Old 08-24-2010, 05:10 PM
JP_79Formula's Avatar
JP_79Formula JP_79Formula is offline
Good description.
You nailed it, i'm worried that if i pull this apart i won't be able to get it working again.
But, i can't tell if i Have to remove the lever pivot to get the broken end out, it looked to
me that it was corroded/glued in, so the lever assembly needs to come out, this fine piece
of work needs some kind of award:
http://forums.maxperformanceinc.com/...8&d=1281465188
looks like joe handyman tried to hone his automotive repair skills with a jigsaw...
maybe i'll try poking it out, but i get the feeling that the pivot needs to come out...
  #42
Old 08-24-2010, 06:14 PM
Default MOY
Well, here it is. Got the pivot out.
As suspected, it looks like the 'repair' approach was to:
a) drill out the lever socket
b) jam JB-Weld and broken lever back into socket.
My mind is full of words that shouldn't be written, suffice it to
say that i have a nomination for Moron Of The Year (MOY).
The JB-Weld strategy was so effective that it flowed around the broken shaft
end and prevents me pushing out the free end, can't even see where the shaft
key lines up with the keyway. Maybe i can drill it out... :}
So i guess i need to find a replacement assembly... any ideas ??
ID:	216419   Click image for larger version
  #43
Old 08-24-2010, 07:00 PM
Ollie's Avatar
Ollie Ollie is offline
JP_79Formula.
Yep, that's a piece of work all right.
The key way appears to be that square area at the top of the photo.
Its ok to giggle and snicker, Dont laugh and point
  #44
Old 08-24-2010, 07:03 PM
GStage1's Avatar
GStage1 GStage1 is offline
Go to your local u-pull-it yard and get another set-up...those are found on all GM cars and trucks of the same year...78-83...so for a few $$$, you will have it fixed.
George Nenadovich
Buick Performance Club Founder
www.BuickPerformanceClub.com
  #45
Old 08-24-2010, 07:35 PM
Ollie's Avatar
JP_79Formula
When you removed the pivot is that a roll pin or a screw, you removed on the lower left.
circled in red.
  #46
Old 08-24-2010, 08:04 PM
The pivot assembly attachment is just a pin, slides out.
Problem is, there aren't many u-pull its down here... too many Lawyers!
and most i have seen have 90's+ cars. I'll have to check.
  #47
Old 08-24-2010, 11:41 PM
beastmaster's Avatar
beastmaster beastmaster is offline
I'm right there also. i drilled this one out with not to much damage.
ID:	216464   Click image for larger version
84 T/A
w/ IA 2 -- 505 N/A
w/ Tiger heads / BOP intake. "Best time" [email protected]/1.28 60ft.
77 Firebird formula 463 w TRW dome
pistons w/ 4x's /edelbrock performer
http://www.youtube.com/watch?v=KK163BxD9EY
  #48
Old 08-25-2010, 11:05 PM
azkeebler's Avatar
azkeebler azkeebler is offline
Jp_79formula,The pivot assembly I pictured earlier is available for purchase. Pay for shipping and it's yours ($5.00). I thought I threw it away as it was. Send me pm if interested.
2-1962 Lemans convertibles 4cyl, auto
1962 Tempest safari wagon (running project)
1972 455 Formula (tribute)
1962 Skylark convertible 215 4-barrel , auto
2009 G8 Sport red metallic, Onyx leather
Whatever else that make my way into the driveway
