Old 05-15-2012, 01:39 PM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
Congrats on the win and good results Glenn
  #62
Old 05-15-2012, 01:44 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Originally Posted by Glenn Sedig View Post
You probably wouldn't believe 3195 lbs. So I won't lie. 2950 lbs
dont lie to me!! LOL.. i think it was 3195!!
good job
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #63
Old 05-15-2012, 02:03 PM
Glenn Sedig Glenn Sedig is offline
Default Tiger Inserts
Leak down before the inserts were installed, and with 15 runs on the old gaskets, on cyl 3 & 5 was 15%. On cyl 4 & 6 was 8%. The heads were installed with new gaskets. The cylinders heads were flat with no bad areas except between the center cylinders. I got more than 15 runs (more like 30 runs) when the heads were new and no deformation had occurred in the center area.
The inserts where installed to sit .001 above the head surface. The heads have not been surfaced since new. The leak down after the 8 runs - 3 & 5 is 2% 4 & 6 is 3%
Engine is 473 Cu in, 14.5:1 comp. N/A
I need to clarify the engine consitency. Along with the inserts and new head gaskets, I changed my valve lash from .026 cold to .010 cold. Hoped to achieve .018 when hot. I believe the lash change and the fact that the track was prepped before each Q - 8 session also helped with the consitency.
  #64
Old 05-15-2012, 04:12 PM
60man's Avatar
60man 60man is offline
Thanks for the info Glen..I don't have a leak down handy ( misplaced it?) so I'm going to check compression with standard gauge...to get an idea of any present issues..??
I ran a comp. check prior to past week ends passes..
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
  #65
Old 05-15-2012, 06:31 PM
It would be good if you can find your leak down tester. The compression happens so fast when you crank your engine over that it is hard to tell if the gasket is starting to leak. If the gasket is bad and you put the cyl at TDC and add air pressure, you will hear the air leak into the neighboring cyl. Of course you will also hear if your valves and rings are leaking.
  #66
Old 05-15-2012, 08:03 PM
60man's Avatar
Yep..so true Glen.. No argument there..I shot some light oil in 3 last time just to see if it helped...No brainer when the oil popped out of 5 ...Duh..sum biotch..!! I used to be a MATCO distributor so I know all about tools... I have a old Fox Valley engine analizer that does cylinder balance test...we used to call it the scope in a box...might try it just for chits sake..
Oh..comp test didn't show any catastrophic problems..
ECM member.
MANDRA
  #67
Old 05-15-2012, 08:46 PM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
Those leak down numbers are really good, do you normally re-torque the head once it's been on a running engine for a number of heat cycles?
I really believe, due to the nature of this insert material, this will solve many of the head gaskets woes our tied together, Pontiac siamese exhaust engines can have. Once the exhaust temps get so hot, the small amount of mating surface will not cool properly and weakens.
In today's bigger bore engines, our larger bore spaced cousins (BBC) have other issues when the chambers begin to collapse due to the lack of surface real estate.
Increased power will always come with a cost.
Calvin Hill
Hill Performance
708-250-7420
  #68
Old 05-16-2012, 07:23 PM
Calvin Hill
Hill Performance
708-250-7420
No I do not. I know I should but there is never enough time.
  #69
Old 05-16-2012, 09:38 PM
related to heat and need to retorque... I've found header bolts (and studded) that need retorque... for awhile... but then just didnt change after a point. I thought rust or corrosion but later tear down every thing is clean and barely rusted on outside...
Causes me to wonder if just pulling to tq spec after a few passes(not loosening and retorquing) you would hit a point eventually where it didnt change. Thoughts???
Maybe kills the studs before the gasket dies ???
  #70
Old 05-17-2012, 08:59 PM
Originally Posted by BruceWilkie View Post
related to heat and need to retorque... I Thoughts???...Maybe kills the studs before the gasket dies ???
Well, I've NEVER re-torque Head-Bolts on a hot-run engine because I figure the organic gasket material is at it's softest, unfair to re-TQ while HOT. In fact I'd be scared to re-TQ while HOT.
Corollary: Re-torque after a complete cool-down sounds fair game. (if we Monk-like about it, not to cavalier).
  #71
Old 05-18-2012, 03:05 PM
twinturrbo406's Avatar
twinturrbo406 twinturrbo406 is offline
... here are our Tiger heads with the insert ... it has turned out really nice and the surface is seamless ... it is a bit tricky blending the inserts by hand, as you are literally hovering over the alloy seats with a carbide-burr (()) but it is a slow process ... and based on the results of the others engines we've seen using this mod, i see no reason why it wont work as intended for these heads ... and it also makes for a very nice "repair" for any heads that have had any issues in this area, regardless of make ...
ID:	284929   Click image for larger version
  #72
Old 05-18-2012, 03:15 PM
Robert C.'s Avatar
Robert C. Robert C. is offline
Very nice work.
Bob C.
Quickest, Fastest, Best selling Pontiac Aftermarket Block IA II and Tiger Heads
Boss Bird Funny Car
Best pass to date 08/06/2016 [email protected]
Allpontiac Big Chief Aluminum Engine Block
http://www.AllPontiac.com
  #73
Old 05-18-2012, 03:16 PM
The heck with the organic gasket material... my own organic material is is peril when things are hot. I havent used header gaskets in 20+ years. (hi temp red only) Used to think it was bolts backing out. Safety wire proved otherwise.(safety wire skill well learned when learning aircraft maintenance) Cured rtv only compresses to a point and I use a pretty thin amount. Only enough to fill voids and have enough stretch for expansion/contraction cycles. So... after figuring out the bolts arent turning and sealer containing seal and not leaking.(Debs street car 8 years as of last month) The bolts are stretching after heat/cool cycles??? Then hit point where they no longer stretch? Or hit point where expansion contraction equalize? Cant be rtv as it would have "glued" like loctite and not allowed much if any movement in first place and once disturbed from "sealed" would stay "loose".
Only talking header bolts or studs here and I've never put a tq wrench on them(ever in my life). Probably will If I ever need to remove them. Hmmm maybe I'll go loosen one later and see what break-away torque is then retighten to same tq. Check tq again Sunday night. Maybe learn nothing or something.
Just have to wonder about thermal cycles on heads/block/gasket/fastener. At what point do gaskets stop crushing? Heads too? What happens to fastener that is constantly heat cycled? Lose temper? I cant see how it could help itself.
Seems good maintenance to check fastener torque though.
  #74
Old 05-18-2012, 03:22 PM
rompn63's Avatar
rompn63 rompn63 is offline
Glenn just called me this morning and said my Tigers are ready. I'll pick them up Tuesday and have them on by the weekend.
  #75
Old 05-18-2012, 03:37 PM
60man's Avatar
Looking good ....Question....any thoughts on adding the additional water hole/passage above center bolt...AKA: 421 mod..?? Is it possible with insert..Would it help prolong gasket life even more ??
Would like to hear Calvin's & Glen's opinion ..Thanks
ECM member.
MANDRA
  #76
Old 05-18-2012, 06:57 PM
Default Tiger insert
I think extra water can't hurt. I would put the hole under the insert unless you can hit the radiused end of the insert dead center with the drill bit. The insert is tough enough that if you don't hit center the drill will wonder off to the side. Also the amount of press fit on the ends of the inserts has been calculated to stay pressed at temps up to 600 degrees even with the different rates of expansion. Drilling the into the ends would give less area of contact for the press.
  #77
Old 05-18-2012, 08:48 PM
...Just have to wonder about thermal cycles on heads/block/gasket/fastener. At what point do gaskets stop crushing? Heads too? What happens to fastener that is constantly heat cycled? Lose temper? I cant see how it could help itself. Seems good maintenance to check fastener torque though.
Wonder no more: Rod bolts, Main Cap bolts, balancer bolt, rocker studs always show excellent break-away torques. No gasket, so you know the thermal cycling does not relax/ yield the fastner nor item fastened.
Head Gasket material is relaxing. Clarity is a good thing.
  #78
Old 06-07-2012, 06:08 PM
Default Insert life update
Put 13 more runs on the heads with the inserts for a total of 21 runs. Leak down is
1----90%
2----94%
3----97%
4----99%
5----99%
6----99%
7----95%
8----98%
Don't know whats up with cyl 1, Set the car up with alcohol and had problems all weekend. Maybe the cyl got washed down before we tested it. Also the motor was cold.
Alcohol runs cooler so I don't know if the insert life will be tested with the same stress as with gasoline. We have done a set of heads for a nitrious engine so may be able to get some info on that when it is back together.
So far the inserts in my heads are holding well.
  #79
Old 06-07-2012, 08:38 PM
1----90%
2----94%
3----97%
4----99%
5----99%
6----99%
7----95%
8----98%
wow, 99% so thats 1% leakdown?? did not know that was possible.i wish my motor would do that, it does not even do that when everything is new..you guys must have some secrets!! i have never seen any e.t on the track from minimal leakdown to up to 20 % leakdown in the center cylinders. Bruce Michale's old pontiac motor was the same way he changed head gaskets at 20% leakdown and never even saw it at the track...
guess it all depends on where the air is going...
glenn, hope you get the alcohol tune up fixed.
1.079 4.52 155.15
3000 lbs
Special Thanks to:
Butler Peformance
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #80
Old 08-08-2012, 12:45 AM
lemans411's Avatar
lemans411 lemans411 is offline
can this mod be done to e heads ? mine are soft here from lifting heads under boost. and where do i send em?
-Rob
67 LE MANS in pieces...
68 gto
84 grand prix twin turbo 496 pontiac 25.3 cage
