Old 03-04-2012, 01:56 AM
71pp'sGP 71pp'sGP is offline
Default temp sending unit
Ok guys, just had my engine rebuilt on my 71 Grand Prix the car is a beast......one problem the guy who built the engine at enginelaboftampa.com told me my temp sending unit wasn't working properly so I'm needing to change it out......its the 3 prong unit, I've looked from one end of this country to the other and can't find a 3 prong sending switch anywhere. I've found 2 prong temp sending units will they work?......is there any other alternative I was told to put me a after market temp gauge. But I really want to keep the car as original as possible. Thanks. Pic coming soon
Old 03-04-2012, 09:13 AM
77 Canamman's Avatar
Lightbulb
See this thread:
http://forums.maxperformanceinc.com/...ght=prong+unit
The three prong switch is solely used for the Transmission Controlled Spark emission control system. The temp sending unit is located on the intake manifold on a 1971 model.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 03-04-2012, 02:16 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Unfortunately, a known good used or NOS part is the only choice.
Old 03-04-2012, 02:22 PM
on my engine i dont see a temp sending unit on the engine head, the only one a have is on the intake its a 3 prong
Old 03-04-2012, 04:20 PM
will a 2 prong sending unit work,
Name:	johns pic 1156.jpg
ID:	277147   Click image for larger version
Name:	johns pic 1161.jpg
Old 03-04-2012, 06:40 PM
david400's Avatar
david400 david400 is offline
I believe that plug you have there is the TSC control plug . you dont need it at this point IMO. you need the single termanal plug for the heat gauge ,should be a single green wire there for the heat gauge plug .
Old 03-05-2012, 10:41 PM
428ho4spd's Avatar
Actually, a '69 style single prong switch will work fine if your not using the TCS system.
Old 03-05-2012, 10:51 PM
428ho4spd's Avatar
This plug actually does both, TCS and temp switch for cars with standard gauges (idiot lamps). Rally gauge cars had another separate sending unit on the opposite side of the intake for the gauge temp.
Old 03-05-2012, 11:22 PM
david400's Avatar
Ahhh, I see ,Thank you Grant
