Old 04-26-2011, 01:33 PM
outlawgto outlawgto is offline
Default Mounting AC compressor with tall valve covers
Anyone have options for mounting a stock ac compressor when you have tall valve covers?
Steve
Herndon, VA
Old 04-26-2011, 05:42 PM
Lemans1970 Lemans1970 is offline
I presume you are concerned with clearance between the passenger side valve cover and the mounting bracket that bolts to the intake. Depending on how much additional clearance that you need, you could probably just put a couple of spacers (bought washers or fabricated spacers) underneath the bracket. Hopefully it wouldn't be so much that you need longer bolts and still have enough leeway for belt adjustment. JMO
