Old 05-24-2012, 07:31 PM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
Once I figured out where the final placement of the fuel cell was, I'd know what I had to do to attach it and have it pass a tech inspection. After pricing fuel cell straps along with shipping cost I decided on buying one inch flat stock at the Tractor Supply. Two 48 inch long flat stock cost about $15- saving me at least $30-.I got lucky as one of the original gas tank braces lined up with one of my straps. I welded 4"X5" 1/8" thick steel to the other gas tank brace to line up for the other strap. 3/8 grade 5 bolts were used.
Name:	fuel cell on aerocoupe 019.jpg
ID:	285495   Click image for larger version
Name:	fuel cell on aerocoupe 021.jpg
ID:	285496   Click image for larger version
Name:	fuel cell on aerocoupe 024.jpg
Old 05-24-2012, 11:00 PM
triathlonx13's Avatar
Real good deal on fab'n your own custom stuff - safe $$ and do it correct for your appllication!
Old 05-25-2012, 12:10 PM
Originally Posted by triathlonx13 View Post
Always nice when things work out ! Can you access the fill hole ?
I hope I can !! I put the trunk lid on to get a better look and it appears that there will be enough access for a hose nozzle. This will be a pump gas car. I'm also planning on putting the battery in the trunk. I can just sqeeze one in through the decklid opening around the fuel cell.
Name:	fuel cell on aerocoupe 023.jpg
Old 06-10-2012, 10:31 AM
I've got my manual brake system on the car now. I used a Power Master powerbooster adapter plate. This info I found on a thread right here for the part #. I did have to add metal to the top of the plate to completely cover the firewall hole. Bought new a mid 80's master cylinder at A.A. and used a brake pedal rod w/ the metal cup from junkyard mid 80's S-10. I did have to shorten the rod.
Name:	fuel cell on aerocoupe 002.jpg
ID:	287169   Click image for larger version
Name:	aerocoupe brakes 015.jpg
ID:	287170   Click image for larger version
Name:	aerocoupe brakes 016.jpg
ID:	287171   Click image for larger version
Name:	aerocoupe brakes 017.jpg
Old 06-10-2012, 10:45 AM
The 86 Aero Coupe's brake petal did have the extra hole for manual brakes. Unfortunately the M.P. adapter is designed to use the power brake position. Hooked up a line lock solenoid and put in the steering column. Now I can move the car around a little easier.
Name:	aerocoupe brakes 018.jpg
ID:	287173   Click image for larger version
Name:	aerocoupe brakes 022.jpg
ID:	287174   Click image for larger version
Name:	aero brakes and running engine stand 019.jpg
Old 07-20-2012, 11:44 PM
LeoP's Avatar
LeoP LeoP is offline
Wish I had the room to do a frame off, looks great, good luck.
  #107
Old 07-21-2012, 07:32 AM
Thanks, the aero coupe has been on the back burner trying to get the 65 going for Norwalk.
Old 07-21-2012, 08:06 AM
Money Pit's Avatar
Money Pit Money Pit is offline
You make it to the track yet with the 65?
Old 07-21-2012, 08:18 AM
Jeff, I literally just got her running yesterday. It's not the old motor but it will work for now,old school 455. Needs some more adjustments and hopefully the 30 year old 800 holley will get the job done for now! I did drive her down the road so I'm pretty close. They have Nostalgia Drags down here in Crossville today. I'd be lucky if I can get her running right for that show.
Old 07-21-2012, 08:22 AM
Money Pit's Avatar
Mike, got ya on that. Good to here she's purring again! Take your time and make sure she's right. Slow and steady wins the race!
Old 08-15-2012, 06:54 PM
Jeff, you got that right. The 65 ran very consistent at Norwalk !
Old 08-15-2012, 07:02 PM
Starting to put some time back on the wife's aero coupe. I took the crash braces out of the doors today. Gotta be good for 15 to 20 lbs less weight.
Name:	wifes aerocoupe, doors 012.jpg
ID:	294569   Click image for larger version
Name:	wifes aerocoupe, doors 013.jpg
ID:	294570   Click image for larger version
Name:	wifes aerocoupe, doors 014.jpg
Old 08-28-2012, 09:51 AM
Here's one of the doors, rust and metal repair finished on the inside. The other door is rougher, needing more metal replacement.
Name:	aerocoupe door 003.jpg
ID:	295822   Click image for larger version
Name:	aerocoupe door 004.jpg
ID:	295823   Click image for larger version
Name:	aerocoupe door 005.jpg
ID:	295824   Click image for larger version
Name:	aerocoupe door 006.jpg
Old 09-09-2012, 09:37 AM
Just finished putting a couple coats of paint on the GM 12 bolt that is going in the Aero Coupe. I'll give it a couple days to cure then put it in.
Name:	aerocoupe rear 004.jpg
ID:	296996   Click image for larger version
Name:	aerocoupe rear 005.jpg
Old 09-15-2012, 08:14 AM
Fortunately for me, the 12 bolt 's application was as advertised. It fits in the 86 G-body. I'm using AutoFab Racing double adjustable upper control arms.
Name:	65's engine parts 007.jpg
Old 09-26-2012, 06:49 PM
The shell is getting closer to paint. Hopefully I'll have it painted before it gets to cold.
Name:	aerocoupe shell 005.jpg
ID:	298479   Click image for larger version
Name:	aerocoupe shell 006.jpg
Old 10-23-2012, 08:14 PM
I got the Aero Coupe's shell painted today. Looks fairly straight for being such a banged up car. We've had some nice weather this week breaking 80 today.
Old 10-23-2012, 08:20 PM
Helps if I add the photos !!
Name:	aerocoupe painted 015.jpg
ID:	301314   Click image for larger version
Name:	aerocoupe painted 016.jpg
ID:	301315   Click image for larger version
Name:	aerocoupe painted 017.jpg
ID:	301317   Click image for larger version
Name:	aerocoupe painted 018.jpg
ID:	301318   Click image for larger version
Name:	aerocoupe painted 019.jpg
Old 10-23-2012, 08:23 PM
pontiacjeff pontiacjeff is offline
Mike, where are you in TN? I gotta roll thru and see this thing as it starts to go back together... coming up to Knoxville in a week or so. Also have a friend in Nashville.
Jeff Ianitello
  #120
Old 10-23-2012, 08:25 PM
ITS BLACK! OMG! I guess I missed that part of the conversation. What paint scheme are you using? Stripes? decals?
Jeff Ianitello
