Old 06-10-2010, 12:37 AM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Very nice, keep up the good work and have fun with it!
Grant
  #82
Old 06-10-2010, 08:31 PM
Pics of interesting stuff on this car.
Last pic highlights the pad marks that held the hood when it was painted at the factory.
Next to last is the P/S cooler I was suprised to see.
Never seen the Ink stamps on a convertor before, nor the front pump, nice to find the paint daub on the Steering box also.
ID:	208743   Click image for larger version
ID:	208744   Click image for larger version
ID:	208747   Click image for larger version
ID:	208748   Click image for larger version
former." --Albert Einstein
- Winston Churchill
  #83
Old 06-10-2010, 08:44 PM
Two piece rotors
Indexing ink on the spindle
Drum tag on the Diff, LR
Paint marking on RR drum / axle
RF Body bushing still in blue
ID:	208750   Click image for larger version
ID:	208751   Click image for larger version
ID:	208752   Click image for larger version
ID:	208753   Click image for larger version
- Winston Churchill
  #84
Old 06-10-2010, 08:48 PM
Before with OE hubcaps
After the Vintage AR200's
ID:	208755   Click image for larger version
- Winston Churchill
  #85
Old 06-10-2010, 09:14 PM
Stuckinda60s Stuckinda60s is offline
Looks like a real step up, Mike. No stitch marks like Frankenstein's monster.
Anyway, it's nice and looks like it has a lot of potential.
Rich
The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance.
Henry Ward Beecher
"The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher
  #86
Old 06-10-2010, 09:45 PM
428ho4spd's Avatar
Cool pics Mike! The drum tag is your rear axle code, amazing that its still there! "2F" is a 3.23 open. Same stamp code will be on the driver's side axle tube as well. Neat stuff!
Grant
  #87
Old 06-10-2010, 10:24 PM
I can see what I assume is the build sheet poking out from under the fuel tank insulator also. I've not taken the time to pull the tank to retrieve it yet tho.
- Winston Churchill
  #88
Old 06-11-2010, 09:52 PM
Keith Vrabec's Avatar
Keith Vrabec Keith Vrabec is offline
Burnout photo for Car Craft????
  #89
Old 06-12-2010, 10:40 AM
Not gonna happen Keith, I need to drive this one for the summer.
MIke
- Winston Churchill
  #90
Old 06-12-2010, 06:03 PM
2manyponchos's Avatar
2manyponchos 2manyponchos is offline
MIke
What does that have to do with a good burnout picture??
P.O.S.I - It's not just a club...it's an addiction!
  #91
Old 06-12-2010, 09:06 PM
Everything. This thing's only been out on hot lap runs since it was parked over 30yrs ago. I'm not gonna kill it before I get to drive it!
- Winston Churchill
  #92
Old 06-13-2010, 11:13 AM
What do you mean? Mine sat 18 years before I flogged it for 2 weeks and now a rod is knocking. Wait...I think I just answered my own question. =)
  #93
Old 06-13-2010, 01:17 PM
I'm not concerned about this engine, it's the rest of the driveline I don't trust!
Mike
- Winston Churchill
  #94
Old 06-13-2010, 07:29 PM
JLHarper's Avatar
JLHarper JLHarper is offline
Mike,
I havent read the thread so dont know if you need parts..but: a member in FIREBIRD PARTS FOR SALE section under ad: 64-80 Firebird and GTO Parts has two 69 GP doors for sale.
Just a FYI if they are hard to find......they are burried in his long ad.
Jeff
  #95
Old 06-13-2010, 10:36 PM
Jeff I saw them, I'm not sure what I'm going to do with the door yet. I may pull it and see how it looks. I may get lazy and replace it. I've got a line on a rust free used one that's relatively close.
Mike
- Winston Churchill
  #96
Old 06-15-2010, 06:19 PM
Changed the RR axle seal today. Pulled the axle,sat it on the floor shaft up picked it up to reinstall it and a stud broke in two when I picked it up!
Needless to say all the lug studs are getting replaced!
Registered it also, installed the plates not happy with the bolt/ nut setup the P/O used.
Still need to do the front studs and pack the bearings.
Mufflers and T-pipes will probably be installed Wed or Thurs.
Planning on a shake down run Sat.
Mike
- Winston Churchill
  #97
Old 06-15-2010, 08:08 PM
pontiac6269's Avatar
pontiac6269 pontiac6269 is offline
I like posts like this. Sweet ride.
Eric
1969 GTO - 461, turbo 400, Continental 13", 3.08 gears. - 12.59 e.t. @ 108.43 mph, 1.898 60'
1978 Oldsmobile Cutlass Supreme- 461, turbo 350, PTC 3500 converter, 9" 3:50 gears. = 11.39 e.t. @ 117.55 mph, 1.599 60' on E85
  #98
Old 06-15-2010, 09:45 PM
Hopefully this documentation will help someone restoring one back for points.
When I restore this car I'll need them also!
Mike
- Winston Churchill
  #99
Old 06-16-2010, 10:40 AM
Got the fuel guage working yesterday afternoon, turned out to be a poor conection between the tank sender and the wire. Functions now.
I got a SERIOUS itch to drive her and took her out for the first semi major shakedown run last night. About 100 miles of backroad cruising. No major problems short of the fact that I burnt the rest of the Mufflers out, sounds like open headers now. That's gonna change., I couldn't keep a conversation with myself let alone anyone else!
- Winston Churchill
  #100
Old 06-18-2010, 10:28 AM
Exhaust ran last night, RH tailpipes are a bitch on these cars. Ended up making in two pieces.
I'm seriously thinking about a Pypes system on her when funds loosen up a bit. Did another hundred miles last night. Control arm bushings are going to be a must in the front but other than that no big issues I can see. Will know more tomorrow as I'm taking it to a B-day party about 90 miles NE of here. We'll see how she does then.
Ran into an interesting issue with her. The Ceramic pads I put on the front are dusting the wheels. That's gonna change and soon, but this is the first set out of well over 200 that I've installed that does this. Car stops well just turns the wheels black on the front. brakes aren't dragging, calipers aren't sticking but these will filthy up the wheels in 20 miles of normal driving.
A/C will be next when I get time.
- Winston Churchill
