Old 11-05-2011, 06:40 PM
GTOWAGON's Avatar
GTOWAGON GTOWAGON is offline
Default WFO drop base shaker assembly
drop base aluminum air cleaner to use aftermarket intake and still have functional shaker 75.00
When you really do something right it's like you didn't do anything at all
1931 Pontiac 5 window coupe OHC6 powered
2015 GMC Yukon SLT
Old 11-06-2011, 06:18 AM
gillyiowa gillyiowa is offline
Default base
sent you a pm
Old 11-06-2011, 11:12 AM
GTOWAGON's Avatar
SPF
2015 GMC Yukon SLT
Old 11-08-2011, 02:34 AM
Sharkbait40's Avatar
Sharkbait40 Sharkbait40 is offline
Default Whick Model?
Which model?
WFO-1 = 77-81 Trans Am
WFO-2 = 70-76 Trans Am
http://www.jbp-pontiac.com/products/...s/dropBase.htm
Thanks, Russ
Old 11-12-2011, 12:02 AM
GTOWAGON's Avatar
This is still available
2015 GMC Yukon SLT
Old 11-12-2011, 10:57 AM
se428bandit's Avatar
se428bandit se428bandit is offline
If sharkbait40 is not interested i might be. Do you have any pics?
Old 11-16-2011, 12:21 PM
GTOWAGON's Avatar
pic
2015 GMC Yukon SLT
Old 12-16-2011, 12:58 AM
GTOWAGON's Avatar
bump
2015 GMC Yukon SLT
Old 02-04-2012, 04:57 PM
GTOWAGON's Avatar
ttt
2015 GMC Yukon SLT
Old 03-28-2012, 11:37 PM
GTOWAGON's Avatar
ttt
2015 GMC Yukon SLT
Old 03-29-2012, 05:13 AM
pontiac1981's Avatar
pontiac1981 pontiac1981 is offline
Default BASE
Originally Posted by Sharkbait40 View Post
Which model?
Thanks, Russ
Which one is this, the WFO-1 OR WFO-2?
Old 03-29-2012, 03:41 PM
vidguy's Avatar
vidguy vidguy is offline
Can you use this as your aircleaner with out a shaker?
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
Old 03-30-2012, 10:32 PM
Formula8's Avatar
Formula8 Formula8 is offline
My guess is WFO 1 as the 70-76 units run a small square filter that fits up in the scoop while the 77+ units run a 14" round filter.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 03-31-2012, 05:53 PM
GTOWAGON's Avatar
This is SPF
2015 GMC Yukon SLT
Old 04-01-2012, 09:18 PM
carbuff's Avatar
carbuff carbuff is offline
Got any more pictures? I may be interested... Thanx!
Old 04-02-2012, 03:43 PM
marxjunk marxjunk is offline
payment sent..thanks...
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
