Old 05-01-2012, 07:00 PM
njsteve's Avatar
njsteve njsteve is offline
Originally Posted by FunctionalShaker View Post
I wouldn't use a standard green hose. I use a heavy duty black Craftsman hose -- works fine.
Hey, Father's day is coming up. Now I know what to ask for.
  #162
Old 05-01-2012, 07:34 PM
thefirebirdm@n's Avatar
thefirebirdm@n thefirebirdm@n is offline
Send a message via MSN to thefirebirdm@n
Hmmm building a shop soon. Guess I will make sure I have hot water routed out to it.
Jimmy
www.firebirdgallery.com
2002 WS6 M6 Trans Am - original owner
1973 Trans Am 455/4-speed
1971 Formula 400/400
1969 GTO 400/400 - 3rd owner
1968 Firebird Convertible 350/200R4
POCI - AAC
  #163
Old 05-02-2012, 12:49 AM
Formulabruce's Avatar
Any "REAL" resto guy worth his salt can remove that section of frame with a spot weld remover ( goes on a drill) get the new frame section,flange the end towards the front, drill holes where the welds were, use a spot weld adapter for a mig welder ( 30 bucks from eastwood) and weld up those holes and the seam and finish it like it was new. Will need spring off though on that side, may want to start spraying some nuts. I have done this on a 4 post lift and wore some rust but the job came out nice. Maybe a welding, fab shop would be more inclined to tackle it than a body, or resto shop though.
  #164
Old 05-02-2012, 07:36 AM
njsteve's Avatar
That is what I was thinking as well.
  #165
Old 05-11-2012, 04:52 PM
cnc's Avatar
cnc cnc is offline
Steve I haven't forgotten about ya I'm still waitng to hear from a guy,,,just an update....fingers crossed,,,,
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
  #166
Old 05-12-2012, 05:49 AM
tommie69's Avatar
tommie69 tommie69 is offline
Wink
Remember - a car cover is not an excuse to stack items on a car you wouldn't put on it without one!
I like that one Chris!Pretty car Steve,good luck with it!
  #167
Old 05-19-2012, 06:20 PM
njsteve's Avatar
Started working on the car today after being away on a trip. Attempted to get her registered since the forms from Customs finally showed up. Of course once I got there, the DMV lady said I have to contact their headquarters on Monday, since the car is coming from a foreign country. (Of course that advice was completely different from what they told me the last time I was there a couple weeks ago when they said I needed the Customs form to complete the paperwork package.)
I replaced the leaky valve cover gasket and got the horns working (it was a disconnected wire at the relay - solved that one pretty easily). Click on the photo to hear how she sounds at the moment.
  #168
Old 05-19-2012, 06:38 PM
Pepi's Avatar
Pepi Pepi is offline
Sounds sweet!
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #169
Old 05-19-2012, 07:22 PM
Guilty's Avatar
Guilty Guilty is offline
Default Part two......
Steve, call your local dmv back on Monday and ask to speak to the manager of the branch. Tell them what you have as far as Customs paperwork and the registration which is also the title. All the customs paperwork is for is to determine how much state tax you are going to pay. Sounds like the person who helped you has no idea what she is doing. Brian.
  #170
Old 05-19-2012, 10:47 PM
Nice!! I am going to envy that AC I think!
  #171
Old 05-20-2012, 07:31 PM
njsteve's Avatar
In today's "Give A Mouse A Cookie" update, it all started this morning with me taking the rear seat out to fix some of the wrinkles in the seat cover. I pulled the back seat and set it in the 80 degree sun for an hour to soften up. Since I wasn't just going to sit around for the hour, I pulled the other seats out...and then the carpet...etc.
Anyway, I had a bag of hog rings so I adjusted and pulled and remounted all the new seat covers till 90% of the wrinkles were gone. They must have been installed in the Canadian winter and ended up being too loose on the seat foams. It worked out very well in the end.
The upright cushions are done, the ones lieing flat are warming up.
  #172
Old 05-20-2012, 07:43 PM
njsteve's Avatar
And while all the seats were warming up I pulled the carpet out to see what the floors looked like. All the original tar paper insulation was in place and actually very pliable and sticky (a real mess actually). Sitting in the sun the stuff was just as tacky as the day it was installed 40 years ago.
I wanted to examine the floorboards so I started carefully pealing with a plastic putty knife and got all of the tar paper insulation up. The car was originally rust proofed when it was new and it looks like they lifted the carpet and slathered the tar paper with extra cosmoline or some other goop and it pretty much saved the floors but it left a black tar mess in places. Here is what it looked like after a few hours of peeling:
  #173
Old 05-20-2012, 07:50 PM
njsteve's Avatar
And look what arrived yesterday:
I ordered a reproduction of the original owner's license plate from these guys: http://www.licenseplates.tv/
It turns out that the CWT-160 plate number that was listed on all of the car's dealership repair orders was in a unique 3-letter/3-number sequence that started in 1973 in Ontario. So it looks like that is as close as the original day-one plate as I am going to get.
  #174
Old 05-20-2012, 08:41 PM
The Boss's Avatar
The Boss The Boss is offline
Very cool!
Are the carpet & seats going back in or are you continuing from here?
And go racin' in the street.
  #175
Old 05-20-2012, 08:44 PM
njsteve's Avatar
I'm putting in new tar paper insulation and carpet. The old carpet was a replacement and it wasn't trimmed properly when installed. Plus it smelled oily from the rust proofing goo. The head liner needs to be replaced as it is the wrong material and was most likely done when they installed the new GM quarters back in the 1980s.
  #176
Old 05-20-2012, 10:36 PM
It will not show once installed,the Eastwood stuff works so well, really cuts the noise and driveline heat. I used a tiny pizza roller to really flatten it before carpeting. I also used the good silver tape to cover areas where seams were. If your gonna keep it/drive it, its something to consider..Its far from original obviously, but not noticeable. Also makes the radio sound much better ( rear speakers) Its just an FYI..Love your car ! Its nice to see someone else spreading out the mess like I used too!!
  #177
Old 05-21-2012, 10:15 AM
LeighP's Avatar
LeighP LeighP is offline
Exceptionally clean car.....nice to see a good solid floor like that.
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
  #178
Old 05-21-2012, 02:14 PM
murphc4 murphc4 is offline
Did you just buy the standard kit from them that says it will cover about 33 sq ft? I was thinking of putting this on the roof and in the doors as well. Also, do you just put the carpet directly over this, or still use an under lay?
Old 05-21-2012, 02:59 PM
666 the legend's Avatar
666 the legend 666 the legend is offline
Got the spare grills refinished. It took a while to mask off the black grates and then paint the argent without getting any on the grates. Very tedious process, indeed. I need to find some better chrome trim rings. Hopefully the ones on the car are better than these.
The car made it through customs fine and the delivery truck is supposedly coming here tonight. I will update you all as soon as I have the car.....
Hey..Steve..nexttime yah paint those grills..just get some poster paper..Trace the back side and then trim it a lil smaller and place it on the front of the grate..No taping or nothing........
  #180
Old 05-21-2012, 03:17 PM
