Old 05-08-2012, 08:02 AM
TinInjun's Avatar
TinInjun TinInjun is offline
Location: American by birth, Southerner by the grace of God
Based of the mph on the dyno sheet, at 6000 rpm you have 14% slip. That's a lot.
Less said,,,,,,,, Less mended.
Old 05-08-2012, 08:34 PM
p4msi1's Avatar
p4msi1 p4msi1 is offline
Send a message via AIM to p4msi1
Tin, it certainly feels like it wants to leap off the dyno. The converter was tightened up a bit from the 4000 stall that it was, but I think you bring up a good point, something for me to investigate. I will just leave it hooked up to the dyno till this weekend and try it again. How much slip is acceptable at top end?
Steve
Old 05-08-2012, 08:54 PM
bryansMtngto's Avatar
bryansMtngto bryansMtngto is offline
Originally Posted by cfmcnc View Post
At 11.1 cr with 440-450 cfms,with the right cam and manifold it should be around 900HP on engine dyno.Bill C,
x2 just was wondering why his chassis dyno #'s so low with his combo. I figureing he would be around 750 to 790 at the rear wheels.
Old 05-08-2012, 09:02 PM
bankbook's Avatar
bankbook bankbook is offline
The smart move would be to call Ceralli Comp. if you have questions about how to improve it.
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
Old 05-08-2012, 09:20 PM
p4msi1's Avatar
Brian, I agree but my 455 went 465 rwhp and ran 10.90. I'm sure I will eventually get 560+ rwhp and at least be able to cover a 10.20 1/4 Mi. then drive it home listening to classic rock. As of right now I have +90 hp and + 50 lbs tq from the old combo. Will that get me to a 10.20? Time will tell for sure. The torque peak was 4950-5000 rpm and the HP peak was 6200 and very flat, which I think is good for overall averages. The split between the HP and TQ was about 1200 rpms. As I'm gathering all this data I'm trying to figure out if I could go up to a 1250 carb, as mentioned earlier, and /or is the intake doing its job based on cam dimensions, cubic inches, HP and TQ peaks. I feel i'm an adaquate tuner but I also know i'm amongst real pro's and will listen to sound advise.
Steve
