Old 01-28-2011, 11:52 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
Default Plastic Lower Door Panel Fix
If you have the '72 and later plastic lower door panels that are warped at the map pockets, I thought I'd post this fix in case it will help someone. Mine were warped out away from the door about 1/2" to 3/4" in the inner wall of both of the front and rear pockets. I tried everything from glueing wood sticks to the back, to hand shaping with a hot blow dryer, to adding 2 part cement to the back of the warped panel for stiffness, all with no luck. What finally worked was simply using a large space heater and stuffing shop towels into the pockets to reverse the bulge. Here is a pic...
I used the rags in the pocket to slightly reverse the curve and make it bulge back toward the door. Then I set the heater on high and propped the the backside of the panel about 1" away from the grill for about 2-3 minutes. When the backside of the plastic on the pocket was hot enough to scald my finger I took the panel away from the heat and moved it to a cold area to cool, with the rags still in place. You may need to hand shape the top edge of the pocket a little at this point to get it back towards straight while its still hot. Then leave the rags in place with just enough pressure on the pocket to keep it straight all night and let it cool completely.
It will be interesting to see how these hold up to the heat of summer but so far they look much better and seem to want to stay in the new position. Now I just need to redye them, they could use some SEM Landua Black.
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
Old 01-29-2011, 12:11 AM
Formulabruce's Avatar
I am impressed, I see alot of car had screws put in for that problem, thats great!
" Long may we DRIVE !"
Old 01-29-2011, 09:47 AM
72TAMAN's Avatar
72TAMAN 72TAMAN is offline
I agree because I have on of them
ANDRE
1972 TRANS AM , UNDER RESTORATION
http://forums.maxperformanceinc.com/...d.php?t=656067
1972 FIREBIRD FUTUR PROJECT
http://forums.maxperformanceinc.com/...d.php?t=674551
1978 TRANS AM (PARTS CAR) MAYBE
1971 LEMANS T37 (PARTED OUT)
1976 TRANS AM (PARTED OUT)
1984 6000LE (SOLD)
2003 SILVERADO 1500
Old 01-29-2011, 10:17 AM
666 the legend's Avatar
666 the legend 666 the legend is offline
I used...WOOD BLOCKS and clamps and a HEAT GUN..Worked out good for me..
Old 01-29-2011, 10:28 AM
1971455HO's Avatar
1971455HO 1971455HO is offline
Thanks for posting this. Mine are the different 70-71 type, but the principle is the same. Good info.
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
Old 01-29-2011, 12:16 PM
Tunas73TA's Avatar
Tunas73TA Tunas73TA is offline
I dont know what you are talking about......
Thanks for a great tip. I was going to try a heat gun and a wet rag, but I think you are right about a much bigger area needing heated
chuck...
1973 455 TA (07A)
