Old 05-17-2010, 10:23 AM
garrity455's Avatar
garrity455 garrity455 is offline
Default blowing brake light fuse over and over
Hey guys. I keep popping the brake light fuse in my 79 trans-am. I know when it blows, the dome light goes out to. Easy way for me to realize it.
But I am not sure if it is the dome light or brake light that is causing the issue. There isn't some common issue I should look for is there?
Thanks,
mike
Old 05-17-2010, 11:13 AM
Pontirag Pontirag is offline
remove one bulb at a time and see if the fuse blows. make sure the bulb contact in the base of the socket does not touch or ground out when you remove the bulb to do this test. do all the brake light bulbs and the dome lite
Make sure the fuse you install is proper rating
check the light switch that turns one the dome light when the door opens.
check the brake switch up under the dash
check up under the dash for any moving parts that migh have worn away insulation
look in the trunk area for any damage to wiring that occured when something was put in the trunk(spare tire, jack cargo) that might have pimched or damaged wiring.
finally trace individual wires from power source to the dome and brake lites.
Old 05-17-2010, 11:49 AM
bankbook's Avatar
bankbook bankbook is offline
Look at the ground wire in the trunk coming off the harness.
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
Old 05-17-2010, 03:53 PM
77 TRASHCAN's Avatar
My car had a intermittant brake light problem. The left side brake would work most of the time. Every once in a while, the left sides would not work.
This is from when the car was NEW!!!
Do you think the dealer could figure it out, when it was under warranty???...
My car NEVER blew a fuse though...???
About 3 years ago I was driving it (car in signature) to work, one of my co-workers, noticed the LH brake lights out.........a couple of days later a small amount of smoke came out of the column, it stopped when I turned the ignition off, did not smoke again, although the LH brake lights NEVER worked again.
I tore the car apart, as suggested above...looked and looked for a short, physically followed ALL the wires through the car....
The final fix ended being, replacing the turn signal switch, yes the brake lights go through the T/S wiring....
Shut it off
Shut it off
Old 05-17-2010, 05:00 PM
ITSBACK's Avatar
ITSBACK ITSBACK is offline
If it was the dome light, it would blow every time you open the door right.
Old 05-17-2010, 10:52 PM
BB1968's Avatar
BB1968 BB1968 is offline
I had the same problem on my 68 GTO conv. It wound up being the turn signal switch. After I replaced the complete wiring harness in the column it took care of it. Mine had gotten corroded over the years and quit making a good connection. I had already replaced all the sockets for the bulbs and made sure all the grounds were in good shape. Maybe this will help.
Old 05-18-2010, 11:20 AM
bnorris_74's Avatar
bnorris_74 bnorris_74 is offline
My 79 Bonne would blow the interior light/brake light fuse but my problem was in the radio wiring harness. (I would lose power to the radio at the sime tome).
Found a bare wire.
Brian
Old 05-18-2010, 07:02 PM
ITSBACK's Avatar
Does it blow the minute you step on the brake and every time?
Old 05-18-2010, 07:03 PM
ITSBACK's Avatar
Don't forget, it does not have to be a ground to blow a fuse. A loose connection can do it as well. A loose connection is a high resistance connection, I have seen it happen before.
Old 07-09-2010, 05:43 PM
garrity455's Avatar
Just thought I would post what I found. I thought it was the dome light wiring, (on same fuse) but it wasn't. It was the trunk light socket. I don't even have a bulb in there. But finally realized the fuse popped, whenever the trunk popped. I just disconnected the trunk light(since I didn't use it anyway) and the problem is now solved. Just wanted to share. Thanks, Mike
1979 Trans-Am. 3900 + lbs.
3.42 gear, 10" 4000+ Continental, 280 cfm e heads, performer rpm, 750 Holley, 242/248 HR cam, 10.2 to 1, 11.31, 117.2 mph, 1.49 60'.
Old 07-09-2010, 06:15 PM
bnorris_74's Avatar
Thanks for the update.
Electrical gremlins are the worst.
Someone can use this update in the future.
Brian
