Old 02-14-2010, 01:21 AM
pontiac phil pontiac phil is offline
Default 1965-389 correct oil dip stick
I have a 65 GTO 389 WITH AC. Can any one tell me were the dip stick tube should mount. Is it to the valve cover behind the compressor or to a bracket on the front of the head? I have the tube in the block but am missing the upper most piece. Is it higher then the valve cover? Any pics would be helpful. Thanks
Old 02-15-2010, 07:13 PM
TooLow TooLow is offline
I am not sure about the GTO's but for a 65 tempest with a 326 the dipstick tube mounts on the valve cover bolt and sticks up over the valve cover. I would sort of think the setup would be the same for the 389. The pic is when we bought the car, we are in the process of redoing it now. Hope the info helps some, or maybe someone with a GTO will chime in with the right answer.
Old 02-15-2010, 08:33 PM
Thanks for taking the time to send the picture. My car should have the compressor on pass. side, but the dip stick should be in the same place I beleave
Old 03-15-2010, 10:04 PM
pbertrand65goat pbertrand65goat is offline
Default position of oil dipstick
Phil,
I have a 65 GTO 389 and it's in the same place as the 326.
Best of luck with the restoration.
Paul
Old 03-15-2010, 10:52 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
A factory air car takes a long dipstick than the one pictured. (The one pictured has dealer add on air) I haven't seen one in a few years and am not sure exactly how it mounts, but it is different!
Old 03-16-2010, 09:57 AM
Sirrotica's Avatar
The dipstick extension tube has a tab on it that is secures it to a hole drilled in the top of the upper compressor bracket with a self tapping sheet metal bolt ( approx 1/4") that also has a star washer and the ground wire for the A/C compressor also attaches there. A/C cars also use a longer dipstick than non A/C cars because of the added length of the extra upper tube extension. So if you don't have the extra tube you need that and the longer A/C dipstick to make it correct. With the A/C compressor in place it's impossible to check the oil as you can't reach the dipstick handle of a non A/C unit. I don't have a picture, this is just from memory of working on many Pontiacs through the years, hope it may be of some help to you.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 03-16-2010, 09:47 PM
Jerry H.'s Avatar
Thanks, I knew I wasn't going crazy!
Old 03-17-2010, 07:46 AM
Sirrotica's Avatar
NP Jerry
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
