Old 05-29-2010, 12:01 PM
1971GTO's Avatar
1971GTO 1971GTO is offline
Thumbs up Rear upper control armbushings at diff.
Here's a close up of one of the last two rear control arm bushings needing replaced; The uppers at the differential "ears". The car has been a driver, and is all together, so I have to replace them in the driveway.
So, I'm making a press-in tool out of 7/16" threaded rod+nuts, 2" i.d. metal pipe and some scrap steel plate. I won't cut the rod to length yet, until I answer this question:
Looking at the picture, it appears to me that the only significant part of the press-in that's going to be most difficult is the widened "shoulder" on these bushings? Essentially the last 1-1/2" of travel into the "ear".
Got all weekend to ponder and make this tool. Am I screwed up in my thinking?
Thanks!
1971 GTO: Quezal Gold, non-R/A 455HO, TH400, 3.55 Safe-T-Track, 1 of 412.
turns in 13.4@101 miles per, "Hey these 'ol GTO's haul ass"!
Old 05-29-2010, 12:22 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
your right, the press fit part is the last 3/4" just under the collar of the bushing.
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
Old 05-29-2010, 01:02 PM
1971GTO's Avatar
Good deal! Makes install alot less anxious, can fer-sure up my tool as well.
Old 05-29-2010, 04:37 PM
rontiac's Avatar
rontiac rontiac is offline
I just made the same tool at home using 1/2 long bolts and such! It worked well removing the old bushings. Looks like I have the same type of bushings going in as you do.
I have a question though, where does the extra rubber sleeve go when assembling the bushings? It's next to the bushing in your picture. Does it get installed on the bushing before pressing on the rear axle housing, so it acts like a spacer?
Thanks!
Ron M.
http://forums.performanceyears.com/forums/image.php?type=sigpic&userid=143670&dateline=12211  78868
1965 LeMans Post Coupe..............I'm not waitin for the undertaker....I'm lookin forward to the uppertaker!.....
Old 05-29-2010, 11:08 PM
FatfreeGTO FatfreeGTO is offline
The last part of the collar that is raised up does not get pressed into the ear on the diff. It just butts up against it. The other collar is used as a spacer between the inside edge of the diff ear and the control arm side itself. Its used to prevent deflection/twisting.
William (BJ)
1966 Pontiac GTO
Old 05-30-2010, 12:54 AM
rontiac's Avatar
Now I get it! That makes sense. Thanks for the pix and the explanation FatfreeGTO!
Old 05-31-2010, 09:31 PM
No problem glad to help when I can!
William (BJ)
1966 Pontiac GTO
Old 03-21-2011, 10:12 AM
1971GTO's Avatar
Thumbs up Rear Upper Control Arm Bushing un/installer
Well, another year later and Summer's almost here; time right now to ponder more jobs to address on the GTO.
Last year I replaced all the rear suspension bushings while on the car, except the uppers at the diff. This year I'm gonna' do that myself in the D/W.
This is the tool I developed at the end of last summer, so had a long time to ponder if it'll really work to press them in or out. FatfreeGTO's picture was very helpfull although my room is more confined. Realisticly, I think that getting the old bushings out come's down to drilling out the rubber and chisel/crush out the sleeve; this tool may be too cumbersome for that aspect when all that's required is elbow grease and a BFH. I'll try out this tool first for sure anyhow.
When installing, I think that if I take alot of extra care to cold hard-freeze/grease the new bushings REAL good & clean up the old ears/and heat them well enuf just before, It'll work fine. It still could take a few taps to get in the ears all the way I suppose.
This tool="waste of time" and around $8..............we'll see. I was pondering having a local jobber put these bushings in for me, could be $250 there!
Any other comments of this tool creation, or success stories of folks accomplishing this work while on the car?
Later,
Mike
ID:	238733   Click image for larger version
ID:	238734   Click image for larger version
Old 03-21-2011, 10:42 AM
67drake's Avatar
67drake 67drake is offline
I use my torches to burn the rubber out,or most of it,then collapse the old bushing with an air chisel. Might not want to go this route if the rear end is still on the car,and should be done outside.
For installing the new one,I used a ball joint press,rented free from the auto parts store. Clearance was a little tight between the press and the rear,but after it went in the first 1/2" or so,it pretty much slid right in. I also slathered some grease around the outside of the bushing before installing,and put the bushings in the freezer for an hour or so before I start to shrink them a little.
‘55 Catalina
Old 03-28-2011, 11:07 AM
This video is helpful for getting the bushings out. I basically did the same thing to remove mine.
http://www.youtube.com/watch?v=UPXf1OR9Lnk
And for install I did exactly this
http://www.youtube.com/watch?v=DPMd2x_DYxc
Again my rear end was out of the car but i would think its possible to do if the diff is still in the car.
Good luck!!
William (BJ)
1966 Pontiac GTO
Old 03-28-2011, 11:25 AM
67drake's Avatar
That 1st video where he pulls the rubber out with the drill bit was nice. I'll have to try that.
‘55 Catalina
Old 03-28-2011, 11:31 AM
grandville455's Avatar
I did that on my front bushings in the A Arm used a drill to drill out the rubber then it pretty much comes right out
Darby
M/T 275/60 ET SS Drag Radial
Old 03-28-2011, 12:51 PM
02Hawk's Avatar
02Hawk 02Hawk is offline
These guys make a decent one...I bought it several years ago and have used it many times
http://www.hrpartsandstuff.com/priceorder.htm
24 beer in a case. 24 Hours in a day. Coincidence? I think not. " Steve Wright"
Old 03-28-2011, 05:13 PM
russosborne's Avatar
russosborne russosborne is offline
From their description it sounds like that is only for the 2 upper bushings on the axle housing. Have you tried using it on the other bushings?
Thanks,
Russ
Old 03-28-2011, 05:24 PM
Tim66 Tim66 is offline
Send a message via ICQ to Tim66
Default control arm bushings
I just finished taking my bushings out and I didn't drill out the rubbers, I just hit them with a hammer until flush with housing and then using a dull chisel I tapped around the flared end of the bushing until it was out, on the control arms themselves they practically flew out with just the 5lb sledge.Good luck,Tim.
Old 03-28-2011, 05:26 PM
Oh yeah, I sprayed them the day before with PB blaster.
Old 04-03-2011, 08:11 PM
SRR's Avatar
SRR SRR is offline
Thumbs up Agreed!
― Calvin Coolidge
