Can anyone tell me what columns 74-80 are for on the billing history sheet? The larger sheet that show options that I received from PHS stops at 73. I have a number 2 in column 74, and cant find what that references. I will appreciate any help decoding my PHS. Thanks
I think Jim Mattison told me once that they to do with stuff like shoulder belts. I believe shoulder belts were not Federally mandated until 69. So some 68's may not have had factory installed shoulder belts. I have seen codes 731, 742, and 754. Scott
I have 742 on my PHS also. Don't know what it means. I have 754 which is for shoulder belts as said above.
731 - air cleaner, dual stage
I have several PHS with 742 - ??
'68 GTO 4-spd Hardtop (11) '68 GTO Convertible AT (1) '70 LeMans Sport Land of Lakes Muscle Car Classic Facebook Event Facebook Wall (Kurt Smith,Minneapolis) |
I have another question on column 34 (engine) there is a 5. On the option order form 5 is not listed, it has numbers 1-4 then 6 and 8? I also see 49 4 what is that?
345 is not on the options list because it was standard equipment - the 400/4bbl engine was standard for the 68 GTO.
494 is Rally Stripes 754 is Front Shoulder Belts
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
Thanks to everyone for the help! I don't think I have ever seen rally stripes on a GTO any one have a picture?
It's just a double pinstripe that runs from front to rear above the lower style line. Someone probably has a better photo but my first GTO that I bought in '82 had the stripes. You can just barely make them out in these photos. Look right below the GTO shield on the fender and right above the rocker extension behind the wheel opening on the quarter. Second pic, right ahead of the wheel opening. ![]()
Greg Reid Palmetto, Georgia Last edited by Greg Reid; 02-07-2011 at 01:49 PM. |
I take it the billing sheet '74' isn't the same as '74' on the buildsheet?
K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.56 @ 139 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
I initially thought it might be for tires or spare tire/wheel.
Looking at Eric's blank Build Sheets it hard to say. I don't have many 68 sheets that are legible, I have one for 69 which doesn't match Eric's 69 sheet though. Evidently different plants had different styles. (Mine is an Arlington car) A lot of my 69 sheets show NG-5 in 74. ????????
Here is the info sheet:
Check post #5 here on 742 code http://forums.maxperformanceinc.com/...ght=order+form
Leo |
Some other questions have come up...My GTO has power steering but it is not checked on the billing history? Also about 10 years ago I had the gas tank out of the car if I remember right it had 5/16" fuel lines. Is that correct for an original 4bbl. 400?
71 & 72 are tires John.
For example a P in 71 and a C in 72 would be G70 Wide Oval Red Line Tires.
I saw that, that's why I thought maybe it was for a spare tire or wheel since it was below the 71/72.
![]() Most didn't show anything in 74 so figured it would be for standard spare/wheel. Some of the 70 sheets (which looked like the 68/69 sheets) had the NG-5 or 4 digit numbers. ![]() From that other link, it could just be an internal use thing. But why would it be down there? Possibly it's for how the spare tire mount in the trunk was welded on? Or? ![]()
How about dealer codes anyone know how to decode that?
Zone 09 Dealer 337 not listed on Wallace site? Anyone know that dealer code?
