Old 02-17-2010, 08:19 AM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
Updates?
Old 02-17-2010, 10:06 AM
GTO's Avatar
GTO GTO is offline
My clutches and steels came in first so I rebuilt my trany and installed it.
Yesterday I started on the drivers side header. All went well but I need a tighter 2 1/8 90 to get by the steering shaft. Today I will start on the pass. side. Was able to clock the drivers side by just using the 90 ends that were cut off the kits ends. Passenger side will be a bit tighter to clock. I also had to cut out two chassis bars to fit the header and oil pan. They will be relocated when the headers are done. It's tough when you have to wait a week between orders.
Also got ahold of James Monroe to see if my 4" Toilet can keep up. Of course it will not once the larger heads are bought and installed. So a Terminator upgrade is in order. ...Eric.
ID:	197587   Click image for larger version
ID:	197588   Click image for larger version
ID:	197589   Click image for larger version
ID:	197590   Click image for larger version
Runner Up Q16 Norwalk 2013!
Old 02-17-2010, 12:23 PM
racegto65's Avatar
racegto65 racegto65 is offline
Just an FYI, but if you are running a diaper instead of a belly pan you might want to put it on before you finish weld.My headers were built years ago and tuck close to the oil pan and even after modifying one side the diaper is still a problem.
Old 02-17-2010, 12:38 PM
GTO's Avatar
GTO GTO is offline
I know what you mean. Had issues with my 2" headers. I'm keeping an eye on these tubes. Will be able to slide the diaper in but have to use header wrap on both the diaper and headers. ... Eric.
Old 02-17-2010, 01:26 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
Thanks for the update on this build, i just ordered some pipe to do mine so this thread is going to come in handy.
I would stay away from the wrap if you can on the headers, have had too many people tell me it will create issues with the pipe rusting. I had to have Dennis at DRE put a couple of patches on my diaper for heat protection and has worked fine.
Dave Polichena
Old 02-17-2010, 10:08 PM
GTO's Avatar
GTO GTO is offline
Passenger side almost done. Need a tighter bend for front cylinder to make it look better. Tight J bends on order. ... Eric.
ID:	197643   Click image for larger version
ID:	197644   Click image for larger version
ID:	197645   Click image for larger version
ID:	197646   Click image for larger version
Old 02-17-2010, 10:10 PM
GTO's Avatar
GTO GTO is offline
More.
Had to put some twists in it in order to be able to clock them. Otherwise it would have been easier to run pipes.
ID:	197648   Click image for larger version
Old 02-17-2010, 10:30 PM
looking good, that sure is a nice looking oil pan!!!!!!!!!!
Old 02-17-2010, 11:27 PM
wrench's Avatar
wrench wrench is offline
Very nice work. You would think with a tube chassis, you would have some room to work with. That is tight!!! Please keep us updated to the end. Do you have an estimate of the time invested so far?
Old 02-18-2010, 11:06 AM
GTO's Avatar
GTO GTO is offline
Thanks. Too bad I have to cover it with a diaper.
Old 02-18-2010, 11:10 AM
GTO's Avatar
GTO GTO is offline
Ya it's tight. Was the first car I did chassis work on. Should have made room for bigger headers. I would know what to do now.
So far I have about 16hrs into it. First set so there was a little screwin' around at first.
Old 02-18-2010, 08:24 PM
GTO's Avatar
GTO GTO is offline
Headers are out now. Waiting for parts. Pulled motor to complete assembling block and weld bars back on chassis.
ID:	197748   Click image for larger version
ID:	197749   Click image for larger version
ID:	197750   Click image for larger version
Old 02-19-2010, 10:45 AM
Ron H's Avatar
Ron H Ron H is offline
Nice work Eric.
68 Firebird
Are you running with the wind or breaking it?
Old 02-19-2010, 12:06 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Ya first class work for sure.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 03-23-2010, 07:26 PM
GTO's Avatar
GTO GTO is offline
Finally got back at it. Finished off #1 and #2 cylinder.
ID:	201020   Click image for larger version
ID:	201024   Click image for larger version
ID:	201025   Click image for larger version
Old 03-23-2010, 07:33 PM
GTO's Avatar
GTO GTO is offline
Here I'm sandblasting, painting with POR 20 and heat curing on a state of the art Northern Ontario Jack Pine oven. All natural! ... Greeeeen heat!
ID:	201032   Click image for larger version
ID:	201033   Click image for larger version
Old 03-23-2010, 07:42 PM
GTO's Avatar
GTO GTO is offline
Finished wrapping. Used almost 200'.
ID:	201035   Click image for larger version
ID:	201036   Click image for larger version
ID:	201037   Click image for larger version
  #38
Old 03-23-2010, 07:45 PM
GTO's Avatar
GTO GTO is offline
Drivers side installed.
ID:	201039   Click image for larger version
ID:	201040   Click image for larger version
  #39
Old 03-23-2010, 07:49 PM
GTO's Avatar
GTO GTO is offline
Passenger side installed.
ID:	201043   Click image for larger version
ID:	201044   Click image for larger version
  #40
how much wrap did you use? 150' of 2'' or so?
