Old 11-28-2011, 10:14 PM
nytrainer's Avatar
Default 68 power trunk release
Bought GTOwagon's power trunk release latch/solonoid (Thanks). Was wondering if anyone who has this option installed has some pictures. Attached is a picture of the underside of the trunk lid. I thought I would put the power wire through the lid represented by the dotted line. I would assume it comes out of the hole and is tywrapped to the right hinge? and then under the seat, rug to the glove box. It was not an option on this particular car but I like having one. Not super worried that I have correct harness, etc but would like to do it as close to original as possible. I do not have a trunk light either so if someone could share what and where it is I would appreciate it.
Thanks,
Dave
Name:	68 trunk.jpg
Old 11-29-2011, 12:43 AM
ledbetter66's Avatar
ledbetter66 ledbetter66 is offline
Default info on trunk release
do a search on rear tail light harness from 69gtocv. There is a pic in there that shows the wiring which comes out of the trunk and follows the passenger side hinge up to rear deck the pic is not the greatest but you can see it fairly well. switch in glove box has two connections one comes from your clock power lead and the other goes from switch under seats and out to trunk to release solenoid which is in the pic I'm telling you about. I think the trunk light plugs in to the harness near the driver side hinge. I hope this helps
Old 11-29-2011, 12:51 AM
Default Picture for trunk release
here's the picture for you, your dotted line I think is correct
Old 11-29-2011, 02:30 PM
nytrainer's Avatar
Thanks Ledbetter for the help.
Old 12-06-2011, 10:59 AM
nytrainer's Avatar
Does anyone know what color the latch mechanism should be. Right now it has overspray from the original color painted on the inside of the trunklid. Should it be silver, black, ??
Dave
Old 12-06-2011, 11:54 AM
gtohurstjudge's Avatar
gtohurstjudge gtohurstjudge is offline
Dave
This is a question I would love to know the correct answer to. I added a power
trunk release to my car many years ago and when I purchased it there was no paint
on the latch(it was a used assembly found in a wrecking yard by a GTO vendor) Upon
installing it, I discovered that it was impossible to install the cable without the latch
being out of the deck lid, so it seemed to me that since nothing had any paint on it, it
must have been installed on the assembly line after the car was painted. Making this
assumption, I left the latch natural as it was when I bought it, but I've often wondered if
maybe the GTO parts vendor cleaned the old overspray off the latch with paint remover before I bought it. I hope someone on this forum with this option from the factory can
answer this question.
Old 12-06-2011, 12:00 PM
nytrainer's Avatar
What cable are you referring to?
Old 12-06-2011, 12:54 PM
Sorry, wrong terminology......I was referring to the wiring harness. You
can't plug the harness in to the latch with the latch on the decklid. And you can't
paint the deck lid with the wire installed as it would interfere with painting the lid where it runs
out the hole above the hinge. I made the assumption that they installed a manual latch
on the car to paint it, or just put a wire on it to close it while painting the top of the lid, then
installed the power trunk latch and wire later on down the line.
Old 12-08-2011, 11:41 PM
PaulatFast PaulatFast is offline
The cars were painted with the decklid unstalled and adjusted. IF the car had the power release option, the latch was changed at a later point in the assembly process. Therefore... no paint on the power mechanism.
Paul
FAST Automotive -The Pontiac restoration shop, not the fuel injection guys! I had the name first.
My site... needs updated-
www.fastrestorations.com
68 GTO's (RA II, RA I, HO, convert, Pro Street, Racecar, etc.), 2 69 GTO Judges, 70 GTO racecar -10.77 @ 124mph, 68 Tempest survivor, 3 03 Aztecs!
Old 12-08-2011, 11:59 PM
nytrainer's Avatar
That make sense Paul. What finish do you suggest. I wire wheeled the overspray and surface rust so it's a shiny metal now.
Old 12-09-2011, 01:07 AM
That depends on what will make you happy. You could paint it. You could clear it. For propper points typre resto, I think it would be plated with a silver zinc finish.
Paul
Old 12-09-2011, 03:26 PM
I have the option factory installed on 4 of my current Pontiacs & have been pulling this option, including correct buttons, clips, etc forever. Many years ago I used to sell them at Pate & Fall Arlington.
The '67-72 electric trunk releases for A-bodys & '69-72 GP's, being one piece solenoid & latch, will be clear zinc plated. They get washed out looking over the years, & some will have had condensation & slight rust on them, so some look much better than others. The '67, 68, & I believe all ( I hate saying all!) '69's trunk poppers had a pink wire pigtail. All the '70-72 integral trunk releases I have had & have, have the black pigtail.
On 2nd Gen F-body & '73-77 A-body style, the trunk solenoid is by itself, & the latch is separate. This is the style quite a few ------ sell on eBay as "original" GTO -SS Chevelle-442. Will require mods to the trunk mtg hole area on a '68-72 A-body. The latch for this style of power trunk release is actually different between standard trunk release & power trunk release, One will need to make sure & get they correct the latch with this style many many latches were painted. I have all colors.
Old 12-10-2011, 12:42 AM
g68mike's Avatar
g68mike g68mike is offline
I have several original cars with documented power trunk release and all have overspray on the portion sticking out and clean no paint on the upper half inside lid. I have pulled tons from salvage yards from Olds, Chevy Buick Cadillac Pontiac and all have overspray. These were installed before being painted at the assembly plant. As was previously mentioned the wiring was also installed before paint. I believe this was a popular convenience option and was added by many owners after purchase thus resulting in the un painted latches seen. To add the option, the wiring can be routed through the trunk lids, sometimes not easily, but can be done. Just like door hinges being installed to firewall and doors and door latches being installed into doors prior to paint, the trunk latch was installed into trunk as well trunk being bolted to hinges, resulting in clean bare metal underneath. Dont forget the assembly process already had body data plate assigned to VIN, confirming what options, paint etc were assigned to each car. GM would not install a incorrect part just to remove it and switch it back out, when already knowing what proper piece was going to be installed.
Heres a pic of a couple, note, where the paint stops is pretty much the same on all.
Old 12-10-2011, 01:24 AM
JOE DEYTON's Avatar
JOE DEYTON JOE DEYTON is offline
all the non powers I have had overspray. I did get one from a cutlass for my 68 gto and it did not have any paint on it.
Old 12-10-2011, 02:36 AM
I only see overspray on one of those releases in your pic? I've never seen an original with paint on it. As far as the GTOAA Judging goes, no paint on the power release.
Paul
Old 12-10-2011, 10:44 AM
g68mike's Avatar
Look closer, all have same overspary pattern.
Old 12-10-2011, 12:39 PM
the one with yellow paint came of an original no repaint car? the others I have a hard time telling.
Have the original release out of my '69 428HO GP. (decklid was rusty in the seam so swapped on another deckid) it has no burgandy paint on it. My T-37 post has its original decklid & original trunk release, can double ck it again, but swear, no cardinal red paint. The T-37 is Pontiac plant car, the GP is Arlington plant car. Currently, I have a Lakewood (atlanta) built '71 GP parts car that still has original deckid & power trunk release, will ck it as well.
Old 12-10-2011, 01:18 PM
nytrainer's Avatar
Default remote release
The side that shows on those 5 release mechs. that g68Mike posted (thanks Mike) is really the side that is almost impossible to see without really stretching. Isn't the other side the side that shows when the trunk is open?
Those pics helped though because as you can see in mine there is a broken bolt sheared off in the top hole. Also, and it worries me a little, is the hole where the actuating rod from the lock cylinder goes looks a bit hogged out compared to Mikes units. I would have blindly proceeded with the install only to realize I had to drill out the broken bolt and probably would have then installed it only to find the rod spins in this oversized hole without opening it.
Thought of swapping the non remote's "hole" but I don't think I can take this apart with those special rivets. I'll probably add some material to the rod so that it fits the hole better I guess. Mike, what do you normally sell those for? $
Name:	trunk release 1.jpg
ID:	266530   Click image for larger version
Name:	trunk release2.jpg
Old 12-10-2011, 07:44 PM
g68mike's Avatar
Maybe these pics are better.
ID:	266629   Click image for larger version
ID:	266631   Click image for larger version
ID:	266632   Click image for larger version
Old 12-10-2011, 07:48 PM
g68mike's Avatar
Another one. Two more of my survivors have originals with original paint, but up here in Chicago, so everythin is in storage for now.
ID:	266634   Click image for larger version
ID:	266635   Click image for larger version
