Old 07-25-2011, 11:01 PM
ron cozzo's Avatar
ron cozzo ron cozzo is offline
Matt, I bet that bracket is the same one shown in the parts catalog used on '63 tempest 4cyl. Same name, same bolt layout. Here's the 63 diagram:
Name:	63 diagram.jpg
'04 GTO Yellow Jacket, A4, Kooks, CAI, etc.
'02 Firebird, V6, auto
'68 GTO Convertible, HO, 4spd, driver
'66 LeMans Hardtop, 400, FI, A/C, 4L80E.
'65 GTO Hardtop, next project
'64 GTO Hardtop, "389", Tri-power, 5 speed, A/C, Yorktown Blue.
http://www.gtoaco.com
Old 07-25-2011, 11:04 PM
ron cozzo's Avatar
Here's the '63 illustration list:
Note number 46 on the '63 list is worded exactly the same as number 19 on the '64 list.
Old 07-25-2011, 11:08 PM
ron cozzo's Avatar
And here's the '63 part number, which I think is the same part for '64:
If true, you can now also shop for '63 4cyl A/C car parts. Hmmm, maybe rarer than '64's with A/C
Name:	63 support.jpg
Old 07-26-2011, 11:49 AM
mwritter's Avatar
mwritter mwritter is offline
Thanks again Ron...the info I have is that the '64 front plate is part # 9774771, which makes sense since the cast bracket is 9774770. So I'm assuming it's different than '63 Tempest but maybe not!
Either way, thanks for the diagram, it's the best image I have of that aluminum spacer.
Matt
1962 Grand Prix - Cameo Ivory|389 4sp|One-Owner Survivor
1964 GTO HT - Silvermist Grey|389 3x2s 4spd|A/C|Hurst Wheels|Frame-off|SOLD
1965 GTO Post - Mayfair Maize|421 3x2s TKO600|Pro-Touring|
1966 GTO HT - Barrier Blue|389 3x2s 4spd|Red Fenderliners
2005 GTO Coupe - Yellow Jacket|Magnacharged LS2 6sp|543hp/561tq|SOLD
2006 GTO Coupe - Spice Red|LS2 6sp|20k orig miles
Old 07-26-2011, 10:26 PM
BOB VIDAN BOB VIDAN is offline
The aluminum bracket for the 63 4 cyl w/AC is not the same as 64 GTO w/AC. You want bracket 548413 as is in the picture. This is used with the 771 front adjuster plate and the 770 to the head mounting bracket. I have an extra if you are needing one. PM if so.
Old 07-26-2011, 10:54 PM
ron cozzo's Avatar
Bob comes though again. There you go!
Interesting part no. 548413, I can't find it anywhere in my '66 parts manual. But 548411 and 548412 are 63 T/4-T/8 Front and Rear Plates.
Bob, I'm assuming you got the part number from the casting, or is there a listing in a different year parts book?
Old 07-26-2011, 10:59 PM
It's on the part and shows in my 64 MPC, group 9.171
Old 07-26-2011, 11:10 PM
ron cozzo's Avatar
Thanks Bob, I need to get a '64 MPC I guess.
Old 07-27-2011, 08:30 AM
mwritter's Avatar
Thanks Bob, you are a life saver - I sent you a PM.
Matt
Old 08-22-2011, 11:25 AM
mwritter's Avatar
Just to close this out, with Bob's aluminum spacer, a front plate I found mislabled as '66 big car on eBay, a repop rear bracket, and the correct cast mount from Frank's Pontiac Parts all problems solved. I've got clearance around the upper rad hose, the upper arm from the intake fits without a spacer, and belt alignment is good. Only issue I've still got is around the dipstick, but I can live with that. Thanks everyone for the help.
Matt
Old 09-08-2011, 09:13 PM
RA1John RA1John is offline
Who makes the repop Rear Bracket?
(Compressor to Intake)
John
'68 Firebird Ram Air 4-spd Conv.
John 14:6
Semper Fi
Old 09-09-2011, 09:55 AM
Regarding the A.C. Compressor Rear Brace...
Many thanks to Bob Vidan for helping to clarify the applications for this Brace (and for providing one of the elusive 'Tri-Power styles!).
If someone is reproducing the standard version, one would think it wouldn't be any more expensive to do the Tri-Power version. Laser cut blank w/2 form-bends?
John
John 14:6
Semper Fi
Old 09-09-2011, 10:05 AM
As you can see, it's not very easy to discern the dimensional difference between the 2 Brackets...
John
John 14:6
Semper Fi
Old 09-16-2011, 04:04 PM
mwritter's Avatar
I was referring to the lower rear mount bracket, which PY sellls under RPE689, 63-70 AC Rear Compressor Bracket, triangular shaped.
Matt
