Old 10-24-2010, 02:54 PM
Firebob's Avatar
Firebob Firebob is offline
Default Emergency Battery Cut-off
Last time I was at the track the tech guy said because my batt was moved to the trunk I needed and emergency battery cutoff accessable from the outside of the car. So I bought an extra taillight to drill through and I'll mount the switch inside with a pull rod out the back.
My question is should the switch be in the + or - cable?
Robert
Old 10-24-2010, 03:20 PM
WDCreech's Avatar
WDCreech WDCreech is offline
The rule book says it is to be on the positive side.
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
[email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
Old 10-24-2010, 04:50 PM
Firebob's Avatar
Thanks.
Old 10-24-2010, 05:22 PM
Polar-Pontiac's Avatar
Polar-Pontiac Polar-Pontiac is offline
You will need to run a #6 cable to one side of the switch the other end to your alternator.so it kills the car.That if you run a alternator.
Old 10-24-2010, 06:10 PM
And the OFF position is pushed in on the rod.
