Old 05-04-2010, 05:05 PM
Hotrodizz Hotrodizz is offline
Old 05-15-2010, 11:09 PM
INTMD8 INTMD8 is offline
Nice work, that thing is unbelievably solid.
  #43
Old 05-25-2010, 01:08 PM
Few more parts restored
I was able to bring back the bezel luster with fine steel wool. Other than the lenses, I reused all other original parts, including the gaskets (which I put a coat of aerosol Plastidip)
  #44
Old 05-25-2010, 01:21 PM
SD73's Avatar
SD73 SD73 is offline
Interesting. You're kick down switch has the same resister soldered on the outside as mine does. I've seen many switches without that. Does anyone know the significants of that?
  #45
Old 05-25-2010, 02:39 PM
njsteve's Avatar
njsteve njsteve is offline
The resister mounted switch was the switch used primarily for the 72 T/As as it served the purpose of triggering the shaker solenoids. Even if you had a four speed car, you still got the resistor kick down switch mounted on the gas pedal bracket. I think the reason for the extra resistor was to somehow alter the voltage going to the solenoids. When was your car built? Pontiac dumped the working shaker option for 1973 and gave a $ credit back on T/A window stickers, but I guess they still used the same dual purpose kickdown switch.
  #46
Old 05-25-2010, 03:42 PM
SD73's Avatar
Mine is a first week of June '73 car, auto. It would be interesting to learn how this affects the voltage to the solenoid. I recall trouble shooting mine at one point and the flapper (I have a conversion) was opening intermittently and some times late. I noticed that the solder had come lose, but I also opened it up the case and cleaned it up a little and put 'er back in service.
  #47
Old 05-30-2010, 09:59 PM
thefirebirdm@n's Avatar
thefirebirdm@n thefirebirdm@n is offline
Send a message via MSN to thefirebirdm@n
Curious about the interior parts. Did you spray them with a gun or rattle can? I assumed you used vinyl dye. What brand? Thanks...
Jimmy
www.firebirdgallery.com
2002 WS6 M6 Trans Am - original owner
1973 Trans Am 455/4-speed
1971 Formula 400/400
1969 GTO 400/400 - 3rd owner
1968 Firebird Convertible 350/200R4
POCI - AAC
  #48
Old 05-31-2010, 10:51 AM
I used a gun with paint mixed for me by my local body shop supply house on thehard parts. I am using rattle can dye on the flexible parts since my supplier said they couldnt make it. I found that 73 Corvette uses the same interior color code and purchased it from one of the vendors.
The original rear lower side panels are badly sun damaged and have since bought another nice set. You can see in the picture that the color looks lighter in that area.
  #49
Old 06-08-2010, 05:35 PM
Got My new hood Latch
  #50
Old 06-08-2010, 07:25 PM
Norwood's Avatar
Norwood Norwood is offline
That looks prety good.....Do you mind if I visit the shop sometime to check it out?
http://cgi.ebay.com/ebaymotors/ws/eB...;3AMESELX%3AIT
  #51
Old 06-08-2010, 07:50 PM
We specialize in GM EFI, I'm restoring the TA at home, but you are of course welcome any time. Latch looks great BTW....
  #52
Old 06-11-2010, 04:26 PM
Gauges came back from Auto Instruments today
Just waiting on the bezel to return from Randy Combs.
  #53
Old 08-12-2010, 08:39 PM
Body shop was finally ready to take the car in, so I dropped it off today. HOPEFULLY some progress pics next week!!
  #54
Old 09-01-2010, 04:39 PM
The body shop sent me a quick picture of the stripped exterior
  #55
Old 09-02-2010, 11:43 AM
superdutybob's Avatar
superdutybob superdutybob is offline
Thumbs up
Hotrod:
You're doing a nice job on this car. I love these threads. So much to learn from others ways of doing things. Looking forward to seeing more of this.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
  #56
Old 09-02-2010, 01:01 PM
abefromen's Avatar
abefromen abefromen is offline
What body shop is doing the work?
  #57
Old 09-10-2010, 09:56 AM
Classic Cars of Mchenry County in Woodstock, IL.
1971 Trans Am 455LSX/T56 Clone
1973 Trans Am LS3/T56 in process
1977 Can Am....Sold
1973 Trans Am 455/Auto, White, # matching-Sold
1959 Impala TT LSX
1987 GNX #357
1969 Boss302 Clone w/Supercharged Coyote 5.0-Sold
2010 ZR1
2009 CTSV
www.speedinc.com
  #58
Old 10-07-2010, 11:18 AM
While waiting for the body shop on the shell, Ive been restoring some things here and there.
Thanks Norwood
I want to duplicate the paint markings on the rear end, I have some reference pictures saved to help duplicate them. I do have a couple questions...is there a quality, correct, assembly line decal kit? Ive seen them at a few vendors, but want to be sure to get the right one. Also, for the paint markings, I assume just get a brush and various colored paints to do this?
The subframe and A-arms are out for powder coating. Hopefully back this week so I can assemble it
  #59
Old 10-07-2010, 11:19 AM
ALSO, the front coil springs....I blasted them, and just coated them in "cast iron" paint. What color were they from the factory?
  #60
Old 10-07-2010, 09:12 PM
Father&Son73T/A Father&Son73T/A is offline
Hotrodizz,I have to see this car,amazing job you are doing,and I pass the body shop you speak of many times driving our 73 up to Wisconsin....wow!
1973 T/A Buccaneer Red L-75 A3,83k mi. #'s match
1979 T/A Atlantis Blue W-72 WS6 23k mi.survivor#'s match
1999 T/A Navy Blue 60k mi....babied
1968 442-gone but not forgotten
"Oh,you can think about it,.....but don't do it!"
Sheriff Bufford T.Justice
