Old 11-12-2010, 01:12 AM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Default Anyone Running the Mickey Thompson 295/55/15 Tires?
Couldn't find anything in the searches for this Section or the Suspension but curious if anyone's running these tires? I'm about to get them as a holiday gift and wanted to see what other GTO members thought about them.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
Old 11-14-2010, 05:08 PM
n20ta2's Avatar
n20ta2 n20ta2 is offline
are they standard radials or drag radials?
1969 GTO street strip project 11.1 forged 461, highport heads
1995 Trans-am 420 ci sb 14:1 compression 9"ford
9.89@132 1.34 60ft SOLD!
Old 11-15-2010, 12:35 AM
GOAT8U2's Avatar
The Drag Radials, they're almost 28" tall and 11" of tread so it's a winner for the GTO's wheel well.
Old 11-16-2010, 07:14 AM
n20ta2's Avatar
yeah they fit,im running the 315 60 15 drag radials,they are a great tire.this is my third set,last set was on my ta in the signature.
Old 11-17-2010, 09:28 PM
Texasoldgoat Texasoldgoat is offline
I might have to go bigger like you guys. I just put on Nitto street slicks 275/50R15s and I can't get them to hook up if I nail it at 60+. But I still love the torque.
Old 11-18-2010, 07:37 AM
n20ta2's Avatar
yeah that is a small tire.
