Old 02-04-2012, 11:51 AM
irgoatmike irgoatmike is offline
Default Window Regulator Channel
Simple question, what do you lubricate the regulator channels with before installing glass? Regular grease, white lithium? irgoatmike
Old 02-04-2012, 05:01 PM
Penray product called inner slide lube. It's a liquid graphite lube that stays on what you spray it on.
MIke
former." --Albert Einstein
- Winston Churchill
Old 02-04-2012, 06:09 PM
Thanks Mike, I'll give it a try. irgoatmike
Old 02-05-2012, 09:11 AM
Jeff Hamlin's Avatar
White lithium grease is another good choice.
Old 02-06-2012, 11:09 PM
RR67GTO's Avatar
RR67GTO RR67GTO is offline
I've tried the 3M spray on white lithium on my cars with poor results. It dried out before long. And, also turned yellow. After three years of using it I cleaned everything and went with a graphite lube. So far it's been great. Perhaps I ended up with a bad couple of cans of 3M.
Build it fast, build it right, hold On TIGHT !!!
Old 02-07-2012, 01:00 AM
lrosen's Avatar
lrosen lrosen is offline
I just used wheel bearing grease on mine. Over 8 years since my resto and my windows go up and down smooth as silk.
1967 Firebird 326 H.O. Conv., M3 floor shift, 3.36:1, Montreaux Blue/Parchment, Dual factory traction bars
2005 IBM GTO M6 - One of 347
1984 Yamaha FJ1100
