Old 08-19-2011, 04:58 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Originally Posted by Region Warrior View Post
Who's make'n the Super 400 again?
Tim Hansberry http://www.hansberryinc.com/index.html
Route 724 PO Box 391 Parkerford, PA 19457 1-610-495-5344
I'd expect we'll have Steve's hood within 2 weeks.
Bolt-On and Pin-On are available, both come with the raised cowel panel.
  #242
Old 08-25-2011, 10:10 AM
mikes2nd mikes2nd is offline
I called Hansberry about a bolt on trunk and a full pro front clip for a 70 gto...
Second day they answered the phone... been two days with no response if they make the parts...
guess ill try vfn or glasstek
  #243
Old 09-01-2011, 11:56 AM
RAIV-Z's Avatar
Latest update: Bolt-on Super400 hood finished yesterday.
  #244
Old 09-01-2011, 12:47 PM
Region Warrior's Avatar
Thanks RAIV-Z.
Been on list since Paul Spotts sold'm.
Time to save up again...
  #245
Old 09-01-2011, 12:58 PM
RAIV-Z's Avatar
This one is for Steve's 67 firebird, we'll trial fit it and take some pictures with it on my 69
  #246
Old 09-16-2011, 03:51 PM
RAIV-Z's Avatar
Bolt-On Super 400 hood arrived today.
  #247
Old 11-30-2011, 09:32 AM
RAIV-Z's Avatar
Default First Gen Firebird Super400 Hood
  #248
Old 11-30-2011, 11:00 AM
rohrt rohrt is offline
Just read through the build. Very Cool!
I will be curious to see how well you like the sound of the exhaust and if the super 400 hood fits. You have a very tall set up.
  #249
Old 11-30-2011, 12:37 PM
JoePapa's Avatar
JoePapa JoePapa is offline
How's the quality and fit of the new Super400 hood?
'69 Firebird 400
http://firstgenfirebird.org/show/closeup.mv?CarID=734
  #250
Old 11-30-2011, 07:46 PM
67'7F6'Bird's Avatar
Thanks!!! The motor is running and the exhaust sounds Great. We may need to remove the 1 inch spacer for the Super 400 Hood to fit.
We haven't put the nose on the car yet, but will shortly and then be able to give some feedback on this Hood.
Steve
  #251
Old 01-01-2012, 08:11 PM
Ed and I decided to put the nose on the car today to make sure its still a Firebird.
ID:	268920   Click image for larger version
ID:	268921   Click image for larger version
ID:	268923   Click image for larger version
ID:	268924   Click image for larger version
  #252
Old 01-01-2012, 08:14 PM
Here is the complete car once again. YEAH!!!!! Also, last picture is our rear hanger installed on the exhaust.
ID:	268927   Click image for larger version
ID:	268928   Click image for larger version
ID:	268930   Click image for larger version
ID:	268931   Click image for larger version
  #253
Old 04-11-2012, 09:05 PM
ponjohn's Avatar
ponjohn ponjohn is offline
This thread is FANTASTIC!!
I have a few questions.
As you remove and reinstall panels to test fit how do you know it's going back in the same exact spot?
How did you determine where and how many plug weld holes to use?
Does the rain gutter stay on the car even when the roof and quarter is removed?
Keep us updated.
John
  #254
Old 04-13-2012, 08:57 AM
Thank ponjohn, Answers below.
As you remove and reinstall panels to test fit how do you know it's going back in the same exact spot? We used small self tapping screws in multiple locations.
How did you determine where and how many plug weld holes to use? Depending on the size of the plug weld needed we spaced them accordingly, about 1 to 2.5 inches.
Does the rain gutter stay on the car even when the roof and quarter is removed? Yes, The gutters remained attached on this build.
Keep us updated.
John
  #255
Old 05-13-2012, 09:27 AM
A few updates...
We installed the Transmission Cooler with Fan, the Electric Fan for the Radiator, Fan Shroud and the Derale Fan Controller. The real tail-Pipe Hangers we welded on too.
Steve
ID:	284325   Click image for larger version
ID:	284326   Click image for larger version
ID:	284327   Click image for larger version
ID:	284328   Click image for larger version
  #256
Old 05-13-2012, 07:22 PM
frankyboy455 frankyboy455 is offline
Originally Posted by 67'7F6'Bird View Post
A few updates...
Steve
didn't you want to bolt them on like the factory did ?
  #257
Old 05-13-2012, 07:43 PM
I needed the welding practice in tight spots.
It looks cleaner this way.
Originality can be Improved.
Those little factory bolts wouldn't hold up this 3" tailpipe. HAHAHA
  #258
Old 07-14-2012, 11:56 PM
We put the "Super 400 Hood" on the car. The fit is OK, it does need some time for overall clean-up from the mold process. the middle sides of the hood which run along the fender seem about a 1/4" high. I may need Dzus fasteners to run along side the hood for proper fitment to pull it down. Pictures to follow.
  #259
Old 08-12-2012, 09:10 AM
I received the "Universal Spinners" 2" Drop Base and Flat Lid with middle recess for the Air Cleaner Bolt. This stuff is Very Nice and I recommend them to anyone who need more hood clearance.
http://www.racingjunk.com/Drag-Racin...-drop-16-.html
Once installed with my Super 400 Hood and 3.5" K&N Air Cleaner the hood still doesn't close all the way and it needs about 1/2" More clearance minimum. Instead of cutting the Victor Intake down I am going to order the Northwind Intake which is 1.25" shorter than the Victor with comparable flow.
http://www.krepower.com/Pontiac%20Intakes.htm
Steve
  #260
Old 08-24-2012, 10:45 AM
4500 Northwind RAIV Ports Intake being Delivered today.
