Old 01-01-2012, 11:48 AM
OldS-man OldS-man is offline
Default 389 piston in a 62 4cyl
I found a set (8) of .030 over cast 389 pistons. I have read on here about using them in the 4cyl, but will they increase the compression to much for a daily driver ?
and I picked up another engine that is a '61. It does not have an oil filter, It just
the part that bolts to the block in place of the filter adapter with the pressure sending unit. Is this common for '61s ?
Old 01-01-2012, 01:53 PM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
Are the pistons flat tops or dished?? Flat tops, compression will be in the 10.25 range, dished will be 8.6 range.
An oil filter was an option. They used a bypass plate instead. Dont see the bypass plate too often.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 01-01-2012, 03:37 PM
the pistons are flat top. the ones I took out are dished
Old 01-01-2012, 03:46 PM
You can use them but will need a different head to bring the compression down.
Keith Collier
Tech advisor
POCI.org
Old 01-01-2012, 06:49 PM
Thanks Keith, your info really helps me out.
is there a piston I can buy and use the head that I have.
I didn't purchase the 389 pistons yet .
Old 01-01-2012, 07:02 PM
SD421's Avatar
SD421 SD421 is offline
Back in 1999 I purchased low compression pistons from Kanter's for my 1961 4 cylinder motor. Turns out they were the 10.25 to 1 pistons. http://www.kanter.com///productdetai...Cat=32&Prc=362
Make sure they are the low compression ones.
Don
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 01-01-2012, 07:10 PM
Any decent machine shop should be able to get pistons for you. I got my last set from NAPA. .030 over 389 pistons were about $20 each. Was not building a performance engine so went with a stock replacement cast piston.
Keith Collier
Tech advisor
POCI.org
Old 01-01-2012, 08:27 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Just open up the chambers a bit on the spark plug side of head, no real cost. It will be under 10:1 stock if the head hasnt been milled alot. 10.25:1 engines adverstised are usually more like 9.75:1 actual. Will 5-8 cc removed , target an 78-80 cc chamber
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
Old 01-04-2012, 11:20 PM
i just checked with Kanter. Rings,rod,main,cam bearings.Gaskets,oil pump,chain and gears.DISHED pistons,intake and exhaust valves. Valve springs,lifters,valve guides.Push rods,rocker arm kit.
$850. plus $126 to re-grind my cam.
probably going this way.
