Old 10-11-2011, 11:29 PM
Tim Corcoran's Avatar
I am sure your car would be happy with a correctly tuned Holley 650 or properly built Quadrajet. I would toss the Edelbrock carb in the trash or sell it to some sucker on ebay.
Tim Corcoran
Old 10-12-2011, 12:49 AM
Pontirag Pontirag is offline
easy Tim.... thats where I'm lookin for carbs for my offy.
Old 10-12-2011, 08:10 AM
Juliano Juliano is offline
Default .
I have a 65 389 also. Vacuum at 800 rpm is 12-13. Edlebrock rpm with 750 edel carb with one size rod leaner...runs great. also have run the edelbrock 2 X 4 package they sell with the two 600 cfm carbs. vacuum goes to 14 - 15 and from a dead stop I burns rubber forever........I have gone on a 5000 km round trip to the same place on both setups...amazingly both burned the same amount of gas.............
Old 10-12-2011, 12:25 PM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
Thanks for the info guys. There are some ugly Qjets on ebay right now and I'm not sure which way I'll go. My first car was a 73 Firebird with a 350 and mechanical holly 4 barrel. I had to rebuild that carb countless amounts of times (kept blowing the power valve) but when it worked it worked great and I loved that you could always tell when the secondarys opened. One of these days I want to build a new engine with some kind of fuel injection on it but until then I'll keep it carbed.
Old 10-12-2011, 12:33 PM
screamingchief's Avatar
Blown power valves are no longer a problem,all the new Holley carbs come with PV blow out protection,and it's super easy to retro-fit such to any older Holley carbs too,takes like 15 - 30 minutes to add that during a routine rebuild.
Plus back before that option was well known,that was why I always used the Holley electric chokes,no "sneezes" during cold start-ups,no blown power valves or such.
Anybody that's blowing their Holley power valves these days needs to brush up on their carb tech knowledge somewhat.
FWIW
Bret P.
This space for rent...
Old 10-12-2011, 01:21 PM
carbking's Avatar
carbking carbking is offline
You might find this article interesting:
http://www.thecarburetorshop.com/Car...eselection.htm
Jon.
