlando Street Car Shootout. Drag Radial Class.
Stock suspension, 3575lbs plus at that time.
8.93@160 on a Schnitz progressive timer. .5 delay with 1.5 build time added on top. Soft, soft tune up.
Soft plume Fogger w/40 pills. Single stage.
Name:	Orlando pits 2005.JPG
ID:	190824   Click image for larger version
ID:	190825   Click image for larger version
ID:	190826   Click image for larger version
ID:	190827   Click image for larger version
  #175
Old 12-14-2009, 11:26 AM
Post
Few pics from Pontiacs in the Park VMP 2006.
Heads up Street Car race. Gotta give the wife some air time. Without her would be twice as hard and busy.
535 pump gas engine on 93 octane. HYDRAULIC ROLLER. Single plate system installed on Friday night to race Saturday. 72 pill. 9.30@140 I think. Don't have the slip with me. but close.
ID:	190829   Click image for larger version
Name:	5-23-06 VMP #2b.jpg
ID:	190830   Click image for larger version
Name:	5-23-06 VMP #3b.jpg
  #176
Old 12-14-2009, 11:27 AM
mysticmissle's Avatar
Dude how fast are you running with your new combination?
  #177
Old 12-14-2009, 12:07 PM
Talking
Only one time out and posted that. Before it became a clusterphucked post. LOL. Haven't really put it all down yet. Haven't had a chance to get out with my new combo only once. If I can get it all together and certain things turn around, I hope to have my Hydraulic roller combo into the 8's with pump gas compression & nitrous next year. But first Balls to the wall........ N/A. LOL.
  #178
Old 12-14-2009, 01:02 PM
John Langer's Avatar
John Langer John Langer is offline
Shakedown this year. Car might be sold???
ID:	190840   Click image for larger version
Name:	e town q2.jpg
  #179
Old 12-14-2009, 01:49 PM
dda72's Avatar
dda72 dda72 is offline
Talking
Pontiac Dude buying it??
  #180
Old 12-14-2009, 02:03 PM
bad69bird's Avatar
Jack,
All I'm saying is that something is not adding up. When I say "a plate" I figured I would be mis-spoken. I'm not up on all that NO2 stuff...plate this, jet that, one kit or three kits I can't keep that chit straight! LOL
But the easiest and most accurate way to figure out how much HP someone is making is to use their MPH and weight. You're a smart man...you know that! That's why I said something wasn't adding up and listed those three factors. I can say with my car, that this is the most accurate way to see how much HP I'm making. You can't go by ET because I pull timing out off the hit.
Not trying to pi$$ in your wheaties or nuttin', I'm just bored recovering from my surgery and had time to look into your post. As far as 75-80, I might try and go next year. Kinda hard to drive right past my home track (20 minutes away) and continue to drive another hour and a half. LOL
