Old 05-27-2012, 06:40 PM
Formulabruce's Avatar
Originally Posted by njsteve View Post
And the final item of the day was adjusting the clutch, which was grabbing way too high. On a hunch, I pulled the actuating rod and noticed the same wear that was on my other car. This groove was cut halfway through, eventually it would have snapped off. I will be replacing both rods: the bellcrank to fork rod, as well as the pedal to bellcrank rod as they both tend to exhibit the same wear patterns.
the metal in this might be better than the offshore repop. I have mig welded many of these and ground them round, redrill hole. Just an idea. Ill look at my 72 AC car and see whats there
  #222
Old 05-27-2012, 06:59 PM
FunctionalShaker FunctionalShaker is offline
I'm with Bruce on repairing that rod.
  #223
Old 05-28-2012, 09:08 AM
The Boss's Avatar
The Boss The Boss is offline
Great details on the underside Steve!
You have incredible patience!
And go racin' in the street.
  #224
Old 05-28-2012, 10:50 AM
Steve,
You probably intend to keep the car original, and if so, then repairing your existing rod(s) is probably the way to go. But if you intend to drive the car regularly you might want to consider going with the aftermarket rods from speed direct. My linkage rods were worn out just like yours so I went with the aftermarket stuff, and it's the best seventy bucks I spent. It was an easy install and can be changed back to original easily. The replacement rods have heim joints and the clutch operation is so smooth now that it feels like a hydraulic clutch.
Chris
ID:	285902   Click image for larger version
ID:	285903   Click image for larger version
ID:	285904   Click image for larger version
  #225
Old 05-29-2012, 02:37 PM
TH65 TH65 is offline
I'm still collecting parts...and need freon, in case anyone has a few spare cans left they aren't using. The car has a new condensor but sadly it was the wrong one and has the outlets in the completely wrong locations.
Things I still need:
1) correct expansion valve with short capillary tube (the replacement all have this way-too-long tube that really looks bad.)
2) correct condensor
3) metal tab that goes on the bracket that holds the "trumpet-looking hose" to the front of the compressor
4) metal hold down tab that retains the metal hose coming from the POA valve.
Steve, let me know if there are any ac parts in these pics you may need, the condensor is off my 72 Esprit, also have the one off the 71 Formula I sold, the first 2 pics of the ac box is off the 72 and the 2nd pair of pics is off the 71, thanks, Tom
ID:	286027   Click image for larger version
ID:	286028   Click image for larger version
ID:	286029   Click image for larger version
ID:	286030   Click image for larger version
1972 Formula 400 4spd Revere Silver
1972 Esprit 400 2bbl Column Auto-rusty parts car
  #226
Old 05-29-2012, 02:38 PM
71 pics
ID:	286032   Click image for larger version
  #227
Old 05-29-2012, 06:11 PM
njsteve's Avatar
njsteve njsteve is offline
Sure, I can use all that stuff! The condensor, the expansion valve, the various little retaining brackets, etc. Even the AC harness if it is intact since mine is missing some of the wires (melted/cut). Where in NY are you? I could come out with the truck and pick it up.
  #228
Old 05-29-2012, 06:36 PM
The Boss's Avatar
Steve,
I've got a 73 Esprit with A/C that I'm just about to start parting - if you want to take the **** off you can have it!
Chris
  #229
Old 05-29-2012, 07:40 PM
njsteve's Avatar
I really appreciate everybodies offers! Do you have a photo of the A/C firewall housing? I do believe the condensor may mave been different once they started using that giant one-piece octopus crimped A/C line setup.
  #230
Old 05-29-2012, 07:58 PM
The Boss's Avatar
Getting dark out there now, but I'll take one tomorrow for you.
  #231
Old 05-30-2012, 04:19 PM
The Boss's Avatar
Some of it's rusty, but complete and untouched.
Name:	2012-05-30 16.13.59.jpg
  #232
Old 05-30-2012, 07:47 PM
Talk about letting a car rot away there, Boss.
  #233
Old 05-30-2012, 08:01 PM
Just needs some of Steve's Purple TLC!!
  #234
Old 05-30-2012, 09:38 PM
The Boss's Avatar
http://www.youtube.com/watch?v=5NU3aKH6r9g
It was free. Sometimes one must die so that others may live.
  #235
Old 05-30-2012, 09:40 PM
njsteve's Avatar
I got the new heater core installed and the box is back in the dash again. I can never understand how something can drop out so easily but take so much finagling and manhandling to get the darn thing back into the car. It took over an hour to figure out the exact angle and turns to get the heater box back under the dashboard.
  #236
Old 05-30-2012, 10:16 PM
Always the way, Imagine if junk yards had to put cars back together?? LOL
  #237
Old 05-30-2012, 11:04 PM
Hijack! Boss, I knew that was coming when I saw the still shot. You should strip that puppy down before the weather damages more good parts.
Back to you, Steve.
  #238
Old 06-06-2012, 06:57 AM
cnc's Avatar
cnc cnc is offline
Steve looks like I may have struck out.....I have asked my friend again if he has heard anything a few times and nothin....
Hopefully another person will pop up....keep us posted on the progress....ttys Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
  #239
Old 06-06-2012, 10:58 AM
Jim Rotella Jim Rotella is offline
When I replaced the heater core on my '72, I remembered someone saying that GM started with a heater core and then they built the F body car around it. What a true statement that was !!!!
  #240
Old 06-06-2012, 11:20 AM
The Boss's Avatar
Jim, that's funny!
Once you've done a couple it's like riding a bike....although having A/C involved makes the work exponential!
