#301
Anyone need the following parts?
70 lemans grille mount parts
#302
Free to a good home, . The coffee can is full of screws, pull-offs, fast idle solonoids, do-dads and whatchamacallits, a few hangers and secondary metering rods as well. Just pay shipping or pick up: $10.70 or $14.50 for flat rate boxes.
[email protected] Last edited by DOC; 12-31-2010 at 06:38 PM. Reason: add email |
#303
Thanks! - Jason
Jason Rackawack 1975 455 Trans Am - 1975 Firebird 400 |
#304
Jason, They are on the way! Email sent w/ the details.
Doug |
#305
Big box of carb stuff arrived and has a lot of what I need,
Thanks alot! I wish everybody was as easy to deal with as DOC. ![]() On sunday I'll take some photos of some freebies to post on here in case anyone needs them. I've gotten alot of favors on PY lately and I'd like to add a deposit to the "Lucky Break Bank"
#306
im looking for a 90* oil filter housing. not sure it isnt going to create more problems then it will solve but I'd like to see how it fits. thanks in advance
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
#307
got one thank you Ron Genovese!
#308
Here's a freebie, send me the shipping cost and its yours,
I think it will fit in a USPS $5 priority mail box. New in package Comp Cams 1" carb spacer for standard Holley Square Flange. Part #VH311 Shoot me a PM and I'll arrange shipping details.
#309
Free to good home, just send me the actual shipping costs.
Aftermarket Rear Drivers Side Wheel Spoiler for 70-78 Trans Am -Perfect for race car or low buck driver that needs repair. -It mounts to wheel well lip -No inside mounting points included, it must be fabricated if needed. -I belive it was made by A&A Fiberglass in the 1990s -It is made of flexable polyeurothane -Part Number 53614-LS -I only have this one - I do not have the other three PM me your shipping info and I'll get a quote on the actual cost. Jason
#310
GONE!
The carb spacer is spoken for, Awaiting shipping payment.
#311
I'm looking for a 4 bbl throttle cable bracket for a '72 LeMans.
thanks
Drew ![]() Fifteen hundred years ago everybody knew the Earth was the center of the universe. Five hundred years ago, everybody knew the Earth was flat, and fifteen minutes ago, you knew that humans were alone on this planet. Imagine what you'll know tomorrow. - K (from MIB) 1972 LeMans Sport convert (T41) '70 XF 455, TH400, 3.31 12-bolt Posi |
#312
This is not performance parts, but maybe someone can use it. I have a rear defogger housing, gasket and grill for 1968 and back. Pay shipping and it's yours.
http://s1133.photobucket.com/albums/...t=IMG_7233.jpg I could use a good thermostat housing for a 1969. Mine is pitted too bad to use. |
#313
I have a used " 4 hole phenolic carb spacer, in perfect condition. (moroso 64930).
Shipping should be $5 or less. I am looking for engine fasteners for intake, oil pan,(need one pan rail reinforcement), water pump etc.. I don't want to strip my original motor for this build. I also need the linkage rod for a 1972 divorced choke (4V). I have the coil and cover. Defogger parts are taken. Thanks |
#316
antiquelemans: I have fasteners from an original '72 GTO 400 for the oil pan (w/corner reinforcements) and intake (it was a Performer intake). Will be glad to trade for the spacer, or just send you the bolts if someone has already spoken for the spacer. Let me know.
DAve |
#317
Spacer is yours. |
#318
74 Formula Below motor destroyed fall of 2023 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.061 @ 110.74 12.092 @ 112.43 12.128 @ 111.71 461 stroker Edelbrock 87 cc dport heads Performer RPM Same Ram Air manifolds, and quadrajet 75 Formula 400 / 4-SPD matching numbers |
#319
Bump, still got these also
#320
Jobstown, NJ 08041.... I found three 1970 GTO grilles in the scrap yard. One side with emblem, and two of the other side. I removed the GTO emblem, and used it for display on my shelf. Does anyone local need the grilles? I can take pictures, or describe them, but I'd rather not ship them. There's no charge, as long as you need them for your car. (Emblem not included).
I'm looking for a good, ready to bolt in, th350 Pontiac transmission with converter, for my 66' Tempest. Does anyone have a cheap or free one in NJ? |
