Old 04-05-2010, 11:36 AM
Hotrodizz Hotrodizz is offline
Default Started Tearing Down my 73 (lots of pics)
I started the tear down on my 73 TA friday night. I started by pressure washing the undercarriage and engine compartment. The car had been sitting in the AZ desert for roughly 20 years, so it is absolutely CAKED with brown crud. It was a filthy, messy job, but seeing the undercarriage and floors of this car tickle me to death. You rarely find anything this nice in Chicagoland. The pictures are after my first spray down.
The forward third of the car is still a mess, but once I get the drivetrain out, I'll have to go over it again.
1971 Trans Am 455LSX/T56 Clone
1973 Trans Am LS3/T56 in process
1977 Can Am....Sold
1973 Trans Am 455/Auto, White, # matching-Sold
1959 Impala TT LSX
1987 GNX #357
1969 Boss302 Clone w/Supercharged Coyote 5.0-Sold
2010 ZR1
2009 CTSV
www.speedinc.com
Old 04-05-2010, 11:43 AM
Interior Tear Down
Nice seeing the actual un-faded carpet color.
The rear window has rust on the LH side, so I was concerned about the rear floor on that side. Luckily, all the rust is superficial, and started to clean up very nice with just a wire brush.
1977 Can Am....Sold
1959 Impala TT LSX
1987 GNX #357
2010 ZR1
2009 CTSV
www.speedinc.com
Old 04-05-2010, 11:49 AM
I could use some suggestions on a few things:
-Removing the black residue from the sound deadner on the floor?
-Driver Side behind dash duct is cracked, upper behind vent, anyone have one to sell me
-Place to have radio checked/cleaned?
-Bezel restoration? Randy Combs?
-Gauge Cleaning/testing/painting source?
-Steering column rebuild service? Ive never tackled this one before.
Thanks in advance guys, I love the information on this forum.
Tom
1977 Can Am....Sold
1959 Impala TT LSX
1987 GNX #357
2010 ZR1
2009 CTSV
www.speedinc.com
Old 04-05-2010, 12:06 PM
superdutybob's Avatar
superdutybob superdutybob is offline
Wards Classic Car Radio is the place to send the radio. Search them on your favorite browser. There was an article in the latest Pontiac Enthusiast about gauge repair. Can't remember the place off hand. Looked like they did nice work.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
Old 04-05-2010, 02:23 PM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
that is alot cleaner than anything i have seen in years.nice car to start with,means nicer car to end with,and less money spent.good luck.
FREEDOM ISN'T FREE
BUT WORTH FIGHTING FOR
Old 04-05-2010, 03:39 PM
Xelerator Xelerator is offline
Wow, what a dream! More pics please!!
I can't believe all the white "overspray" on the underside, floors and underside of roof!!
Was your 73 a Van Nuys built car? Whats the build date on it?
I sense the start of an NJSteve style thread for a 73 TA!!
73 TA 4spd (in need of restoration)
http://www.aasencamaros.com
Old 04-05-2010, 03:51 PM
Thought I read all were Norwood cars in 73. Not certain that I am accurate on that...I also noticed my car seems to have more overspray than others I have seen.
1977 Can Am....Sold
1959 Impala TT LSX
1987 GNX #357
2010 ZR1
2009 CTSV
www.speedinc.com
Old 04-05-2010, 04:56 PM
Hmm, I know the camaros were either built in Van Nuys (L) or Norwood (N), I would assume the FBs were built in either L or N too.
Take a look at your cowl tag, what does it say?
Old 04-05-2010, 05:50 PM
Car isnt here at work, but I thought I read there was a strike in 73 so all were N built.
1977 Can Am....Sold
1959 Impala TT LSX
1987 GNX #357
2010 ZR1
2009 CTSV
www.speedinc.com
Old 04-05-2010, 06:05 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
Norwood, OH was the only plant building Camaro/Firebird from '72-77.
Old 04-05-2010, 06:50 PM
Sorry, my bad.
Still, it's strange to see that much white paint covering all the surfaces, maybe because mine being red it's hard to tell where the red ends.
Old 04-05-2010, 06:54 PM
Tom
Some may disagree but I have just used wax/degrease and it will come up in no time. I have never tried this but the "Super Clean" in a purple container may also break it down enough to remove it.
As a side note, please make note of all factory type markings:
-Suspension parts
-Drive Shaft
-Springs
-Brake Parts
Thanks in advance.
Old 04-06-2010, 09:47 AM
Will do.
1977 Can Am....Sold
1959 Impala TT LSX
1987 GNX #357
2010 ZR1
2009 CTSV
www.speedinc.com
Old 04-06-2010, 04:19 PM
Made a little progress last night. I removed the windshield and rear glass trim, as well as completely disassembled the doors and removed the glass. I was having a problem getting the RH latch screws to break loose, but hopefully after soaking in WD40 overnight, they will break loose tonight. I also removed the hood and disassembled everything in the cowl area. Unfortunately the cowl seal is toast, I assume no longer available through GM, so what is the best available aftermarket?
I hope to start on the front end sheet metal tonight.
1977 Can Am....Sold
1959 Impala TT LSX
1987 GNX #357
2010 ZR1
2009 CTSV
www.speedinc.com
Old 04-06-2010, 08:00 PM
The best way to remove the latch bolts is to heat them up. Do NOT try and use an impact (the kind you hit with a hammer) because the metal on this part of the door is very thin. Just use a torch or something similar to get it hot and use a screwdriver.
Old 04-07-2010, 01:33 PM
thefirebirdm@n's Avatar
thefirebirdm@n thefirebirdm@n is offline
Send a message via MSN to thefirebirdm@n
Please keep posting pics as much as you are able. I'm doing a lot of restoration work on my '73 as well and a lot of what I already took apart was a mess, missing pieces, mis-matched bolts so good pics of correct '73s certainly help. Thanks, great thread!!
Jimmy
www.firebirdgallery.com
2002 WS6 M6 Trans Am - original owner
1973 Trans Am 455/4-speed
1971 Formula 400/400
1969 GTO 400/400 - 3rd owner
1968 Firebird Convertible 350/200R4
POCI - AAC
Old 04-07-2010, 01:39 PM
I will post some more tonight or tomorrow AM. BTW, thank you for the AMK reference chart. I have your first version, and will be placing an order with them soon.
Got the nose off. Deciding how I should bring it to the body shop. I took the bumper reinforcement out of the nose because I want to paint it, but I also dont want it to get primer and paint overspray all over it. I am sure they will need it together in order to align/fit all the panels. I suppose they should fit it all, then disassemble it, paint the nose, then reinstall the reinforcement.
1977 Can Am....Sold
1959 Impala TT LSX
1987 GNX #357
2010 ZR1
2009 CTSV
www.speedinc.com
Old 04-07-2010, 05:59 PM
I did the same thing. Complete disassembled the nose and had it painted bare. I had all the brackets blasted and powdercoated and it came out great:
Jimmy
POCI - AAC
Old 04-08-2010, 10:23 AM
Bumper off
Although I located some good originals, I rough fit one of the ABS repros, which fits pretty well considering I didnt tweak it at all and the welting isnt on.
This is where the night ended
Still having trouble with the last door latch bolt. Doesnt seem to respond to heat or WD40. Guess Ill give it another go tonight. On another note, the only piece of front sheetmetal that needs to be changed is the battery tray
1977 Can Am....Sold
1959 Impala TT LSX
1987 GNX #357
2010 ZR1
2009 CTSV
www.speedinc.com
Old 04-08-2010, 10:24 AM
These 2 items were screwed to the LH fenderwell, any ideas?
1977 Can Am....Sold
1959 Impala TT LSX
1987 GNX #357
2010 ZR1
2009 CTSV
www.speedinc.com
